CCS/IWR1642: IWR1642
Part Number: IWR1642
Hello, all.
I attempt to import and run some labs in "industrial tool box 4_4_1"
But I have an error as below.
Even I checked SYS/BIOS already downloaded.
I have already download as below.
1. code composer 10.1.0
2. mmWave sensor-industrial toolbox 4.4.1
3. mmwave_sdk_03_04_00_03
Could you help me ?
  • The error message didn't show up in the post.  However given the context I think what you are saying is that is that CCS is giving an error about something not being found.  Projects will specify the software products and versions to use.  CCS then tries to resolve these with the products that it is aware of.  I am guessing that CCS does not know where things are installed on your machine.  You can specify the locations in the Preferences dialog here:
    In the top section you can specify where to look for products.  The click the refresh button and it should list what it has discovered in the bottom section.
    John
