I AM NEW AT USING CCS AND USING CCS5.1& CCS6.2, BUT USING THE INBUILT PROGRAMS TO GENERATE PWM, SO I HAVE ALREADY ENTERED ALL THE SOURCE FILES REQUIRED.
AND STILL THE PROBLEM ARISES STATING :- ERROR: PROGRAM "MAKE" IS NOT FOUND IN PATH.
EARLIER FACED WITH FEW PROBLEMS BUT RESOLVED ALL AND YET THIS PROBLEM ARISES IN CONSOLE. HENCEE COULD NOT MOVE FURTHER TO DEBUGGING.
PLEASE HELP ME.
THIS IS THE TEXT FROM CONSOLE:
**** Build of configuration Debug for project epwm_updown_aq ****
make all
make all
Cannot run program "make": Launching failed
Error: Program "make" not found in PATH
PATH=[C:\ti\ccsv5\ccs_base\emulation\analysis\bin\..\..\..\common\bin;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\..\..\..\DebugServer\bin;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\ofs;C:\ti\ccsv5\ccs_base\common\bin;C:\ti\ccsv5\ccs_base\common\uscif;C:\ti\ccsv5\ccs_base\DebugServer\license;C:/ti/ccsv5/eclipse/jre/bin/client;C:/ti/ccsv5/eclipse/jre/bin;C:/ti/ccsv5/eclipse/jre/lib/i386;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\ti\ccsv5\eclipse;;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\.;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/aet_config;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/trace_config/setup;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../xmldb/trace_config/devices;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../../../common/bin;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../../../common/uscif;C:\ti\ccsv5\ccs_base\emulation\analysis\bin\../../tpi;C:\ti\ccsv5\ccs_base\emulation\drivers]
Error: Program "make" is not found in PATH
**** Build Finished ****
