Hi CCS team,
Currently started using CCS dark mode, very cool looking.
My habit is for different devices, for every version of SDKs, and for different wireless protocols, or drivers, I create different workspaces for them, easy for me to itemize and manage.
The problem is I changed one of my workspaces in CCS to dark mode, but when I open other workspaces, they still use default theme, seems I have to change every of my workspaces manually if I want to apply the dark mode to all my workspaces.
Any solutions for this?
Thanks!
Yan,
These sort of settings are stored in the workspace itself and not shared. One thing you can do is when creating a new workspace you can copy settings from your current workspace. This will copy all the dark theme settings.
The other thing you can do is export your preferences from one workspace and then import into another. If you go to File Export you can access that here.
Note when doing this leave the box check that says all. If you instead check the 3 individual categories it won't export the theme settings and just those 3 categories.
Then in the other workspace you go to File -> Import and select the file that you just created.
John
