Part Number: TM4C1231H6PM
Other Parts Discussed in Thread: TM4C1290NCPDT
I had been using Code Sourcery (Codebench) and have moved my sources to CCS (8.3.1.00004). I'm using code that has been running with the prior compiler - unchanged, and it compiles and links fine. When run, it crashes in a certain function (operator initiated). I commented out 1/2 of the code in that function and now the code crashes at startup (the function is never called). So I'm assuming there is something happening in the link/locate phase but I have no idea how to start debugging the problem. Any ideas would be appreciated.
Thank
Doug
