Part Number: CC1352R
Other Parts Discussed in Thread: ENERGYTRACE
When I try to start a standalone EnergyTrace session from CCS 9.3.0.00012, nothing happens after the initial dialog box. EnergyTrace during a debug session works as expected. I'm using the CC1352R LaunchPad and my development machine is running Mac OSX 10.15.3 (however, the issue exists in Windows as well). In the workspace logs, I found the following unhandled exception:
!ENTRY org.eclipse.ui 4 0 2020-02-13 15:42:40.247
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
at com.ti.dvt.energytrace.views.DSManager$DSDialog.createDialogArea(DSManager.java:519)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:768)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at org.eclipse.jface.window.Window.open(Window.java:783)
at com.ti.dvt.energytrace.views.DSManager$DSDialog.open(DSManager.java:612)
at com.ti.dvt.energytrace.IDEHandler.launchHiddenDS(IDEHandler.java:440)
at com.ti.dvt.energytrace.IDEHandler.preNonDebugStartup(IDEHandler.java:224)
at com.ti.dvt.energytrace.IDEHandler.startupDashboard(IDEHandler.java:490)
at com.ti.dvt.energytrace.actions.DashboardAction.runET(DashboardAction.java:102)
at com.ti.dvt.energytrace.actions.DashboardAction.run(DashboardAction.java:55)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:247)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:219)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:436)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4247)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1508)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1531)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1516)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1320)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4091)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3712)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
