CCS/CC1352P: High power consumption after migration to simplelink SDK 4.10.0.78
Part Number: CC1352P
Working on custom board based on CC1352P.
Migrated from simple link SDK 3.40.0.02 to 4.10.0.78.
Before migration, power consumption on idle was ~200uA.
After migrating to SDK v4.10.0.78, power consumption on idle is 60mA.
Migrating to new SDK is the only change.
EnablePolicy is checked ( Attached syscfg).
 * These arguments were used when this file was generated. They will be automatically applied on subsequent loads
 * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
 * @cliArgs --device "CC1352P1F3RGZ" --package "RGZ" --part "Default" --product "simplelink_cc13x2_26x2_sdk@4.10.00.78"
 * @versions {"data":"2020021217","timestamp":"2020021217","tool":"1.4.0+1234","templates":"2020021217"}
 * Import the modules used in this configuration.
const GPIO        = scripting.addModule("/ti/drivers/GPIO", {}, false);
const GPIO1       = GPIO.addInstance();
const GPIO2       = GPIO.addInstance();
const GPIO3       = GPIO.addInstance();
const GPIO4       = GPIO.addInstance();
const GPIO5       = GPIO.addInstance();
const GPIO6       = GPIO.addInstance();
const GPIO7       = GPIO.addInstance();
const GPIO8       = GPIO.addInstance();
const GPIO9       = GPIO.addInstance();
const GPIO10      = GPIO.addInstance();
const GPIO11      = GPIO.addInstance();
const GPIO12      = GPIO.addInstance();
const GPIO13      = GPIO.addInstance();
const I2C         = scripting.addModule("/ti/drivers/I2C", {}, false);
const I2C1        = I2C.addInstance();
const NVS         = scripting.addModule("/ti/drivers/NVS", {}, false);
const NVS1        = NVS.addInstance();
const RTOS        = scripting.addModule("/ti/drivers/RTOS");
const TRNG        = scripting.addModule("/ti/drivers/TRNG", {}, false);
const TRNG1       = TRNG.addInstance();
const Temperature = scripting.addModule("/ti/drivers/Temperature");
const Timer       = scripting.addModule("/ti/drivers/Timer", {}, false);
const Timer1      = Timer.addInstance();
const UART        = scripting.addModule("/ti/drivers/UART", {}, false);
const UART1       = UART.addInstance();
const UART2       = UART.addInstance();
const easylink    = scripting.addModule("/ti/easylink/easylink");
 * Write custom configuration values to the imported modules.
GPIO1.$name             = "CONFIG_GPIO_BTN1";
GPIO1.interruptTrigger  = "Rising Edge";
GPIO1.gpioPin.$assign   = "DIO_27";
GPIO1.pinInstance.$name = "CONFIG_PIN_0";
GPIO2.$name             = "CONFIG_GPIO_INT_ACC";
GPIO2.interruptTrigger  = "Both Edges";
GPIO2.gpioPin.$assign   = "DIO_8";
GPIO2.pinInstance.$name = "CONFIG_PIN_1";
GPIO3.$name             = "CONFIG_GPIO_INT_AL";
GPIO3.interruptTrigger  = "Falling Edge";
GPIO3.gpioPin.$assign   = "DIO_9";
GPIO3.pinInstance.$name = "CONFIG_PIN_2";
GPIO4.$name             = "CONFIG_GPIO_INT_VOX";
GPIO4.interruptTrigger  = "Both Edges";
GPIO4.gpioPin.$assign   = "DIO_10";
GPIO4.pinInstance.$name = "CONFIG_PIN_3";
GPIO5.$name             = "CONFIG_GPIO_INT_EXPANDER";
GPIO5.interruptTrigger  = "Both Edges";
GPIO5.gpioPin.$assign   = "DIO_18";
GPIO5.pinInstance.$name = "CONFIG_PIN_4";
GPIO6.$name             = "CONFIG_GPIO_FS_VBUS";
GPIO6.interruptTrigger  = "Both Edges";
GPIO6.gpioPin.$assign   = "DIO_26";
GPIO6.pinInstance.$name = "CONFIG_PIN_5";
GPIO7.$name             = "CONFIG_GPIO_SENS_IN_BF";
GPIO7.interruptTrigger  = "Rising Edge";
GPIO7.gpioPin.$assign   = "DIO_22";
GPIO7.pinInstance.$name = "CONFIG_PIN_6";
GPIO8.$name             = "CONFIG_GPIO_SENS_IN_BF2";
GPIO8.interruptTrigger  = "Falling Edge";
GPIO8.gpioPin.$assign   = "DIO_15";
GPIO8.pinInstance.$name = "CONFIG_PIN_7";
GPIO9.$name             = "CONFIG_GPIO_INT_TILT";
GPIO9.interruptTrigger  = "Falling Edge";
GPIO9.gpioPin.$assign   = "DIO_14";
GPIO9.pinInstance.$name = "CONFIG_PIN_8";
GPIO10.$name             = "CONFIG_GPIO_INT_RTC";
GPIO10.interruptTrigger  = "Falling Edge";
GPIO10.pull              = "Pull Up";
GPIO10.gpioPin.$assign   = "DIO_25";
GPIO10.pinInstance.$name = "CONFIG_PIN_9";
GPIO11.$name             = "CONFIG_GPIO_BAT_OFF";
GPIO11.mode              = "Output";
GPIO11.outputStrength    = "High";
GPIO11.gpioPin.$assign   = "DIO_23";
GPIO11.pinInstance.$name = "CONFIG_PIN_10";
GPIO12.$name             = "CONFIG_GPIO_VEXT_EN";
GPIO12.mode              = "Output";
GPIO12.gpioPin.$assign   = "DIO_20";
GPIO12.pinInstance.$name = "CONFIG_PIN_11";
GPIO13.$name             = "CONFIG_GPIO_CEL_PWRON";
GPIO13.mode              = "Output";
GPIO13.gpioPin.$assign   = "DIO_11";
GPIO13.pinInstance.$name = "CONFIG_PIN_12";
I2C1.$name                = "CONFIG_I2C_0";
I2C1.i2c.$name            = "MyI2C1";
I2C1.i2c.$assign          = "I2C0";
I2C1.i2c.sdaPin.$assign   = "DIO_5";
I2C1.i2c.sclPin.$assign   = "DIO_21";
I2C1.sdaPinInstance.$name = "CONFIG_PIN_13";
I2C1.clkPinInstance.$name = "CONFIG_PIN_14";
NVS1.$name                    = "CONFIG_NVS_0";
NVS1.internalFlash.$name      = "ti_drivers_nvs_NVSCC26XX0";
NVS1.internalFlash.regionBase = 0x48000;
NVS1.internalFlash.regionSize = 0x8000;
const CCFG              = scripting.addModule("/ti/devices/CCFG", {}, false);
CCFG.enableBootloader   = true;
CCFG.ccfgTemplate.$name = "ti_devices_CCFGTemplate0";
TRNG1.$name = "CONFIG_TRNG_0";
Timer1.$name                     = "CONFIG_TIMER_0";
Timer1.timerInstance.$name       = "CONFIG_GPTIMER_0";
Timer1.timerInstance.timer.$name = "MyGPTM1";
UART1.$name               = "CONFIG_UART_0";
UART1.uart.$name          = "MyUART1";
UART1.uart.txPin.$assign  = "DIO_13";
UART1.uart.rxPin.$assign  = "DIO_12";
UART1.txPinInstance.$name = "CONFIG_PIN_15";
UART1.rxPinInstance.$name = "CONFIG_PIN_16";
UART2.$name                = "CONFIG_UART_1";
UART2.flowControl          = true;
UART2.txPinInstance.$name  = "CONFIG_PIN_17";
UART2.rxPinInstance.$name  = "CONFIG_PIN_18";
UART2.uart.$name           = "MyUART1";
UART2.uart.$assign         = "UART1";
UART2.uart.txPin.$assign   = "DIO_24";
UART2.uart.rxPin.$assign   = "DIO_19";
UART2.uart.ctsPin.$assign  = "DIO_6";
UART2.uart.rtsPin.$assign  = "DIO_7";
UART2.ctsPinInstance.$name = "CONFIG_PIN_19";
UART2.rtsPinInstance.$name = "CONFIG_PIN_20";
easylink.addrSize                                            = 2;
easylink.enableAddrFilter                                    = false;
easylink.radioConfigEasylinkPhyCustom.symbolRate             = 20.000;
easylink.radioConfigEasylinkPhyCustom.deviation              = 5.0;
easylink.radioConfigEasylinkPhyCustom.rxFilterBw             = "34.1";
easylink.radioConfigEasylinkPhyCustom.whitening              = "CC1101/CC2500 compatible";
easylink.radioConfigEasylinkPhyCustom.codeExportConfig.$name = "ti_devices_radioconfig_code_export_param0";
const RF                 = scripting.addModule("/ti/drivers/RF", {}, false);
RF.pinSelectionAntenna   = 3;
RF.rfAntennaPinSymbol0   = "CONFIG_RF_ANTENNA_DIO28";
RF.rfAntennaPinSymbol1   = "CONFIG_RF_ANTENNA_DIO29";
RF.rfAntennaPinSymbol2   = "CONFIG_RF_ANTENNA_DIO30";
RF.rfAntennaPin0.$assign = "DIO_28";
RF.rfAntennaPin1.$assign = "DIO_29";
RF.rfAntennaPin2.$assign = "DIO_30";
 * Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
 * version of the tool will not impact the pinmux you originally saw.  These lines can be completely deleted in order to
 * re-solve from scratch.
Timer1.timerInstance.timer.$suggestSolution = "GPTM0";
UART1.uart.$suggestSolution                 = "UART0";
Policy
