Part Number: UCD3138PFCEVM-026
we want to modify (i_target_offset) by memory debugger, which register does( i_target_offset)refer to?
thanks.
thanks.
i_target_offset is a variable, not a register, just modify i_target_offset directly
It sounds like you may not know how to use the memory debugger to look at variables. If you look at the PFC code, you will see a directory just below the main code directory where the source code is with a device name. If you look at the memory debugger on the upper left corner, you will see the word "File" if you click on that, you can select the directory I mentioned, and the memory debugger will use it to get the variables, so that you can examine the variables directly.
I would suggest that you do the video training that TI provides on the web. It will help with with lots of the things you are asking questions about:
https://training.ti.com/jp/ucd3138-digital-power-training-series
