CCS/LAUNCHXL-CC26X2R1: Issues with disabling SysConfig
Part Number: LAUNCHXL-CC26X2R1
Hello!
I am following the guide listed on the SimpleLink User Guide on how to disable SysConfig to freeze the config files.
However, after following the guide listed, I receive many errors when rebuilding my project. I am using CCS V10 with everything up to date. The errors I receive are related to the .opt files. Even after changing the location of these files in Build Properties -> Arm Compiler -> Advanced Options -> Command Files it still looks for the files in the standard Debug/syscfg/ folder location.
Any ideas on what to do to force it to see the moved files? I have also successfully excluded the .syscfg file from my build.
Description Resource Path Location Type
Cannot open command file 'syscfg/ti_ble_app_config.opt': No such file or directory CC26X2R1_LAUNCHXL_fxns.c /project_zero_CC26X2R1_LAUNCHXL_tirtos_ccs/Startup C/C++ Problem
Cannot open command file 'syscfg/ti_build_config.opt': No such file or directory CC26X2R1_LAUNCHXL_fxns.c /project_zero_CC26X2R1_LAUNCHXL_tirtos_ccs/Startup C/C++ Problem
I receive 54 of these errors when I attempt to build after following the guide.
