Other Parts Discussed in Thread: CCSTUDIO, CODECOMPOSER
Hi all,
I have a problem with ccs 3.3.
everything was running ok until last monday, but now each time that I try to open the cpu registers window (an sporadically also the watch window) I get the following error
After few clicks on "continue" the error disappears, but the register window is unusable.
The details of the error are copied below.
Anybody has any idea on how to solve this problem?
Thanks!
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
at RegisterWindow.AppSetting.WriteSetting(String Section, String Setting, String Value)
at RegisterWindow.RegisterWindowUserCtrl.RegisterWindowUserCtrl_HandleDestroyed(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnHandleDestroyed(EventArgs e)
at System.Windows.Forms.Control.WmDestroy(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assembly caricati **************
mscorlib
Versione assembly: 1.0.5000.0
Versione Win32: 1.1.4322.2470
Base di codice: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
DummyDotNET
Versione assembly: 1.0.3173.42239
Versione Win32: 5.98.0.393
Base di codice: file:///C:/CCStudio_v3.3/cc/bin/DummyDotNET.DLL
Syncfusion.Grid.Windows
Versione assembly: 3.0.1.0
Versione Win32: 3.0.1.0
Base di codice: file:///c:/windows/assembly/gac/syncfusion.grid.windows/3.0.1.0__3d67ed1f87d44c89/syncfusion.grid.windows.dll
Syncfusion.Shared.Base
Base di codice: file:///c:/windows/assembly/gac/syncfusion.shared.base/3.0.1.0__3d67ed1f87d44c89/syncfusion.shared.base.dll
Versione Win32: 1.1.4322.2032
Base di codice: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
Base di codice: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
Syncfusion.Core
Base di codice: file:///c:/windows/assembly/gac/syncfusion.core/3.0.1.0__632609b4d040f6b4/syncfusion.core.dll
System.Drawing
Base di codice: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Syncfusion.Tools.Windows
Base di codice: file:///c:/windows/assembly/gac/syncfusion.tools.windows/3.0.1.0__3d67ed1f87d44c89/syncfusion.tools.windows.dll
System.Xml
Base di codice: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
CcsMemoryServerProxy
Versione assembly: 1.0.3260.1131
Versione Win32: 5.98.0.404
Base di codice: file:///C:/CCStudio_v3.3/cc/bin/CcsMemoryServerProxy.DLL
CcsMemoryServerCOMInterface
Versione assembly: 1.0.3260.1099
Base di codice: file:///C:/CCStudio_v3.3/cc/bin/CcsMemoryServerCOMInterface.DLL
CcsMemoryServer
Versione assembly: 1.0.3260.1107
Base di codice: file:///C:/CCStudio_v3.3/cc/bin/CcsMemoryServer.DLL
interop.CodeComposer
Versione assembly: 1.50.0.0
Versione Win32: 1.50.0.0
Base di codice: file:///C:/CCStudio_v3.3/cc/bin/interop.CodeComposer.DLL
CcsEventLog
Versione assembly: 1.0.3260.1100
Base di codice: file:///C:/CCStudio_v3.3/cc/bin/CcsEventLog.DLL
CcsPropertyControl
Versione assembly: 1.0.3260.1093
Base di codice: file:///C:/CCStudio_v3.3/cc/bin/CcsPropertyControl.DLL
mscorlib.resources
Versione Win32: 1.1.4322.573
Base di codice: file:///c:/windows/assembly/gac/mscorlib.resources/1.0.5000.0_it_b77a5c561934e089/mscorlib.resources.dll
Versione assembly: 3.0.1.1
Versione Win32: 3.0.1.1
Base di codice: file:///c:/windows/assembly/gac/syncfusion.grid.windows/3.0.1.1__036fe6034c821ea4/syncfusion.grid.windows.dll
PropertyPageEditor
Versione assembly: 1.0.3260.1094
Base di codice: file:///C:/CCSTUD~1.3/plugins/Joule/PROPER~1/PropertyPageEditor.dll
Base di codice: file:///c:/windows/assembly/gac/syncfusion.tools.windows/3.0.1.1__036fe6034c821ea4/syncfusion.tools.windows.dll
System.Drawing.resources
Base di codice: file:///c:/windows/assembly/gac/system.drawing.resources/1.0.5000.0_it_b03f5f7f11d50a3a/system.drawing.resources.dll
Versione assembly: 1.0.3260.1124
Base di codice: file:///C:/CCSTUD~1.3/plugins/Joule/REGIST~1/RegisterWindowUserCtrl.dll
CCSRegAdaptor
Versione assembly: 1.0.3260.1117
Base di codice: file:///C:/CCSTUD~1.3/plugins/Joule/REGIST~1/CCSRegAdaptor.DLL
Interop.REGISTERWINDOWLib
Versione assembly: 1.0.0.0
Versione Win32: 1.0.0.0
Base di codice: file:///C:/CCSTUD~1.3/plugins/Joule/REGIST~1/Interop.REGISTERWINDOWLib.DLL
Syncfusion.Grid.Base
Base di codice: file:///c:/windows/assembly/gac/syncfusion.grid.base/3.0.1.0__3d67ed1f87d44c89/syncfusion.grid.base.dll
Syncfusion.Shared.Windows
Base di codice: file:///c:/windows/assembly/gac/syncfusion.shared.windows/3.0.1.0__3d67ed1f87d44c89/syncfusion.shared.windows.dll
System.XML.resources
Base di codice: file:///c:/windows/assembly/gac/system.xml.resources/1.0.5000.0_it_b77a5c561934e089/system.xml.resources.dll
SYSTEM.WINDOWS.FORMS.resources
Base di codice: file:///c:/windows/assembly/gac/system.windows.forms.resources/1.0.5000.0_it_b77a5c561934e089/system.windows.forms.resources.dll
************** Debug JIT **************
Per attivare il debug JIT (Just-In-Time), è necessario impostare il valore
jitDebugging nella sezione system.windows.forms del file di configurazione
dell'applicazione o del computer (machine.config).
L'applicazione inoltre deve essere compilata con il debug
attivato.
Ad esempio:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Quando il debug JIT è attivato, tutte le eccezioni non gestite
vengono inviate al debugger JIT registrato nel computer,
anziché essere gestite da questa finestra di dialogo.
