CCS/AWR1443BOOST: metadata not determined
Part Number: AWR1443BOOST
I am using code composer studio v7 in ubuntu. generated bin files using mmsdk 2.1.0.4 but generated only mss.xer4f file and generated mss.bin file. While trying to import project to ccs i got the error metadata is not determined. Can you suggest how to resolve this.
  • Kusum,
    I'm not sure if I understand the issue correctly. Are you trying to import a mmWave example project into CCS and getting the error during import? If so, which example?
    The example projects in Industrial Toolbox typically require a specific version of mmWave SDK and other tools to be fully compatible. If they are not, that could results in errors during import and/or build. So if you are importing an example project please check the Setup Guide or User's Guide that comes with it to check for dependencies and ensure you are using those exact versions. See this related post.
    If your issue is something different, please provide more details.
  • Since I haven’t heard back from you, I’m assuming you were able to move past this issue. If not, please feel free to post a reply with more details as requested in the previous post. Thanks!
