Part Number: AM3356
I have a question about UART in the StarterWave routine.
I call the function UARTFIFOWrite to put the data I need to send into A FIFO.
However, when this function executes the For loop, it is interrupted by other tasks, and the data sent out later becomes abnormal.
The configuration is as follows:
Problem: Why did the data exception occur when the execution of the UARTFIFOWrite function was interrupted by other tasks without any changes to the configuration?There are also problems if you change the other task functionality to Task_sleep.How to solve this problem and what causes it?
Thank you very much.
