* Copyright (c) 2012-2015, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* SECTION MAPPING */
var program = xdc.useModule('xdc.cfg.Program');
program.sectMap[".args"] = new Program.SectionSpec();
program.sectMap[".bss"] = new Program.SectionSpec();
program.sectMap[".cinit"] = new Program.SectionSpec();
program.sectMap[".cio"] = new Program.SectionSpec();
program.sectMap[".const"] = new Program.SectionSpec();
program.sectMap[".data"] = new Program.SectionSpec();
program.sectMap[".far"] = new Program.SectionSpec();
program.sectMap[".fardata"] = new Program.SectionSpec();
program.sectMap[".neardata"] = new Program.SectionSpec();
program.sectMap[".rodata"] = new Program.SectionSpec();
program.sectMap[".stack"] = new Program.SectionSpec();
program.sectMap[".switch"] = new Program.SectionSpec();
program.sectMap[".sysmem"] = new Program.SectionSpec();
program.sectMap[".text"] = new Program.SectionSpec();
// Must place these sections in core local memory
program.sectMap[".args"].loadSegment = "L2SRAM";
program.sectMap[".cio"].loadSegment = "L2SRAM";
// Variables in the following data sections can potentially be 'shared' in
// OpenMP. These sections must be placed in shared memory.
program.sectMap[".bss"].loadSegment = "DDR3";
program.sectMap[".cinit"].loadSegment = "DDR3";
program.sectMap[".const"].loadSegment = "DDR3";
program.sectMap[".data"].loadSegment = "DDR3";
program.sectMap[".far"].loadSegment = "DDR3";
program.sectMap[".fardata"].loadSegment = "DDR3";
program.sectMap[".neardata"].loadSegment = "DDR3";
program.sectMap[".rodata"].loadSegment = "DDR3";
program.sectMap[".sysmem"].loadSegment = "DDR3";
// Code sections shared by cores - place in shared memory to avoid duplication
program.sectMap[".switch"].loadSegment = program.platform.codeMemory;
program.sectMap[".text"].loadSegment = program.platform.codeMemory;
// Size the default stack and place it in L2SRAM
var deviceName = String(Program.cpu.deviceName);
if (deviceName.search("DRA7XX") == -1) { program.stack = 0x20000; }
else { program.stack = 0x8000; }
program.sectMap[".stack"].loadSegment = "L2SRAM";
// Since there are no arguments passed to main, set .args size to 0
program.argSize = 0;
/* OPENMP RUNTIME CONFIGURATION */
// Include OMP runtime in the build
var ompSettings = xdc.useModule("ti.runtime.openmp.Settings");
// Set to true if the application uses or has dependencies on BIOS components
ompSettings.usingRtsc = true;
if (ompSettings.usingRtsc)
/* Configure OpenMP for BIOS
* - OpenMP.configureCores(masterCoreId, numberofCoresInRuntime)
* Configures the id of the master core and the number of cores
* available to the runtime.
var OpenMP = xdc.useModule('ti.runtime.ompbios.OpenMP');
// Configure the index of the master core and the number of cores available
// to the runtime. The cores are contiguous.
OpenMP.masterCoreIdx = 0;
// Setup number of cores based on the device
if (deviceName.search("DRA7XX") != -1) { OpenMP.numCores = 2; }
else if (deviceName.search("6670") != -1) { OpenMP.numCores = 4; }
else if (deviceName.search("6657") != -1) { OpenMP.numCores = 2; }
else if (deviceName.search("K2L") != -1) { OpenMP.numCores = 4; }
else { OpenMP.numCores = 8; }
// Pull in memory ranges described in Platform.xdc to configure the runtime
var ddr3 = Program.cpu.memoryMap["DDR3"];
var ddr3_nc = Program.cpu.memoryMap["DDR3_NC"];
var msmc = Program.cpu.memoryMap["MSMCSRAM"];
var msmcNcVirt = Program.cpu.memoryMap["OMP_MSMC_NC_VIRT"];
var msmcNcPhy = Program.cpu.memoryMap["OMP_MSMC_NC_PHY"];
// Initialize the runtime with memory range information
OpenMP.msmcBase = msmc.base
OpenMP.msmcSize = msmc.len;
OpenMP.msmcNoCacheVirtualBase = msmcNcVirt.base;
OpenMP.msmcNoCacheVirtualSize = msmcNcVirt.len;
OpenMP.msmcNoCachePhysicalBase = msmcNcPhy.base;
else
OpenMP.allocateStackFromHeap = true;
OpenMP.allocateStackFromHeapSize = 0x010000;
OpenMP.hasMsmc = false;
OpenMP.ddrNoCacheBase = ddr3_nc.base;
OpenMP.ddrNoCacheSize = ddr3_nc.len;
OpenMP.ddrBase = ddr3.base;
OpenMP.ddrSize = ddr3.len;
// Configure memory allocation using HeapOMP
// HeapOMP handles
// - Memory allocation requests from BIOS components (core local memory)
// - Shared memory allocation by utilizing the IPC module to enable
// multiple cores to allocate memory out of the same heap - used by malloc
var HeapOMP = xdc.useModule('ti.runtime.ompbios.HeapOMP');
// Shared Region 0 must be initialized for IPC
var sharedRegionId = 0;
// Size of the core local heap
var localHeapSize = 0x8000;
// Size of the heap shared by all the cores
var sharedHeapSize = 0x08000000;
// Initialize a Shared Region & create a heap in the DDR3 memory region
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.setEntryMeta( sharedRegionId,
{ base: ddr3.base,
len: sharedHeapSize,
ownerProcId: OpenMP.masterCoreIdx,
cacheEnable: true,
createHeap: true,
isValid: true,
// Configure and setup HeapOMP
HeapOMP.configure(sharedRegionId, localHeapSize);
else
OpenMP.useIpcSharedHeap = false;
OpenMP.allocateLocalHeapSize = 0x8000
OpenMP.allocateSharedHeapSize = 0x00800000
var Startup = xdc.useModule('xdc.runtime.Startup');
Startup.lastFxns.$add('&__TI_omp_initialize_rtsc_mode');
else
/* Size the heap. It must be placed in shared memory */
program.heap = sharedHeapSize;
One thing, is that if I change the shared heap size, the start address for other stuff in the DDR3 segment don't change ...
