Part Number: CC1352P
I used to use the provide FTDI chip to read the serial port with a serial terminal program to for example commission the dev kit to connect to a Zigbee Hub. I tried using an external USB cable with a FTDI chip and the prompt shown on my serial terminal is slightly different. For example it no longer displays the menu of options that a user can select eg COMMISSION. The menu basically doesn't print correctly using an external cable.
Is there a fix for this?
I'm using one of these cables:
