Part Number: CC2652R
Hi
Iam trying to combine two example projects i.e,simple_peripheral+spimaster codes. Iam trying to add spimaster project to simpleperipheral. How can I do this?
Harshita.P
Hi
Harshita.P
You can use the Sensor Controller to read the sensor and integrate with BLE:
To transfer the value between boards you need to also create a Central/Master device that reads out the sensor value from the GATT Server on the peer device. You can then either read the attribute value with GATT read or implement and enable notifications.
You can refer to SimpleStreamClient_enableNotifications in simple_serial_socket_client on how to enable notifications from a Master device:
