how to get a break down of code size.
Hi
I would like to be able to get a break down of the code usage rom/ram for all the objects in my build. I thought I would be able to do this with the cg_xml tools but I only seam to be able to get a report on the sections.
The information is available from the map file but it is not in a usable format.
Are there any options to the linker that I can use to group the information?
Any suggestions?
Anyone got any scripts that process the map file that they are willing to share?
Cheers
Anyd
  • The cg_xml package also includes some scripts that work on the XML form of the linker map file. These scripts are in the \map directory of the cg_xml installation.  There is no script which does what you describe.  But someone with modest Perl skills could use lib_footprint.pl as a starting point for such a script.
    Thanks and regards,
    -George
