CCS version : 9.2
My typical sequence is launch, group connect and group CPU reset by pressing the reset icon at the group level to reset both cores before loading code, this sequence now requires an additional GUI step compared to previous CCS versions, cannot see the reason why and therefore I am reporting it as a problem. Sequence to recreate below:
Say a previous session had cores grouped. As we know, when you terminate and launch the target, it remembers the grouping and after the launch, it shows the group 1 highlighted as expected. At this point the CPU reset icon hasn't shown up at the Group level [probably not expected to show as I haven't connected yet]. Then I group connect the target, both cores connect. The CPU reset icon at group level still hasn't shown up, even though the Group 1 is still highlighted. Then I move the cursor to Group1 box and click it to select it [and it remains highlighted as before after this step], and the CPU reset icon shows up (also works as expected) and stays until the rest of the session [even if you ungroup and group again]. So there is an additional step here as you can see.
