Part Number: TMS320F28379D
Greetings,
I have generated an image which I programmed onto my DSP using the Black Hawk emulator. When I look at the map file, it indicates that some of the code should be in flash addresses between 0x081000 and 0x082000. But when I look at that section of memory, it is blank (all 0xFFFFs). The areas above 0x082000, on a cursory inspection, seem to have been programmed correctly. To rule out a part failure as the issue, I tried it on a second one with the same result. Is there something in the cmd file, or somewhere else, which could be causing this to happen?
Thank you,
Ed
