Part Number: TMS320F28069
I enabled the MISRA C 2004 check from project properties and trying to make my motor control as comliant to MISRA C as possible.
Whenever i access a bitfield in the following format i get MISRA C warning.
GpioDataRegs.GPATOGGLE.bit.GPIO18=1; 'Description Resource Path Location Type #1393-D (MISRA-C:2004 10.1/R) The value of an expression of integer type shall not be implicitly converted to a different underlying type if it is not a conversion to a wider integer type of the same signedness main.c /FOC line 213 C/C++ Problem '
How to avoid this warning?
Shadab
