MATLAB and CCS
Hai,
             I want to link matlab and CCSV3.3 i want to know which are all the versions supports, Weather MATLAB 2010A or B supports.... And also for CCS 4.1 which matlab will support, Suggestions please......
thanks in advance.....
    I believe both do but it is best to contact Mathworks for confirmation.
    shan said:
    And also for CCS 4.1 which Matlab will support
    No version of Matlab supports CCSv4.x
  • Hai Lee,
        Thanks for your reply, I check with Mathworks , Both the version of matlab will work with CCS. and i want to know why CCS4.X wont support the Matlab....
    Mathworks decided not to port their software to work with v4. They will support v5.
  • Hi Lee,
                Thakns for your valuable information......
  • HI
    I use matlab to generate code used on tmsf2812 ,but matlab report some mistakes  as following:
     >> checkEnvSetup('ccs', 'F2812', 'setup')
    1. Checking CCS (Code Composer Studio) version
       Required version: 3.3.82.13
       Required by     : Embedded IDE Link 4.2
       Required for    : Automation and Code Generation
       Your Version    : 3.3.81.6
       Incompatible version detected. CCS version does not satisfy product requirements!
    2. Checking CGT (Texas Instruments C2000 Code Generation Tools) version
       Required version: 5.2.1
       Required for    : Code generation
       Your Version    : 4.1.3
       Incompatible version detected. CGT version does not satisfy product requirements!
    3. Checking DSP/BIOS (Real Time Operating System) version
       Required version: 5.33.05
       Required for    : Real-Time Data Exchange (RTDX)
       Your Version    : 5.31.02
       Incompatible version detected. DSP/BIOS version does not satisfy product requirements!
    4. Checking Flash Tools (TMS320C2812 Flash APIs) version
       Required version: 2.10
       Required by     : Target Support Package 4.2
       Required for    : Flash Programming
    Warning: Installation directory for Flash Tools is invalid.
    > In C:\Program Files\MATLAB\R2010b\toolbox\idelink\extensions\ticcs\envChecker\checkEnvSetup_private.p>updateInstallDir at 531
      In C:\Program Files\MATLAB\R2010b\toolbox\idelink\extensions\ticcs\envChecker\checkEnvSetup_private.p>envSetup at 269
      In C:\Program Files\MATLAB\R2010b\toolbox\idelink\extensions\ticcs\envChecker\checkEnvSetup_private.p>checkEnvSetup_private at 68
      In checkEnvSetup at 131
       Your Version    :
       Incompatible version detected. Flash Tools version does not satisfy product requirements!
       Following environment variables required for code generation could not be set:
       ### "FLASH_2812_API_INSTALLDIR"
                                                          so ,my question is where can i download such files?
    thank you!
    best  regards!
    thank you!
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv3/CCS_3_3/exports/SR12_CCS_v3.3_SR_3.3.82.13.exe
    http://software-dl.ti.com/dsps/dsps_registered_sw/sdo_ccstudio/codegen/C2000/5.2.1/exports/ti_cgt_c2000_5.2.1_setup_win32.exe
    http://software-dl.ti.com/dsps/dsps_registered_sw/sdo_sb/targetcontent/bios/bios_5_33/bios_5_33_05/index_external.html
       Your Version    :
    Looks like this is something from Mathworks
    http://www.mathworks.com/products/embedded-coder/prev_requirements_ti.html
    ki
  • thanks for your answer!  What problem will appear if  CCS version does not satisfy MATLAB requirements? In fact, Code can be generated under the current version which aren't updated.
  • That question is best asked to the people at Mathworks.
    ki
    ok, my problem have solved!  guys can refer to http://www.mathworks.com/help/toolbox/ecoder/ug/f0-63953.html  .
    Thank you very much. Best regards for you!
  • Just wanted to say thanks for this post, saved me from hours of searching to get this setup.
    Very much appreciated.
  • thanks a lot, it really helps.
