CCS/AWR1642BOOST: Problem with build in code composer studio
Part Number: AWR1642BOOST
Other Parts Discussed in Thread: AWR1642, SYSBIOS, MATHLIB
Hello! I try to build the lab people count demo in code composer studio 9.1. I use this instructions http://dev.ti.com/tirex/explore/node?a=VLyFKFf__2.5.2&a=AocYeEd__1.2.0&node=AKp3HmPnKfC9wgcoqoqH2A__VLyFKFf__2.5.2&r=VLyFKFf__LATEST&r=AocYeEd__LATEST. I setup mmWave Industrial Toolbox v2.2.0, TI mmWave SDK v1.02.00.05, C6000 Code Generation Tool v7.4.16. I use TI mmWave SDK v1.02.00.05 because only this version works for AWR1642 ES1.0, and only project from mmWave Industrial Toolbox v2.2.0 imports with TI mmWave SDK v1.02.00.05, another versions needs later versions of mmWave SDK. When i try to build it with the C6000 Code Generation Tool v7.4.16 i get some errors which attached in picture.
Please help me to understad what is wrong with it.
And i attached a console output too.
**** Clean-only build of configuration Debug for project pplcount_16xx_dss ****
"C:\\ti\\ccs910\\ccs\\utils\\bin\\gmake" -k -j 4 clean -O
DEL /F "xwr16xx_pplcount_dss.hex" "configPkg\linker.cmd" "configPkg\compiler.opt" "xwr16xx_pplcount_dss.xe674"
DEL /F "RADARDEMO_aoaEstCaponBF.oe674" "RADARDEMO_aoaEstCaponBF_DopplerEst.oe674" "RADARDEMO_aoaEstCaponBF_heatmapEst.oe674" "RADARDEMO_aoaEstCaponBF_matrixInv.oe674" "RADARDEMO_detectionCFAR.oe674" "RADARDEMO_detectionCFAR_priv.oe674" "RADARDEMO_rangeProc.oe674" "RADARDEMO_rangeProc_priv.oe674" "RADARDEMO_rangeProc_utils.oe674" "cycle_measure.oe674" "dss_config_edma_util.oe674" "dss_data_path.oe674" "dss_main.oe674" "radarOsal_malloc.oe674" "radarProcess.oe674"
DEL /F "RADARDEMO_aoaEstCaponBF.d" "RADARDEMO_aoaEstCaponBF_DopplerEst.d" "RADARDEMO_aoaEstCaponBF_heatmapEst.d" "RADARDEMO_aoaEstCaponBF_matrixInv.d" "RADARDEMO_detectionCFAR.d" "RADARDEMO_detectionCFAR_priv.d" "RADARDEMO_rangeProc.d" "RADARDEMO_rangeProc_priv.d" "RADARDEMO_rangeProc_utils.d" "cycle_measure.d" "dss_config_edma_util.d" "dss_data_path.d" "dss_main.d" "radarOsal_malloc.d" "radarProcess.d"
RMDIR /S/Q "configPkg\"
ЌҐ г¤ Ґвбп ­ ©вЁ C:\ti\_ti_proj\pplcount_16xx_dss\Debug\xwr16xx_pplcount_dss.hex
ЌҐ г¤ Ґвбп ­ ©вЁ C:\ti\_ti_proj\pplcount_16xx_dss\Debug\xwr16xx_pplcount_dss.xe674
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project pplcount_16xx_dss ****
"C:\\ti\\ccs910\\ccs\\utils\\bin\\gmake" -k -j 4 all -O
rm -f C:/ti/_ti_proj/pplcount_16xx_dss/xwr16xx_pplcount_dss.bin
makefile:199: recipe for target 'pre-build' failed
process_begin: CreateProcess(NULL, rm -f C:/ti/_ti_proj/pplcount_16xx_dss/xwr16xx_pplcount_dss.bin, ...) failed.
make (e=2): Не удается найти указанный файл.
gmake[1]: [pre-build] Error 2 (ignored)
Building file: "../dss_mmw.cfg"
Invoking: XDCtools
"C:/ti/xdctools_3_50_04_43_core/xs" --xdcpath="C:/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR16XX:false:600 -r release -c "C:/ti/c6000_7.4.16" "../dss_mmw.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring dss_mmw.xe674 from package/cfg/dss_mmw_pe674.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making C:/ti/_ti_proj/pplcount_16xx_dss/src/sysbios/sysbios.ae674 ...
gmake[1]: Entering directory `C:/ti/_ti_proj/pplcount_16xx_dss/src/sysbios'
gmake[1]: Nothing to be done for `all'.
gmake[1]: Leaving directory `C:/ti/_ti_proj/pplcount_16xx_dss/src/sysbios'
Build of libraries done.
cle674 package/cfg/dss_mmw_pe674.c ...
Finished building: "../dss_mmw.cfg"
Building file: "../RADARDEMO_aoaEstCaponBF.c"
Invoking: C6000 Compiler
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_aoaEstCaponBF.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_aoaEstCaponBF.c"
Finished building: "../RADARDEMO_aoaEstCaponBF.c"
Building file: "../RADARDEMO_detectionCFAR.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_detectionCFAR.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_detectionCFAR.c"
Finished building: "../RADARDEMO_detectionCFAR.c"
Building file: "../RADARDEMO_aoaEstCaponBF_DopplerEst.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_aoaEstCaponBF_DopplerEst.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_aoaEstCaponBF_DopplerEst.c"
Finished building: "../RADARDEMO_aoaEstCaponBF_DopplerEst.c"
Building file: "../RADARDEMO_rangeProc.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_rangeProc.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_rangeProc.c"
Finished building: "../RADARDEMO_rangeProc.c"
Building file: "../RADARDEMO_aoaEstCaponBF_matrixInv.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_aoaEstCaponBF_matrixInv.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_aoaEstCaponBF_matrixInv.c"
Finished building: "../RADARDEMO_aoaEstCaponBF_matrixInv.c"
Building file: "../RADARDEMO_rangeProc_utils.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_rangeProc_utils.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_rangeProc_utils.c"
Finished building: "../RADARDEMO_rangeProc_utils.c"
Building file: "../cycle_measure.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="cycle_measure.d_raw" --cmd_file="configPkg/compiler.opt" "../cycle_measure.c"
Finished building: "../cycle_measure.c"
Building file: "../dss_config_edma_util.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_config_edma_util.d_raw" --cmd_file="configPkg/compiler.opt" "../dss_config_edma_util.c"
Finished building: "../dss_config_edma_util.c"
Building file: "../dss_data_path.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_data_path.d_raw" --cmd_file="configPkg/compiler.opt" "../dss_data_path.c"
>> Compilation failure
subdir_rules.mk:9: recipe for target 'dss_data_path.oe674' failed
"..\dss_mmw.h", line 203: error #20: identifier "Mailbox_Handle" is undefined
"../dss_data_path.c", line 1403: error #137: struct "rlAdcBitFormat" has no field "bitFormat"
2 errors detected in the compilation of "../dss_data_path.c".
gmake[1]: *** [dss_data_path.oe674] Error 1
Building file: "../dss_main.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_main.d_raw" --cmd_file="configPkg/compiler.opt" "../dss_main.c"
>> Compilation failure
subdir_rules.mk:9: recipe for target 'dss_main.oe674' failed
"C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/dss/dss_mmw.h", line 203: error #20: identifier "Mailbox_Handle" is undefined
"../dss_main.c", line 543: error #20: identifier "Mailbox_Handle" is undefined
2 errors detected in the compilation of "../dss_main.c".
gmake[1]: *** [dss_main.oe674] Error 1
Building file: "../radarOsal_malloc.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="radarOsal_malloc.d_raw" --cmd_file="configPkg/compiler.opt" "../radarOsal_malloc.c"
Finished building: "../radarOsal_malloc.c"
Building file: "../RADARDEMO_aoaEstCaponBF_heatmapEst.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_aoaEstCaponBF_heatmapEst.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_aoaEstCaponBF_heatmapEst.c"
Finished building: "../RADARDEMO_aoaEstCaponBF_heatmapEst.c"
Building file: "../radarProcess.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="radarProcess.d_raw" --cmd_file="configPkg/compiler.opt" "../radarProcess.c"
Finished building: "../radarProcess.c"
Building file: "../RADARDEMO_rangeProc_priv.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_rangeProc_priv.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_rangeProc_priv.c"
Finished building: "../RADARDEMO_rangeProc_priv.c"
Building file: "../RADARDEMO_detectionCFAR_priv.c"
"C:/ti/c6000_7.4.16/bin/cl6x" -mv6740 --abi=eabi -O3 -ms0 -g --include_path="C:/ti/_ti_proj/pplcount_16xx_dss" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo" --include_path="C:/ti/mmwave_sdk_01_02_00_05/packages" --include_path="C:/ti/mathlib_c674x_3_1_2_1/packages" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft16x16_imre/c64P" --include_path="C:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP" --include_path="C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="C:/ti/mmwave_industrial_toolbox_2_2_0/labs/lab0011-pplcount/lab0011_pplcount_pjt/radarDemo/chains/RadarReceiverPeopleCounting/mmw_PCDemo/gtrack" --include_path="C:/ti/c6000_7.4.16/include" --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="RADARDEMO_detectionCFAR_priv.d_raw" --cmd_file="configPkg/compiler.opt" "../RADARDEMO_detectionCFAR_priv.c"
gmake[1]: Target 'main-build' not remade because of errors.
gmake: *** [all] Error 2
Finished building: "../RADARDEMO_detectionCFAR_priv.c"
makefile:165: recipe for target 'all' failed
  • Hi Ruslan,
    I've asked an expert to look into this and we should have an answer for you later this week.
    Cheers,
    Akash
  • Hi Ruslan,
    Please check that the SDK version CCS is using is the same as the version specified in the Projectspec file for the DSS.  You can check this by
    1. Right click on dss project
    2. Click Properties
    3. Select General
    4. Select Products
    5. Check which SDK is selected.
    In cases where the correct SDK is not installed, CCS will choose the one nearest in version and available on the computer. This can lead to compatibility issues.
    Justin
  • Hi, Justin! I've followed your instructions. Build-errors still here, but it's another now.
    I see that errors "Mailbox_Handle" and "rlAdcBitFormat" have disappeared. I think that means that correct version of SDK is in use( version 1.1 was selected). But now it's .dss project errors. I have the following configuration:
    In the developer's section of the People Counting Demo user's guide, there is a table that lists all prerequisite software.  Please compare the versions against the product versions you have, and make sure all version are correct.
    The build console in CCS gives a better description of the errors, can you send a screenshot of that?
    Justin
  • Hello! All versions are correct. I attached a console output:
    "C:\\ti\\ccs910\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
    Invoking: XDCtools
    "C:/ti/xdctools_3_50_04_43_core/xs" --xdcpath="C:/ti/bios_6_53_02_00/packages;C:/ti/dsplib_c674x_3_4_0_0/packages;C:/ti/dsplib_c64Px_3_4_0_0/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR16XX:false:600 -r release -c "C:/ti/c6000_7.4.16" "../dss_mmw.cfg"
    cle674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/BIOS.c ...
    asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
    asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
    asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
    asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
    asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
    asme674 C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
    are674 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj ti_tls_get_tp.obj c62_TaskSupport_asm.obj ...
    >> Compilation failure
    >> Compilation failure
    and list of errors
    The errors you are showing indicate that the wrong SDK is in use.  Please show a picture of the "products" tab, under Properties->General, with SDK visible.
    Justin
