Other Parts Discussed in Thread: BQ78PL114, BQWIZARD
Hi
for bq78pl114
I want to read and write, but bqwizard doesn't work
I use usb interface adapter for this adapter is working
we have seen it works with be2works
Can you provide more information with the errors you are seeing? Screenshots and breakdown of your procedure and connections will help us debug your problem easier.
Sincerely,
Wyatt Keller
This appears to be a new thread based on this one: https://e2e.ti.com/support/interface/f/138/p/925700/3425910#3425910
Can you provide your testing procedure? Is the board being powered? Can you check the communication lines with the scope to make sure they are operating correctly? Have you been able to test a different board or chip?
Sincerely,
Wyatt Keller
