Other Parts Discussed in Thread: LAUNCHXL-CC1352R1
art Number: LAUNCHXL-CC1352R1
Hi Everyone,
I am having an issue with my script where in I start with an empty TI RTOS project. My goal is to run a basic Task that has a function pointer but in my script I wasn't able to make it work. Though there are no compile issues.
All codes below this line doesn't work.
task0 = Task_create((Task_FuncPtr) ledController, &taskParams, NULL);
Here is the full script of project.
* Copyright (c) 2015-2019, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== empty.c ========
/* For usleep() */
#include <unistd.h>
#include <stdint.h>
#include <stddef.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
/* Driver Header files */
#include <ti/drivers/GPIO.h>
// #include <ti/drivers/I2C.h>
// #include <ti/drivers/SPI.h>
// #include <ti/drivers/UART.h>
// #include <ti/drivers/Watchdog.h>
/* Driver configuration */
#include "ti_drivers_config.h"
#define STACKSIZE 512
UART_Handle uart;
char echoPrompt[] = "ERROR";
static void ledController(UArg arg0, UArg arg1)
while (1)
GPIO_toggle(CONFIG_GPIO_LED_0);
Task_sleep(50);
* ======== mainThread ========
void *mainThread(void *arg0)
UART_Params uartParams;
Task_Params taskParams;
Task_Handle task0;
GPIO_init();
UART_init();
UART_Params_init(&uartParams);
uartParams.writeDataMode = UART_DATA_BINARY;
uartParams.readDataMode = UART_DATA_BINARY;
uartParams.readReturnMode = UART_RETURN_FULL;
uartParams.readEcho = UART_ECHO_OFF;
uartParams.baudRate = 115200;
uart = UART_open(CONFIG_UART_0, &uartParams);
GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
Task_Params_init(&taskParams);
taskParams.stackSize = 255;
taskParams.priority = 15;
if(task0==NULL)
UART_write(uart, echoPrompt, sizeof(echoPrompt));
return (NULL);
and in my ROV View it says
Any help would be greatly appreciated.
Thank you and regards,
Jonathan
