CCS: CCS crash after installing a window security patch.
A customer is experiencing the below crash error after installing a window security patch.
even if they uninstall the CCS and install it again, they encounter the same error.
CCS9.3.0
CCS10.1.0
    Can the customer provide information on which windows security patch was installed?
    Also have the customer try cleaning both the CCS cache and their workspace folder
    https://software-dl.ti.com/ccs/esd/documents/users_guide/ccs_troubleshooting.html#general-ide (9.4.2 and 9.4.3)
    If the above has no impact, please have the customer provide their Eclipse error Log (the .log file in their workspace folder)
    ki
  • Hi Ki,
    even if the customer did clean CCS and deleted metadata in a workspace, the same error is occurred.
    Window security patch
    log
    !SESSION 2020-07-29 11:07:35.102 -----------------------------------------------
    eclipse.buildId=4.8.0.I20180611-0500
    java.version=1.8.0_144
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=ko_KR
    Framework arguments:  -product com.ti.ccstudio.branding.product
    Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product com.ti.ccstudio.branding.product -clean
    !ENTRY org.eclipse.egit.core 2 0 2020-07-29 11:08:09.309
    !MESSAGE Builtin LFS support not present/detected
    !STACK 0
    java.lang.ClassNotFoundException: org.eclipse.jgit.lfs.BuiltinLFS cannot be found by org.eclipse.egit.core_5.0.0.201806131550-r
    	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:508)
    	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:419)
    	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:411)
    	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
    	at java.lang.ClassLoader.loadClass(Unknown Source)
    	at java.lang.Class.forName0(Native Method)
    	at java.lang.Class.forName(Unknown Source)
    	at org.eclipse.egit.core.Activator.registerBuiltinLFS(Activator.java:279)
    	at org.eclipse.egit.core.Activator.start(Activator.java:212)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
    	at java.security.AccessController.doPrivileged(Native Method)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
    	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1002)
    	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:354)
    	at org.eclipse.osgi.container.Module.doStart(Module.java:581)
    	at org.eclipse.osgi.container.Module.start(Module.java:449)
    	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
    	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:114)
    	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:505)
    	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
    	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:392)
    	at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
    	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
    	at org.eclipse.egit.ui.Activator$RepositoryChangeScanner.<init>(Activator.java:921)
    	at org.eclipse.egit.ui.Activator.setupRepoChangeScanner(Activator.java:1034)
    	at org.eclipse.egit.ui.Activator.start(Activator.java:336)
    	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:470)
    	at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:609)
    	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:177)
    	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:931)
    	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
    	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:60)
    	at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:174)
    	at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:104)
    	at org.eclipse.ui.internal.Workbench$34.runWithException(Workbench.java:2378)
    	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
    	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
    	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
    	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4567)
    	at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:95)
    	at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2373)
    	at org.eclipse.ui.internal.Workbench.init(Workbench.java:1654)
    	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2859)
    	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:654)
    	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
    	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
    	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
    	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
    	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    	at java.lang.reflect.Method.invoke(Unknown Source)
    	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
    	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
    	at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
    !ENTRY com.ti.common.core 1 0 2020-07-29 11:08:11.006
    !MESSAGE path=ccs_base/DebugServer
    !ENTRY com.ti.common.core 1 0 2020-07-29 11:08:11.019
    !MESSAGE debugServerDir=C:/ti/ccs901/ccs/ccs_base/DebugServer
    !ENTRY org.eclipse.equinox.event 4 0 2020-07-29 11:08:24.505
    !MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] {ChangedElement=org.eclipse.e4.primaryDataStack=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@289cf7db (tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@49ee3b8d, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.primaryDataStack=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@289cf7db (tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@49ee3b8d, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized}, AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@4c682826
    !STACK 0
    org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException:
    	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
    	at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:64)
    	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:212)
    	at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:61)
    	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
    	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:196)
    	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
    	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
    	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
    	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
    	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
    	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
    	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
    	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
    	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
    	at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
    	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:304)
    	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:304)
    	at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:200)
    	at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:138)
    	at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:190)
    	at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:572)
    	at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:782)
    	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1005)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:137)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:93)
    	at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:74)
    	at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1507)
    	at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1478)
    	at com.ti.ccstudio.debug.ui.targetStatus.TargetStatusManager.addStatusBar(TargetStatusManager.java:379)
    	at com.ti.ccstudio.debug.ui.targetStatus.statusBar.TargetStatusBar.fill(TargetStatusBar.java:44)
    	at com.ti.ccstudio.debug.ui.targetStatus.statusBar.CCSStatusBar.createControl(CCSStatusBar.java:39)
    	at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:105)
    	at org.eclipse.ui.internal.menus.CompatibilityWorkbenchWindowControlContribution.construct(CompatibilityWorkbenchWindowControlContribution.java:90)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:412)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:345)
    	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:214)
    	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:108)
    	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
    	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:51)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlContribution.createControl(ToolControlContribution.java:53)
    	at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:101)
    	at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:343)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.subscribeTopicUpdateToBeRendered(ToolBarManagerRenderer.java:213)
    	at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
    	at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:346)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarContributionRecord.updateVisibility(ToolBarContributionRecord.java:71)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$2.changed(ToolBarManagerRenderer.java:479)
    	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
    	at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:344)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processAddition(ToolBarManagerRenderer.java:471)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.generateContributions(ToolBarManagerRenderer.java:447)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContribution(ToolBarManagerRenderer.java:416)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createWidget(ToolBarManagerRenderer.java:376)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:1012)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:672)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:778)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:749)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:743)
    	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:727)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(PartRenderingEngine.java:308)
    	at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
    	at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:88)
    	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
    	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:340)
    	at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.processAddition(ContributionsAnalyzer.java:441)
    	at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.addTrimContributions(TrimBarRenderer.java:164)
    	at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:136)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:686)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:557)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:541)
    	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:722)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1096)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
    	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
    	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
    Caused by: java.lang.IllegalArgumentException:
    	at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
    	at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:160)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:411)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:397)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getActivePerspective(ModelServiceImpl.java:976)
    	at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.getElementsToMinimize(MinMaxAddon.java:719)
    	at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.maximize(MinMaxAddon.java:690)
    	at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:381)
    	at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
    	... 150 more
    !ENTRY org.eclipse.launchbar.core 2 0 2020-07-29 11:08:25.380
    !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
    !ENTRY org.eclipse.launchbar.core 2 0 2020-07-29 11:08:25.553
    !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
    !ENTRY org.eclipse.launchbar.core 2 0 2020-07-29 11:08:25.577
    !ENTRY org.eclipse.core.jobs 4 2 2020-07-29 11:08:26.517
    !MESSAGE An internal error occurred during: "CrashReportJob".
    !STACK 0
    java.lang.UnsatisfiedLinkError: C:\Users\82104\AppData\Local\Temp\proxy_vole3857512545234510846.dll: 액세스가 거부되었습니다
    	at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    	at java.lang.ClassLoader.loadLibrary0(Unknown Source)
    	at java.lang.ClassLoader.loadLibrary(Unknown Source)
    	at java.lang.Runtime.load0(Unknown Source)
    	at java.lang.System.load(Unknown Source)
    	at com.btr.proxy.search.desktop.win.Win32ProxyUtils.<clinit>(Win32ProxyUtils.java:37)
    	at com.btr.proxy.search.browser.ie.IEProxySearchStrategy.readSettings(IEProxySearchStrategy.java:57)
    	at com.btr.proxy.search.browser.ie.IEProxySearchStrategy.getProxySelector(IEProxySearchStrategy.java:42)
    	at com.btr.proxy.search.ProxySearch.getProxySelector(ProxySearch.java:193)
    	at com.ti.ccstudio.errorreporting.HtmlPostUtility.getProxy(HtmlPostUtility.java:84)
    	at com.ti.ccstudio.errorreporting.HtmlPostUtility.<init>(HtmlPostUtility.java:62)
    	at com.ti.ccstudio.errorreporting.ErrorReportJob.run(ErrorReportJob.java:64)
    	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
    !ENTRY com.ti.ccstudio.ui 1 0 2020-07-29 11:08:35.988
    !MESSAGE CCS IDE session started!
    	CCS build: 9.3.0.00012
    	CCS location: C:/ti/ccs901/ccs
    	Workspace location: D:/00_DevData/99_WorkSpace/02_TI/00_MC85A
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.298
    !MESSAGE constructor
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.336
    !MESSAGE done with directories
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.387
    !MESSAGE loading ti_logger
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.587
    !MESSAGE Platform os: win32
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.610
    !MESSAGE loading cToolsIF
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.630
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.748
    !MESSAGE loading TraceFactory
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.812
    !MESSAGE loading sqlite3
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.833
    !MESSAGE loading CloudTrace
    !ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2020-07-29 11:08:36.865
    !MESSAGE CloudTrace interface loaded
    !ENTRY com.ti.ccstudio.project.ui.webcontent 1 0 2020-07-29 11:08:36.966
    !MESSAGE CCS HTTP adapter started! [ccs.port:29861] - Open 'http://localhost:29861/ide' in web browser to see listing of available APIs...
  • Thank you for the log. The error in the first screenshot and the related error in the log is:
    This is related to the CCS feature of sending any crash logs to TI. Apparently this attempt failed because of the above access error. Please have the customer check the permissions to make sure they have access to that file in the above Temp folder
    This "CrashReportJob" is not essential to run CCS. If the customer presses the "OK" button in the dialog box, does CCS run ok afterwards?
