size of .debug_info section changes for same set of code
Other Parts Discussed in Thread: TMS320C6747
My CCS project and source code are stored in Subversion.  The same project is checked out twice, each time to a different folder on the same PC.  TiMake is used to build the checked-out projects.  Ofd6x is used to process the *.out files to produce text output for comparison.   Comparing the output produced by the ofd6x shows that the size of the .debug_info is different between two builds; the sizes of all other sections are the same between two builds. I like to understand the followings:
1. Does the size of the .debug_info depends on the location of (i.e.: the path to) the source code?
2. What might be the side effects of this size change?
Jeff Lam
Development Environment
Window XP; CCS Platinum; TMS320C6747 Processor
