Part Number: AM5728
I am now using C++ for PRU , and come across a problem that , the IMEM(Instruction Memory,12KB) is overwhelming
How should I optimize my code. Here is the map(only the .text part because .text is loaded into IMEM) of my PRU code , any suggestion will be thankful .
I am wondering why vla_alloc.c.obj takes so many room of the IMEM
.text 0 0000001c 00002f68
0000001c 00000770 main.obj (.text:main)
0000078c 00000244 rtspruv3_le.lib : vla_alloc.c.obj (.text:__vla_alloc)
000009d0 00000200 rtrunner.obj (.text:_ZN8Rtrunner13handle_normalEv)
00000bd0 000001dc wdbuf.obj (.text:_ZN5wdbuf12wdbuf_createEPKcj)
00000dac 000001d4 rtspruv3_le.lib : memory.c.obj (.text:realloc)
00000f80 000001bc rtrunner.obj (.text:_ZN8Rtrunner19encode_Write_to_RcsEi)
0000113c 00000168 rtrunner.obj (.text:_ZN8RtrunnerC1Ev)
000012a4 00000154 rtspruv3_le.lib : memory.c.obj (.text:malloc)
000013f8 00000128 uart_comm.obj (.text:_ZN8UARTComm4readEP13BufferFromDSPi)
00001520 00000124 rcs_comm.obj (.text:_ZN7RCSComm4readEP13BufferFromRCS)
00001644 00000120 rtrunner.obj (.text:_ZN8Rtrunner19encode_Write_to_DspEi)
00001764 0000011c rtrunner.obj (.text:_ZN8Rtrunner20generateDspWritebuffEi)
00001880 00000114 rtrunner.obj (.text:_ZN8Rtrunner18generateIniBufToWdEi)
00001994 000000e8 rtrunner.obj (.text:_ZN8Rtrunner16handle_servo_stoEv)
00001a7c 000000e0 rwdevice_wd.obj (.text:_ZN2Wd5writeEPKhRKj)
00001b5c 000000e0 rtrunner.obj (.text:_ZN8Rtrunner18encode_Write_to_WdEv)
00001c3c 000000dc rwdevice_wd.obj (.text:_ZN2Wd4readEPhRKj)
00001d18 000000d8 rtspruv3_le.lib : vla_alloc.c.obj (.text:_Z21free_dead_allocationsPv$33)
00001df0 000000d8 rpmsg_lib.lib : pru_rpmsg.object (.text:pru_rpmsg_send)
00001ec8 000000c4 : pru_rpmsg.object (.text:pru_rpmsg_receive)
00001f8c 000000c0 route_list.obj (.text:_ZN9RouteList5popUpEPhj)
0000204c 000000b8 rtspruv3_le.lib : vla_alloc.c.obj (.text:__vla_dealloc)
00002104 000000b0 rwdevice_rpmsg.obj (.text:_ZN5Rpmsg4initEPv)
000021b4 000000b0 route_list.obj (.text:_ZN9RouteList8pushBackEPKhj)
00002264 000000a8 rtspruv3_le.lib : memory.c.obj (.text:free)
0000230c 000000a0 rwdevice_wd.obj (.text:_ZN2WdD1Ev)
000023ac 00000094 rwdevice_rpmsg.obj (.text:_ZN5Rpmsg4readEPhRKj)
00002440 00000088 route_list.obj (.text:_ZN9RouteList7getDataEPhj)
000024c8 00000070 rwdevice_uart.obj (.text:_ZN4Uart5writeEPKhRKj)
00002538 00000064 rwdevice_rpmsg.obj (.text:_ZN5Rpmsg5writeEPKhRKj)
0000259c 00000060 rtrunner.obj (.text:_ZN8RtrunnerD1Ev)
000025fc 00000060 rpmsg_lib.lib : pru_rpmsg.object (.text:pru_rpmsg_init)
0000265c 00000060 : pru_virtqueue.object (.text:pru_virtqueue_get_avail_buf)
000026bc 00000060 : pru_virtqueue.object (.text:pru_virtqueue_init)
0000271c 0000005c rwdevice_uart.obj (.text:_ZN4Uart4initEPv)
00002778 0000005c rpmsg_lib.lib : pru_rpmsg.object (.text:pru_rpmsg_channel)
000027d4 0000005c : pru_virtqueue.object (.text:pru_virtqueue_add_used_buf)
00002830 00000054 buffer_from_rcs.obj (.text:_ZN13BufferFromRCSC1Ev)
00002884 00000054 crc.obj (.text:_ZN3CRC9crc_ccittEPKhi)
000028d8 00000050 rwdevice_uart.obj (.text:_ZN4Uart4readEPhRKj)
00002928 00000044 pru_list.obj (.text:_ZN7PruList8pushBackEPKhj)
0000296c 00000044 route_list.obj (.text:_ZN9RouteList7freeMemEv)
000029b0 0000003c buffer_to_dsp.obj (.text:_ZN11BufferToDSP7setDataEPKhjjj)
000029ec 0000003c buffer_to_dsp.obj (.text:_ZN11BufferToDSPD1Ev)
00002a28 0000003c buffer_to_rcs.obj (.text:_ZN11BufferToRCS7setDataEPKhjjj)
00002a64 0000003c buffer_to_rcs.obj (.text:_ZN11BufferToRCSD1Ev)
00002aa0 0000003c buffer_from_dsp.obj (.text:_ZN13BufferFromDSPD1Ev)
00002adc 0000003c buffer_from_rcs.obj (.text:_ZN13BufferFromRCSD1Ev)
00002b18 00000038 rwdevice_wd.obj (.text:_ZN2Wd4initEPv)
00002b50 00000038 buffer_to_rcs.obj (.text:_ZN9RWBufBase10updateDataEPKhj)
00002b88 00000034 buffer_to_dsp.obj (.text:_ZN11BufferToDSPC1Ev)
00002bbc 00000034 buffer_to_rcs.obj (.text:_ZN11BufferToRCSC1Ev)
00002bf0 00000034 buffer_from_dsp.obj (.text:_ZN13BufferFromDSPC1Ev)
00002c24 00000034 rtspruv3_le.lib : memcpy.asm.obj (.text)
00002c58 00000030 pru_counter_operation.obj (.text:_Z19restart_pru_counterv)
00002c88 00000028 rcs_comm.obj (.text:_ZN7RCSCommC1Ev)
00002cb0 00000028 route_list.obj (.text:_ZN9RouteListC1Ev)
00002cd8 00000028 route_list.obj (.text:_ZN9RouteListD1Ev)
00002d00 00000028 rpmsg_lib.lib : pru_virtqueue.object (.text:pru_virtqueue_kick)
00002d28 00000024 buffer_to_dsp.obj (.text:_ZN11BufferToDSP11setRoutePosEPKhj)
00002d4c 00000024 buffer_to_dsp.obj (.text:_ZN11BufferToDSP14setControlFlagEPKhj)
00002d70 00000024 rtspruv3_le.lib : mpyi.c.obj (.text:__pruabi_mpyi)
00002d94 00000020 wdbuf.obj (.text:_Z6strcpyPcPKc$24)
00002db4 00000020 rwdevice_wd.obj (.text:_ZN2WdC1Ev)
00002dd4 00000020 rtspruv3_le.lib : new.c.obj (.text:_Znwj)
00002df4 0000001c pru_list.obj (.text:_ZN7PruListC1Ev)
00002e10 00000018 rtspruv3_le.lib : typeinfo.c.obj (.text:_ZN10__cxxabiv117__class_type_infoD0Ev)
00002e28 00000018 : typeinfo.c.obj (.text:_ZN10__cxxabiv120__si_class_type_infoD0Ev)
00002e40 00000018 rwdevice_uart.obj (.text:_ZN4UartC1Ev)
00002e58 00000018 uart_comm.obj (.text:_ZN8UARTCommC1Ev)
00002e70 00000018 prulogger.obj (.text:_ZN9PruloggerC1Ev)
00002e88 00000018 rtspruv3_le.lib : error.c.obj (.text:__abort_execution)
00002ea0 00000018 : memset.c.obj (.text:memset)
00002eb8 00000014 prulogger.obj (.text:_ZN9PruloggerD1Ev)
00002ecc 00000010 pru_counter_operation.obj (.text:_Z21get_pru_counter_valuev)
00002edc 00000010 buffer_from_rcs.obj (.text:_ZN13BufferFromRCS14getControlFlagEv)
00002eec 00000010 buffer_from_rcs.obj (.text:_ZN13BufferFromRCS5getIDEv)
00002efc 00000010 buffer_from_rcs.obj (.text:_ZN13BufferFromRCS8getParamEv)
00002f0c 00000010 rtspruv3_le.lib : delete.c.obj (.text:_ZdlPv)
00002f1c 0000000c buffer_from_dsp.obj (.text:_ZN13BufferFromDSP12getTimestampEv)
00002f28 0000000c buffer_from_dsp.obj (.text:_ZN13BufferFromDSP13getServoBrakeEv)
00002f34 0000000c buffer_from_dsp.obj (.text:_ZN13BufferFromDSP6getAckEv)
00002f40 0000000c buffer_from_dsp.obj (.text:_ZN13BufferFromDSP6getPosEv)
00002f4c 00000008 rtrunner.obj (.text:_ZN8Rtrunner7getdiffEhh)
00002f54 00000008 rtrunner.obj (.text:_ZN9RWBufBase10getDataPtrEv)
00002f5c 00000008 buffer_to_rcs.obj (.text:_ZN9RWBufBase13getDataLengthEv)
00002f64 00000008 route_list.obj (.text:_ZN9RouteList11getRouteLenEv)
00002f6c 00000008 rtspruv3_le.lib : exit.c.obj (.text:abort)
00002f74 00000008 : exit.c.obj (.text:loader_exit)
00002f7c 00000004 : typeinfo.c.obj (.text:_ZN10__cxxabiv117__class_type_infoD1Ev)
00002f80 00000004 : typeinfo.c.obj (.text:_ZN10__cxxabiv120__si_class_type_infoD1Ev)
