Part Number: LP-CC2652RB
Hi, I am trying to implement message queue to receive data from another microcontroller to CC2652 Launchpad. I want to receive and write data to sd card. For this i am following lab exercise given in the link below.
This lab exercise i have modified according to my application. I am turning an LED on after receiving '\n' character.
Next i want to write an array of character received from the Uart into the SD card. But i am getting errors. One error is that i am not able to access the incoming character variable in the alarm.c file. Where do i declare it so that i use it across all files. I am attaching all the three edited files i.e. Uartecho.c , main_tirtos & alarm.c .
Please help me, i am really stuck in it.
shivam
* Copyright (c) 2015-2020, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== uartecho.c ========
#include <stdint.h>
#include <stddef.h>
#include <mqueue.h>
/* Driver Header files */
#include <ti/drivers/GPIO.h>
#include <ti/drivers/UART.h>
/* Driver configuration */
#include "ti_drivers_config.h"
char input;
* ======== mainThread ========
void *mainThread(void *arg0)
const char echoPrompt[] = "Echoing characters:\r\n";
UART_Handle uart;
UART_Params uartParams;
mqd_t *mqdes = arg0;
int msg;
/* Call driver init functions */
//GPIO_init();
UART_init();
/* Configure the LED pin */
// GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
/* Create a UART with data processing off. */
UART_Params_init(&uartParams);
uartParams.writeDataMode = UART_DATA_BINARY;
uartParams.readDataMode = UART_DATA_BINARY;
uartParams.readReturnMode = UART_RETURN_FULL;
uartParams.readEcho = UART_ECHO_OFF;
uartParams.baudRate = 115200;
uart = UART_open(CONFIG_UART_0, &uartParams);
if (uart == NULL) {
/* UART_open() failed */
while (1);
/* Turn on user LED to indicate successful initialization */
//GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON);
UART_write(uart, echoPrompt, sizeof(echoPrompt));
/* Loop forever echoing */
while (1) {
UART_read(uart, &input, 1);
if (input == '\n')
msg = 5;
mq_send(*mqdes , (char *)&msg, sizeof(msg), 0);
GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_OFF);
UART_write(uart, &input, 1);
* Copyright (c) 2016-2020, Texas Instruments Incorporated
* are met:
* ======== main_tirtos.c ========
#include <stdint.h>
/* POSIX Header files */
#include <pthread.h>
#include <mqueue.h>
/* RTOS header files */
#include <ti/sysbios/BIOS.h>
#include <ti/drivers/Board.h>
extern void *mainThread(void *arg0);
extern void *alarmThread(void *arg0);
/* Stack size in bytes */
#define THREADSTACKSIZE 1024
#define MSG_SIZE sizeof(int)
#define MSG_NUM 4
mqd_t mqdes;
* ======== main ========
int main(void)
pthread_t thread;
pthread_t alarm;
pthread_attr_t attrs;
struct sched_param priParam;
int retc;
struct mq_attr mqAttrs;
Board_init();
GPIO_init();
mqAttrs.mq_maxmsg = MSG_NUM;
mqAttrs.mq_msgsize = MSG_SIZE;
mqAttrs.mq_flags = 0;
mqdes = mq_open ("alarm", O_RDWR | O_CREAT,
0664, &mqAttrs);
if (mqdes == (mqd_t)-1) {
/* mq_open() failed */
while (1);
/* Initialize the attributes structure with default values */
pthread_attr_init(&attrs);
/* Set priority, detach state, and stack size attributes */
priParam.sched_priority = 1;
retc = pthread_attr_setschedparam(&attrs, &priParam);
retc |= pthread_attr_setdetachstate(&attrs, PTHREAD_CREATE_DETACHED);
retc |= pthread_attr_setstacksize(&attrs, THREADSTACKSIZE);
if (retc != 0) {
/* failed to set attributes */
while (1) {}
retc = pthread_create(&thread, &attrs, mainThread, (void *)&mqdes);
if (retc != 0) {
/* pthread_create() failed */
while (1) {}
* Make the alarm thread a higher priority.
priParam.sched_priority = 2;
retc = pthread_create(&alarm, &attrs, alarmThread, (void *)&mqdes);
if (retc != 0) {
while (1);
BIOS_start();
return (0);
* ======== alarm.c ========
#include <file.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
#include <mqueue.h>
#include <third_party/fatfs/ffcio.h>
#include <ti/drivers/SDFatFS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Clock.h>
/* Buffer size used for the file copy process */
#ifndef CPY_BUFF_SIZE
#define CPY_BUFF_SIZE 2048
#endif
/* String conversion macro */
#define STR_(n) #n
#define STR(n) STR_(n)
/* Drive number used for FatFs */
#define DRIVE_NUM 0
const char inputfile[] = "fat:"STR(DRIVE_NUM)":input.txt";
const char outputfile[] = "fat:"STR(DRIVE_NUM)":output.txt";
//const char textarray[] ="Hello from shivam";
//static Display_Handle display;
/* Set this to the current UNIX time in seconds */
const struct timespec ts = {
.tv_sec = 1469647026,
.tv_nsec = 0
/* File name prefix for this filesystem for use with TI C RTS */
char fatfsPrefix[] = "fat";
unsigned char cpy_buff[CPY_BUFF_SIZE];
* ======== alarmThread ========
int msg;
UInt32 sleepTickCount;
sleepTickCount = 100000 / Clock_tickPeriod;
while (mq_receive(*mqdes, (char *)&msg, sizeof(msg), NULL) != -1) {
/* Turn on user LED */
Task_sleep(sleepTickCount);
SDFatFS_Handle sdfatfsHandle;
FILE *src;
SDFatFS_init();
add_device(fatfsPrefix, _MSA, ffcio_open, ffcio_close, ffcio_read,
ffcio_write, ffcio_lseek, ffcio_unlink, ffcio_rename);
/* Initialize real-time clock */
clock_settime(CLOCK_REALTIME, &ts);
sdfatfsHandle = SDFatFS_open(CONFIG_SDFatFS_0, DRIVE_NUM);
/* Open file for both reading and writing */
src = fopen(inputfile, "w+");
fseek(src,0,SEEK_END);
fwrite(&input, 1, 1, src);
/* Close inputfile[] */
fclose(src);
/* Stopping the SDCard */
SDFatFS_close(sdfatfsHandle);
return(0);
* ======== fatfs_getFatTime ========
int32_t fatfs_getFatTime(void)
time_t seconds;
uint32_t fatTime;
struct tm *pTime;
* TI time() returns seconds elapsed since 1900, while other tools
* return seconds from 1970. However, both TI and GNU localtime()
* sets tm tm_year to number of years since 1900.
seconds = time(NULL);
pTime = localtime(&seconds);
* localtime() sets pTime->tm_year to number of years
* since 1900, so subtract 80 from tm_year to get FAT time
* offset from 1980.
fatTime = ((uint32_t)(pTime->tm_year - 80) << 25) |
((uint32_t)(pTime->tm_mon) << 21) |
((uint32_t)(pTime->tm_mday) << 16) |
((uint32_t)(pTime->tm_hour) << 11) |
((uint32_t)(pTime->tm_min) << 5) |
((uint32_t)(pTime->tm_sec) >> 1);
return ((int32_t)fatTime);
