CCS/MSP432E401Y: CCS/MSP432E401Y: Perspectives not saving - continued
Part Number: MSP432E401Y
Team,
Below post is a continuation of problem described a couple of months ago: https://e2e.ti.com/support/tools/ccs/f/81/p/814440/3027659#3027659. From customer:
I am increasingly seeing this phenomenon more and more:
CCS will go to 100% CPU utilization for several seconds (sometimes up to 10 seconds at a time), while seemingly doing nothing. Sometimes restarting it helps for a while. While it is at 100% utilization, I can not do anything; I just have to wait for it to un-stick itself. It will do this several times in a row -- I can perform one operation (say, changing tabs in a window), then wait a few more seconds, then perform another operation, wait a few more seconds, and so on.
 I'm on Ubuntu 18.04, running CCS 9.1.0.00010
 If it helps, I've attached the CCS error log:
!SESSION 2019-08-19 08:57:21.741 -----------------------------------------------
eclipse.buildId=4.8.0.I20180611-0500
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product com.ti.ccstudio.branding.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product com.ti.ccstudio.branding.product
This is a continuation of log file /home/rugrat/workspace_v9/.metadata/.bak_2.log
Created Time: 2019-08-20 13:49:58.123
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:49:58.123
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=23, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@9a56d2b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=23, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@9a56d2b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
	at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:88)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:196)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:340)
	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.reconcileManagerToModel(ToolBarManagerRenderer.java:970)
	at org.eclipse.ui.internal.e4.compatibility.ActionBars.updateActionBars(ActionBars.java:94)
	at org.eclipse.ui.SubActionBars.updateActionBars(SubActionBars.java:622)
	at org.eclipse.ui.SubActionBars.dispose(SubActionBars.java:266)
	at org.eclipse.ui.part.PageBookView.removePage(PageBookView.java:834)
	at org.eclipse.ui.part.PageBookView.partClosed(PageBookView.java:762)
	at org.eclipse.ui.internal.console.ConsoleView.partClosed(ConsoleView.java:140)
	at org.eclipse.ui.internal.console.ConsoleView$5.run(ConsoleView.java:436)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4915)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4521)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
Caused by: java.lang.NullPointerException
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=24, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@3d376d9b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=24, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@3d376d9b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:49:58.138
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=18, Widget=ToolBar {}, NewValue=fixedGroup=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@328f4e46 (tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=18, Widget=ToolBar {}, NewValue=fixedGroup=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@328f4e46 (tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:49:58.139
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=19, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@17e9e99 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=19, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@17e9e99 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:49:58.140
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=20, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@9a56d2b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=20, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@9a56d2b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:49:58.142
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=21, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@3d376d9b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=21, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@3d376d9b (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:50:02.905
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=18, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@3de4c41c (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=18, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@3de4c41c (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.reconcileManagerToModel(ToolBarManagerRenderer.java:963)
	at org.eclipse.ui.part.PageBookView.showPageRec(PageBookView.java:958)
	at org.eclipse.ui.internal.console.ConsoleView.showPageRec(ConsoleView.java:166)
	at org.eclipse.ui.part.PageBookView.partActivated(PageBookView.java:720)
	at org.eclipse.ui.internal.console.ConsoleView$4.run(ConsoleView.java:411)
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:50:02.906
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=19, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@5b9d1aaa (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=19, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@5b9d1aaa (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:50:02.907
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=20, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@6fd1b393 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=20, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@6fd1b393 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:58:54.146
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:58:54.147
!STACK 0
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:58:54.148
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:58:58.950
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=18, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@b73415 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=18, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@b73415 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:58:58.951
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=19, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@791ba467 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=19, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@791ba467 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:58:58.952
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.ui.console.ConsoleView=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolBarImpl@6c8f60f3 (tags: [], contributorURI: null) (widget: ToolBar {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer@22ff11ef, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=20, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@d9752b3 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)}, AttName=children, EventType=ADD, Position=20, Widget=ToolBar {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.DirectToolItemImpl@d9752b3 (elementId: null, tags: [Opaque], contributorURI: null) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, enabled: true, selected: false, type: Push) (contributionURI: null, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:59:20.075
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=PartStack@610d28b8=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@77db3d02 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, noFocus, active], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@2bd4780c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=PartStack@610d28b8=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@77db3d02 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, noFocus, active], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@2bd4780c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=4, Widget=CTabFolder {}, NewValue=Drag Placerholder=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@530cce20 (tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: false)}, AttName=children, EventType=ADD, Position=4, Widget=CTabFolder {}, NewValue=Drag Placerholder=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@530cce20 (tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: false)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
	at org.eclipse.e4.ui.workbench.addons.dndaddon.DragAgent.dragStart(DragAgent.java:100)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.PartDragAgent.dragStart(PartDragAgent.java:88)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDManager.startDrag(DnDManager.java:222)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDManager.lambda$0(DnDManager.java:81)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:128)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5686)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1370)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4940)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4518)
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:59:20.701
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=PartStack@610d28b8=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@77db3d02 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, noFocus, active], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@2bd4780c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=PartStack@610d28b8=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@77db3d02 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, noFocus, active], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@2bd4780c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=6, Widget=CTabFolder {}, NewValue=org.eclipse.debug.ui.ExpressionView=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@36ab3814 (tags: [View, categoryTag:Debug], contributorURI: null) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer@229cb4d8, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: true)}, AttName=children, EventType=ADD, Position=6, Widget=CTabFolder {}, NewValue=org.eclipse.debug.ui.ExpressionView=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@36ab3814 (tags: [View, categoryTag:Debug], contributorURI: null) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer@229cb4d8, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: true)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
	at org.eclipse.e4.ui.workbench.addons.dndaddon.StackDropAgent.dock(StackDropAgent.java:327)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.StackDropAgent.drop(StackDropAgent.java:401)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.DragAgent.dragFinished(DragAgent.java:169)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.PartDragAgent.dragFinished(PartDragAgent.java:100)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDManager.finishDrag(DnDManager.java:261)
	at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDManager.startDrag(DnDManager.java:228)
!ENTRY org.eclipse.equinox.event 4 0 2019-08-20 13:59:22.087
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=PartStack@610d28b8=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@77db3d02 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, noFocus, active], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@2bd4780c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=PartStack@610d28b8=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@77db3d02 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, noFocus, active], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@2bd4780c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=children, EventType=ADD, Position=6, Widget=CTabFolder {}, NewValue=Drag Placerholder=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@6b9bc7a8 (tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: false)}, AttName=children, EventType=ADD, Position=6, Widget=CTabFolder {}, NewValue=Drag Placerholder=org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@6b9bc7a8 (tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: false)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@5a837512
!STACK 0
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-20 14:32:42.165
!MESSAGE DS_ERROR: CORTEX_M4_0: JTAG Communication Error: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 8.2.0.00004)
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-20 14:32:42.259
!MESSAGE DS_ERROR: CORTEX_M4_0: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-20 15:29:14.733
!MESSAGE DS_ERROR: CORTEX_M4_0: GEL: Error while executing OnRestart( 0 ): Specified reset is not allowed at this time
	 at GEL_AdvancedReset("System Reset", 1) [msp432e401y.gel:188]
	 at OnRestart(0)
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-20 16:35:09.768
!MESSAGE DS_ERROR: CORTEX_M4_0: GEL: File: /home/rugrat/git/msprepository/IO_432_PTP2/BMP_Image/IO_432_PTP2.out Load cancelled by user.
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-20 16:40:02.770
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-20 16:40:02.859
!SESSION 2019-08-21 10:41:22.636 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-21 10:41:23.460
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 1 0 2019-08-21 10:41:23.461
!MESSAGE debugServerDir=/home/rugrat/ti/ccs901/ccs/ccs_base/DebugServer
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 10:41:28.438
!MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 10:41:28.441
!MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-21 10:41:28.493
!MESSAGE CCS IDE session started!
	CCS build: 9.1.0.00010
	CCS location: /home/rugrat/ti/ccs901/ccs
	Workspace location: /home/rugrat/workspace_v9
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 10:41:28.636
!MESSAGE constructor
!MESSAGE done with directories
!MESSAGE loading ti_logger
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 10:41:28.637
!MESSAGE Platform os: linux
!MESSAGE loading cTools
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 10:41:28.640
!MESSAGE loading TraceFactory
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 10:41:28.641
!MESSAGE loading sqlite3
!MESSAGE loading CloudTrace
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 10:41:28.650
!MESSAGE CloudTrace interface loaded
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-21 10:41:53.152
!MESSAGE No repository found at file:/tmp/mozilla_rugrat0/CCS9.0.1.00004_linux-x64/baserepo/tools-commonRepo.
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.154
!MESSAGE Could not set property: ccs associatedFiles. Value is too long.
!STACK 0
java.lang.Exception: Could not set property: ccs associatedFiles. Value is too long.
	at org.eclipse.core.internal.resources.ResourceException.provideStackTrace(ResourceException.java:39)
	at org.eclipse.core.internal.resources.ResourceException.<init>(ResourceException.java:35)
	at org.eclipse.core.internal.properties.PropertyManager2.setProperty(PropertyManager2.java:169)
	at org.eclipse.core.internal.resources.Resource.setPersistentProperty(Resource.java:1666)
	at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.associateFileWithContext(CoffErrorParser.java:449)
	at com.ti.ccstudio.errorparser.parsers.ErrorPattern.recordError(ErrorPattern.java:121)
	at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.processPendingMesg(CoffErrorParser.java:258)
	at com.ti.ccstudio.errorparser.parsers.CoffErrorParser.doProcessLine(CoffErrorParser.java:112)
	at com.ti.ccstudio.errorparser.parsers.BaseErrorParser.processLine(BaseErrorParser.java:327)
	at org.eclipse.cdt.core.ErrorParserManager.processLine(ErrorParserManager.java:366)
	at org.eclipse.cdt.core.ErrorParserManager.checkLine(ErrorParserManager.java:705)
	at org.eclipse.cdt.core.ErrorParserManager.write(ErrorParserManager.java:689)
	at org.eclipse.cdt.internal.core.StreamProgressMonitor.write(StreamProgressMonitor.java:101)
	at java.io.OutputStream.write(OutputStream.java:75)
	at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$SynchronizedOutputStream.flushBufferedErrors(ProcessClosure.java:256)
	at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$SynchronizedOutputStream.write(ProcessClosure.java:207)
	at com.ti.ccstudio.project.core.internal.build.temp.ProcessClosure$ReaderThread.run(ProcessClosure.java:78)
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.156
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.157
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.159
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.160
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.161
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.162
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.163
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.164
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-21 11:06:07.165
!STACK 0
!SESSION 2019-08-21 14:27:15.875 -----------------------------------------------
Framework arguments:  -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product com.ti.ccstudio.branding.product -data file:/home/rugrat/workspace_v9/ -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 1 0 2019-08-21 14:27:16.575
!ENTRY com.ti.common.core 1 0 2019-08-21 14:27:16.576
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 14:27:20.975
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 14:27:20.982
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-21 14:27:21.016
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 14:27:21.110
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 14:27:21.111
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 14:27:21.114
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 14:27:21.115
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 14:27:21.119
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-21 14:27:48.467
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-21 14:57:59.016
!MESSAGE DS_ERROR: Warning:
A firmware update is required for the debug probe. Click the "Update" button to update the firmware and connect to the debug target.
DO NOT UNPLUG THE DEBUG PROBE DURING THE UPDATE.
!SESSION 2019-08-21 15:26:37.335 -----------------------------------------------
Framework arguments:  -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -data file:/home/rugrat/workspace_v9/ -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 1 0 2019-08-21 15:26:38.040
!ENTRY com.ti.common.core 1 0 2019-08-21 15:26:38.041
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 15:26:42.279
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 15:26:42.285
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-21 15:26:42.491
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 15:26:42.602
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 15:26:42.603
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 15:26:42.604
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 15:26:42.606
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 15:26:42.607
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 15:26:42.614
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-21 15:27:09.109
!SESSION 2019-08-21 17:01:17.740 -----------------------------------------------
Framework arguments:  -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -data file:/home/rugrat/workspace_v9/ -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 1 0 2019-08-21 17:01:18.441
!ENTRY com.ti.common.core 1 0 2019-08-21 17:01:18.442
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 17:01:22.933
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-21 17:01:22.937
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-21 17:01:23.123
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 17:01:23.220
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 17:01:23.221
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 17:01:23.223
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 17:01:23.224
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-21 17:01:23.228
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-21 17:01:49.709
!SESSION 2019-08-22 09:09:33.839 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-22 09:09:34.560
!ENTRY com.ti.common.core 1 0 2019-08-22 09:09:34.561
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-22 09:09:38.773
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-22 09:09:38.778
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-22 09:09:38.821
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-22 09:09:38.926
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-22 09:09:38.927
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-22 09:09:38.929
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-22 09:09:38.930
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-22 09:09:38.933
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-22 09:10:32.809
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-22 12:18:24.699
	 at OnRestart(0)
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-22 12:20:44.911
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-22 13:26:35.407
!MESSAGE DS_ERROR: CS_DAP_0: Error connecting to the target: (Error -267 @ 0x0) The controller could not detect valid target supply. Check target JTAG connection and/or connection setting specifying voltage level. (Emulation package 8.2.0.00004)
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-22 13:26:35.439
!MESSAGE DS_ERROR: Error connecting to the target:
(Error -267 @ 0x0)
!ENTRY org.eclipse.cdt.core 1 0 2019-08-22 14:38:22.392
!MESSAGE Indexed 'IO_432_PTP2' (154 sources, 255 headers) in 3.59 sec: 20,207 declarations; 93,816 references; 0 unresolved inclusions; 6 syntax errors; 458 unresolved names (0.4%)
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-22 17:26:58.675
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-22 17:27:15.028
!MESSAGE DS_ERROR: CS_DAP_0: Error: (Error -267 @ 0x0) The controller could not detect valid target supply. Check target JTAG connection and/or connection setting specifying voltage level. (Emulation package 8.2.0.00004)
!SESSION 2019-08-23 09:18:16.385 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 09:18:17.124
!ENTRY com.ti.common.core 1 0 2019-08-23 09:18:17.125
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 09:18:21.249
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 09:18:21.254
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 09:18:21.296
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:18:21.413
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:18:21.414
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:18:21.416
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:18:21.417
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:18:21.421
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 09:18:50.173
!SESSION 2019-08-23 09:58:34.627 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 09:58:35.350
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 09:58:39.569
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 09:58:39.573
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 09:58:39.626
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:58:39.727
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:58:39.728
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:58:39.729
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:58:39.731
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:58:39.732
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:58:39.733
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 09:58:39.738
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 09:59:12.841
!SESSION 2019-08-23 10:06:08.573 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 10:06:09.272
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 10:06:13.374
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 10:06:13.379
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 10:06:13.519
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:06:13.627
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:06:13.628
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:06:13.631
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:06:13.632
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:06:13.633
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:06:13.638
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 10:06:49.628
!SESSION 2019-08-23 10:56:05.640 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 10:56:06.317
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 10:56:10.571
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 10:56:10.574
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 10:56:10.629
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:56:10.727
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:56:10.728
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:56:10.730
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:56:10.731
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 10:56:10.736
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 10:56:39.290
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-23 11:08:10.683
!MESSAGE DS_ERROR: CORTEX_M4_0: Breakpoint Manager: Error enabling this function: Address exceeds the allowed range
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-23 11:08:18.718
!SESSION 2019-08-23 13:32:02.498 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 13:32:03.213
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 13:32:05.986
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 13:32:05.992
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 13:32:07.336
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 13:32:07.389
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 13:32:07.390
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 13:32:07.393
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 13:32:07.398
!ENTRY com.ti.common.project.core 1 0 2019-08-23 13:32:23.092
!MESSAGE Project 'IO_432_PTP2' could not be loaded!
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 13:32:34.756
!ENTRY com.ti.ccstudio.debug 1 0 2019-08-23 14:36:58.640
	 at OnRestart(0)
!SESSION 2019-08-23 15:07:52.245 -----------------------------------------------
Framework arguments:  -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product -data file:/home/rugrat/workspace_v9/ -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 1 0 2019-08-23 15:07:52.952
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 15:07:57.465
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 15:07:57.472
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 15:07:57.694
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:07:57.794
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:07:57.795
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:07:57.798
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:07:57.799
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:07:57.804
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 15:08:25.419
!SESSION 2019-08-23 15:09:28.640 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 15:09:29.364
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 15:09:33.826
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 15:09:33.830
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 15:09:34.056
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:09:34.137
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:09:34.138
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:09:34.139
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:09:34.142
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 15:09:34.147
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 15:09:59.425
!SESSION 2019-08-23 17:04:03.331 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 17:04:04.143
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 17:04:08.535
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 17:04:08.539
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 17:04:08.540
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 17:04:08.780
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:04:08.856
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:04:08.857
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:04:08.858
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:04:08.860
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:04:08.861
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:04:08.867
!ENTRY org.eclipse.equinox.p2.updatechecker 4 0 2019-08-23 17:04:12.291
!MESSAGE Exception in update check thread
!STACK 0
org.eclipse.core.runtime.OperationCanceledException
	at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:126)
	at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:158)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.handleRemoteIndexFile(AbstractRepositoryManager.java:721)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:715)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:657)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:107)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:102)
	at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:165)
	at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:107)
	at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:121)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:60)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:767)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
	at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:149)
	at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:127)
	at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:75)
!ENTRY org.eclipse.core.jobs 4 2 2019-08-23 17:04:12.388
!MESSAGE An internal error occurred during: "Replace IU Job".
!STACK 0
	at com.ti.ccstudio.app.center.internal.CCSAppCenter.log(CCSAppCenter.java:446)
	at com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:414)
	at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$3(CCSAppCenter.java:358)
	at com.ti.ccstudio.app.center.internal.CCSAppCenter$2.run(CCSAppCenter.java:234)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
!SESSION 2019-08-23 17:05:56.101 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-23 17:05:56.864
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 17:06:01.155
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-23 17:06:01.165
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-23 17:06:01.383
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:06:01.491
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:06:01.492
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:06:01.495
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:06:01.496
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-23 17:06:01.501
!ENTRY org.eclipse.cdt.core 4 0 2019-08-23 17:06:02.542
!MESSAGE Error
!STACK 1
C Model Exception: C Model Status [Element lwip does not exist.]
	at org.eclipse.cdt.internal.core.model.CElement.newNotPresentException(CElement.java:484)
	at org.eclipse.cdt.internal.core.model.CContainer.buildStructure(CContainer.java:156)
	at org.eclipse.cdt.internal.core.model.Openable.generateInfos(Openable.java:261)
	at org.eclipse.cdt.internal.core.model.CElement.openWhenClosed(CElement.java:427)
	at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:305)
	at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:295)
	at org.eclipse.cdt.internal.core.model.Parent.getChildren(Parent.java:55)
	at org.eclipse.cdt.internal.core.model.CElement.accept(CElement.java:524)
	at org.eclipse.cdt.internal.core.model.CElement.accept(CElement.java:526)
	at org.eclipse.cdt.internal.core.pdom.indexer.PDOMUpdateTask.createDelegate(PDOMUpdateTask.java:111)
	at org.eclipse.cdt.internal.core.pdom.indexer.PDOMUpdateTask.run(PDOMUpdateTask.java:86)
	at org.eclipse.cdt.internal.core.pdom.PDOMIndexerJob.run(PDOMIndexerJob.java:155)
!SUBENTRY 1 org.eclipse.cdt.core 4 969 2019-08-23 17:06:02.542
!MESSAGE Element lwip does not exist.
!ENTRY org.eclipse.cdt.core 4 0 2019-08-23 17:06:02.543
!MESSAGE Error
!STACK 1
!SUBENTRY 1 org.eclipse.cdt.core 4 969 2019-08-23 17:06:02.543
!MESSAGE Error
!STACK 1
!ENTRY org.eclipse.cdt.core 4 0 2019-08-23 17:06:02.544
!MESSAGE Error
!STACK 1
!SUBENTRY 1 org.eclipse.cdt.core 4 969 2019-08-23 17:06:02.544
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-23 17:06:31.382
!SESSION 2019-08-26 09:05:12.315 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-26 09:05:13.304
!ENTRY com.ti.common.core 1 0 2019-08-26 09:05:13.305
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 09:05:16.526
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 09:05:16.529
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-26 09:05:19.111
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 09:05:19.177
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 09:05:19.178
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 09:05:19.186
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 09:05:19.220
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 09:05:19.221
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 09:05:19.239
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-26 09:05:46.943
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 09:05:57.881
!MESSAGE Indexed 'msp432_loader' (15 sources, 82 headers) in 1.32 sec: 5,267 declarations; 8,454 references; 0 unresolved inclusions; 10 syntax errors; 127 unresolved names (0.92%)
!ENTRY org.eclipse.core.resources 4 1 2019-08-26 10:16:02.825
!MESSAGE Problems occurred while refreshing local changes
!SUBENTRY 1 org.eclipse.core.resources 4 1 2019-08-26 10:16:02.825
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Errors occurred while refreshing resources with the local file system.
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.refreshResource(FileSystemResourceManager.java:976)
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.refresh(FileSystemResourceManager.java:956)
	at org.eclipse.core.internal.resources.Resource.refreshLocal(Resource.java:1547)
	at org.eclipse.core.internal.refresh.RefreshJob.runInWorkspace(RefreshJob.java:163)
	at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:39)
Contains: The project description file (.project) for 'msp432_loader' is missing.  This file contains important information about the project.  The project will not function properly until this file is restored.
java.lang.Exception: The project description file (.project) for 'msp432_loader' is missing.  This file contains important information about the project.  The project will not function properly until this file is restored.
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.read(FileSystemResourceManager.java:903)
	at org.eclipse.core.internal.resources.Project.updateDescription(Project.java:1341)
	at org.eclipse.core.internal.resources.File.updateMetadataFiles(File.java:379)
	at org.eclipse.core.internal.localstore.RefreshLocalVisitor.visit(RefreshLocalVisitor.java:288)
	at org.eclipse.core.internal.localstore.UnifiedTree.accept(UnifiedTree.java:110)
	at org.eclipse.core.internal.localstore.FileSystemResourceManager.refreshResource(FileSystemResourceManager.java:973)
!SUBENTRY 2 org.eclipse.core.resources 4 271 2019-08-26 10:16:02.825
!MESSAGE Errors occurred while refreshing resources with the local file system.
!SUBENTRY 3 org.eclipse.core.resources 4 567 2019-08-26 10:16:02.825
!MESSAGE The project description file (.project) for 'msp432_loader' is missing.  This file contains important information about the project.  The project will not function properly until this file is restored.
!STACK 0
!ENTRY org.eclipse.ui.ide 4 4 2019-08-26 10:16:10.281
!MESSAGE Problems saving workspace
!ENTRY org.eclipse.ui.ide 2 1 2019-08-26 10:16:10.281
!MESSAGE Problems occurred while trying to save the state of the workbench.
!SUBENTRY 1 org.eclipse.core.resources 2 234 2019-08-26 10:16:10.281
!MESSAGE The project description file (.project) for 'msp432_loader' was missing.  This file contains important information about the project.  A new project description file has been created, but some information about the project may have been lost.
!SESSION 2019-08-26 10:44:48.645 -----------------------------------------------
eclipse.buildId=4.8.0.I20180611-0500
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
!ENTRY com.ti.common.core 1 0 2019-08-26 10:44:49.371
!ENTRY com.ti.common.core 1 0 2019-08-26 10:44:49.372
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 10:44:51.904
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 10:44:51.906
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 10:44:51.907
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-26 10:44:53.115
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 10:44:53.192
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 10:44:53.194
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 10:44:53.195
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 10:44:53.198
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-26 10:45:20.839
!SESSION 2019-08-26 11:11:46.317 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-26 11:11:47.042
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 11:11:51.201
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 11:11:51.206
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-26 11:11:51.400
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 11:11:51.522
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 11:11:51.523
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 11:11:51.526
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 11:11:51.534
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-26 11:12:19.721
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.632
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.633
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.634
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.635
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.636
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.637
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.638
!STACK 0
!ENTRY org.eclipse.core.resources 4 568 2019-08-26 11:13:10.640
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 12:47:07.741
!MESSAGE Indexed 'msp432_loader' (15 sources, 82 headers) in 1.29 sec: 5,338 declarations; 8,577 references; 0 unresolved inclusions; 10 syntax errors; 127 unresolved names (0.9%)
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 13:14:15.441
!MESSAGE Indexed 'msp432_loader' (15 sources, 82 headers) in 1.03 sec: 5,267 declarations; 8,455 references; 0 unresolved inclusions; 10 syntax errors; 127 unresolved names (0.92%)
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 13:14:58.355
!MESSAGE Indexed 'msp432_loader' (15 sources, 82 headers) in 0.881 sec: 5,338 declarations; 8,578 references; 0 unresolved inclusions; 10 syntax errors; 127 unresolved names (0.9%)
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 13:15:17.032
!MESSAGE Indexed 'msp432_loader' (15 sources, 82 headers) in 0.675 sec: 5,267 declarations; 8,455 references; 0 unresolved inclusions; 10 syntax errors; 127 unresolved names (0.92%)
!SESSION 2019-08-26 13:20:47.394 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-26 13:20:48.140
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 13:20:52.462
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 13:20:52.465
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 13:20:52.466
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-26 13:20:52.687
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 13:20:52.770
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 13:20:52.771
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 13:20:52.772
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 13:20:52.775
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 13:20:52.776
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 13:20:52.777
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 13:20:52.781
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-26 13:21:24.900
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 13:32:44.176
!MESSAGE Indexed 'msp432_loader' (15 sources, 82 headers) in 1.33 sec: 5,338 declarations; 8,578 references; 0 unresolved inclusions; 10 syntax errors; 127 unresolved names (0.9%)
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 13:41:55.364
!MESSAGE Indexed 'msp432_loader' (15 sources, 82 headers) in 0.643 sec: 5,338 declarations; 8,578 references; 0 unresolved inclusions; 10 syntax errors; 127 unresolved names (0.9%)
!ENTRY org.eclipse.cdt.core 1 0 2019-08-26 14:58:52.987
!MESSAGE Indexed 'CD_432' (117 sources, 211 headers) in 1.96 sec: 10,533 declarations; 38,361 references; 14 unresolved inclusions; 0 syntax errors; 893 unresolved names (1.8%)
!SESSION 2019-08-26 14:59:33.758 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-26 14:59:34.457
!ENTRY com.ti.common.core 1 0 2019-08-26 14:59:34.458
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 14:59:38.786
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 14:59:38.790
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 14:59:38.792
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-26 14:59:39.015
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 14:59:39.106
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 14:59:39.107
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 14:59:39.109
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 14:59:39.110
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 14:59:39.113
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 14:59:39.114
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 14:59:39.119
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-26 15:00:11.817
!SESSION 2019-08-26 15:14:56.119 -----------------------------------------------
!ENTRY com.ti.common.core 1 0 2019-08-26 15:14:56.835
!ENTRY com.ti.common.core 1 0 2019-08-26 15:14:56.836
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 15:15:01.177
!ENTRY org.eclipse.launchbar.core 2 0 2019-08-26 15:15:01.182
!ENTRY com.ti.ccstudio.ui 1 0 2019-08-26 15:15:01.377
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 15:15:01.469
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 15:15:01.470
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 15:15:01.473
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 15:15:01.474
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2019-08-26 15:15:01.480
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2019-08-26 15:15:32.656
  • Hello Viktorija,
    Viktorija Cecil said:
    CCS will go to 100% CPU utilization for several seconds (sometimes up to 10 seconds at a time), while seemingly doing nothing. Sometimes restarting it helps for a while. While it is at 100% utilization, I can not do anything; I just have to wait for it to un-stick itself. It will do this several times in a row -- I can perform one operation (say, changing tabs in a window), then wait a few more seconds, then perform another operation, wait a few more seconds, and so on.
    There are several potential causes:
    1) The indexer. This is especially true for workspaces with many large projects. Try disabling the indexer
    2) Resource Explorer. Resource Explorer will scan the PC for packages (though this is usually only when it is first opened). If Resource Explorer is open, try closing it or having it disconnect from the server.
    3) DVT Disk Usage feature. Try using the workaround mentioned in this post (the workaround should apply to both Windows and Linux)
    ki
  • Hello Viktorija,
    Just following up to see if any of the above suggestions were helpful.
    ki
  • Waiting to hear from customer.
  • Hi Viktorija,
    Since we haven’t heard back from you, we are assuming that the customer was able to move past this issue and/or the suggestions were helpful. If that is not the case, please feel free to post a reply with an update below (or create a new thread). Thanks!
  • Customer implemented your suggestions, and it seems to work better with occasional hiccup.
    Thanks for your help!
    Viktorija
