CCS: Switching compiler version in code composer modifies target string in [Project]->[Properties]->[General]::Tab[Products] | Target: textbox
Hi, when switching from compiler version (in this case due to upgrade from CCSV8 to CCSV9) i discovered a bug I've seen before:
The textbox in the products section of my project properties / general containing the Target string is modified in this process, resulting in errors: it was ti.targets.arm.elf.M4F, but changed to ti.targets.arm.elf.M4.
I can work with this, but since two of my colleagues are not too fond of the whole Code Composer environment and take every chance to criticize the IDE, can this issue be fixed?
