Other Parts Discussed in Thread: TMS320DM6435
I searched this topic in the forums and haven't come up with a good solution. I was working with our target hardware (using a DM6435) a few days ago and it was working fine. Today I am trying to use the device again, and every time I try and connect, I get the error: TRG_ERR_COMM_FAILURE Error Occured at 0x0000000D. I have switched to use the EVMDM6437 and have the same exact issue.
I also use the DM642 and this board connects to the same emulator/PC with no problem.
Hopefully this covers the basic info you need:
Code Composer Info:
CCS: v4.2.1.0004 (No updates show in the update manager)
If you need more info about CCS, please let me know.
System Info:
Windows 7 64 bit
Device manager shows driver v1.0.0.3 for Texas Instruments XDS560 PCI JTAG Emulator.
CCS Is not installed to Program Files (x86) and UAC is disabled
Target Configurations:
This is what i am trying to use to connect to the DM6435 based hardware.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
<configuration XML_version="1.2" id="TI XDS560 Emulator, 20-pin Rev-D Cable_0">
<instance XML_version="1.2" desc="TI XDS560 Emulator, 20-pin Rev-D Cable_0" href="connections\TIXDS560_Rev_D_Connection.xml" id="TI XDS560 Emulator, 20-pin Rev-D Cable_0" xml="TIXDS560_Rev_D_Connection.xml" xmlpath="connections"/>
<connection XML_version="1.2" id="TI XDS560 Emulator, 20-pin Rev-D Cable_0">
<instance XML_version="1.2" href="drivers\tixds560icepick_c.xml" id="drivers" xml="tixds560icepick_c.xml" xmlpath="drivers"/>
<instance XML_version="1.2" href="drivers\tixds560c64xp.xml" id="drivers" xml="tixds560c64xp.xml" xmlpath="drivers"/>
<platform XML_version="1.2" id="platform_0">
<instance XML_version="1.2" desc="TMS320DM6435_0" href="Devices\dm6435.xml" id="TMS320DM6435_0" xml="dm6435.xml" xmlpath="Devices"/>
</platform>
</connection>
</configuration>
</configurations>
This is what i am using to try and connect to the DVMDM6437.
<instance XML_version="1.2" desc="EVMDM6437_0" href="boards\evmdm6437.xml" id="EVMDM6437_0" xml="evmdm6437.xml" xmlpath="boards"/>
</platform>
</connection>
</configuration>
</configurations>
