Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN, TMDX570LC43HDK
We have a code base that was developed for the TMS570LS3157 using CCS v6.0.1 and TI ARM Compiler v5.1.6 over the last few years. We are now porting some of the code to a TMS570LC4357. We will be generating a new BSP using HALCoGen. We are working in avionics where changing the development environment has an expensive ripple effect, so we would like to use the same CCS / TI ARM Compiler if possible.
1) What might force us to update CCS or the ARM Compiler? Our preliminary tests indicate the code will compile and run on a TMDX570LC43HDK.
2) Are there any compatibility issues between versions of CCS and versions of the ARM Compiler, or can I install any compiler version listed under Help | Install New Software | TI Compiler Updates?
Thank you,
Charlie Johnston
