CCS/IWR1443BOOST: Priyanka.S@GlobalMantrai.com
Part Number: IWR1443BOOST
I cannot able to debug the vitalsigns code in ccs.. As am a new user, Anyone please guide me how to change the logs by using CLI..
  • Former Member
    0 Former Member
    Can you please clarify you are having trouble using the CCS debug mode to step through the vital signs code? Can you tell me what step you are able to get to? What is the issue you are seeing?
    What do you mean by "change the logs by using CLI"?
    Amanda
    In CCS, the vital signs code has been runned properly and I got the line is CLI is operational.. Afterthat, I want to type a command in the console window. Can you share me what is the exact command we can type in console..
  • Former Member
    0 Former Member in reply to priyanka s
    Hello Priyanka,
    What are you trying to debug? You generally do not type anything into the CCS console. You can run the visualizer and vital signs demo as you normally would with the pre-compiled bin (the cfg commands are sent by the online visualizer. While in CCS debug mode you can see the error code if an error occurs in the console window of CCS or set a breakpoint if needed.
    Amanda
