CCS: "Failed to create the part's controls" at startup, and on View > Resource Explorer, Getting Started, CCS App Center.. etc.
For reference, this is on a Linux OS, via VM with MacOS host.
Upon launch, the CCS Welcome window just displays the red error symbol, and says :
This occurs immediately at startup, but also when i select any of the following from the View drop down menu:
Resource Explorer
Resource Explorer Offline
Getting Started
CCS App Center
The "<<Details" log provides this info:
java.lang.NullPointerException
at com.teamdev.jxbrowser.chromium.swing.BrowserView.<init>(SourceFile:61)
at com.ti.chromium.browser.JxBrowser.<init>(JxBrowser.java:298)
at com.ti.chromium.browser.ChromiumBrowserContributor.createBrowser(ChromiumBrowserContributor.java:40)
at com.ti.browser.internal.TIBrowser.<init>(TIBrowser.java:95)
at com.ti.browser.TIBrowserFactory.createBrowser(TIBrowserFactory.java:81)
at com.ti.ccstudio.app.center.internal.browser.AppCenterBrowser.createPartControl(AppCenterBrowser.java:162)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:153)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:99)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:364)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1005)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:970)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:137)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:412)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:331)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:190)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:1012)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:672)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:778)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:749)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:743)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:727)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:104)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5831)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:212)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:196)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:174)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:634)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:598)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:788)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1235)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3277)
at org.eclipse.ui.internal.WorkbenchPage.access$26(WorkbenchPage.java:3192)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3174)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:71)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3169)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3133)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3114)
at com.ti.ccstudio.app.center.internal.OpenAppCenterLiveAction.openAppCenter(OpenAppCenterLiveAction.java:63)
at com.ti.ccstudio.app.center.internal.AppCenterHandler.execute(AppCenterHandler.java:32)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:291)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:93)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:318)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:252)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:161)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:204)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:433)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:446)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:472)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5686)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1370)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4940)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4518)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
  • Hi Jonathan,
    Have you see the FAQ in the link below?
    https://e2e.ti.com/support/tools/ccs/f/81/t/880244
    ki
  • Yes, I have looked into this.
    Following that thread, i still have the same error.
    The terminal output:
    Gtk-Message: 16:26:42.179: Failed to load module "canberra-gtk-module"
    JxBrowser - init()
    04:26:55 SEVERE: There are next missing dependencies:
    browsercore64 => libgconf-2.so.4
    libbrowsercore64.so => libgconf-2.so.4
    04:26:55 SEVERE: Failed to start IPC process.
    java.lang.IllegalStateException: Missing dependendecies have been detected. Check the log for details.
    at com.teamdev.jxbrowser.chromium.internal.ipc.ExternalChromiumProcessLinux.preProcessRun(SourceFile:3150)
    at com.teamdev.jxbrowser.chromium.internal.ipc.ExternalChromiumProcess.doStart(SourceFile:62)
    at com.teamdev.jxbrowser.chromium.internal.ipc.ChromiumProcess.start(SourceFile:235)
    at com.teamdev.jxbrowser.chromium.internal.ipc.d.run(SourceFile:193)
    at java.lang.Thread.run(Thread.java:745)
    com.teamdev.jxbrowser.chromium.internal.ipc.IPCException: Failed to start IPC process.
    at com.teamdev.jxbrowser.chromium.internal.ipc.d.run(SourceFile:200)
    Caused by: java.lang.IllegalStateException: Missing dependendecies have been detected. Check the log for details.
    ... 1 more
    2020-03-11 16:26:59.630:INFO::Worker-2: Workbench early startup: Logging initialized @17436ms to org.eclipse.jetty.util.log.StdErrLog
    2020-03-11 16:26:59.905:INFO:oejs.Server:Worker-2: Workbench early startup: jetty-9.4.10.v20180503; built: 2018-05-03T15:56:21.710Z; git: daa59876e6f384329b122929e70a80934569428c; jvm 1.8.0_112-b15
    2020-03-11 16:27:00.097:INFO:oejs.AbstractConnector:Worker-2: Workbench early startup: Started ServerConnector@486fe567{HTTP/1.1,[http/1.1]}{127.0.0.1:41197}
    2020-03-11 16:27:00.098:INFO:oejs.Server:Worker-2: Workbench early startup: Started @17904ms
    CCS HTTP adapter started! [ccs.port:41197] - Open 'http://localhost:41197/ide' in web browser to see listing of available APIs...
  • Can you try clearing out the jxbrowser cache? Try both steps below:
    https://software-dl.ti.com/ccs/esd/documents/users_guide/ccs_troubleshooting.html#clear-the-ccs-browser-cache
    - delete the following folder: ./ccs/eclipse/configuration/.jxbrowser-chromium-lib
    ki
