Part Number: AWR6843ISK
Other Parts Discussed in Thread: MMWAVEICBOOST
I'd like to deal with the ccs project with AWR6843ISK at debug mode.
After project is compiled, the emulator can not be connected to the EVK.
Test Environment, a figure of EVK Setup, Test Connection Log and figure of BH XDS560v2 configuration utility & log is listed below.
Please assist.
<Test Environment>
EVK : AWR6843ISK + MMWAVEICBOOST
CCS version : 10.1.1.00004
SDK version : mmwave_sdk_03_04_00_03
Emulator : BH XDS560v2-USB System Trace Emulator
CCS Project Name : 68xx_mmwave_sdk_hwa (mmwave_automotive_toolbox_3_1_0\mmwave_sdk_ccs_projects\mmwave_sdk_3_4)
<EVK Setup>
< Test Connection Log >
[Start: Blackhawk XDS560v2-USB System Trace Emulator_0]
Execute the command:
%ccs_base%/common/uscif/dbgjtag.exe -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\Soo\AppData\Local\TEXASI~1\CCS\
ccs1011\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 560/2xx-class product.
This utility will load the program 'bh560v2u.out'.
Loaded FPGA Image: C:\ti\ccs1011\ccs\ccs_base\common\uscif\dtc_top.jbc
The library build date was 'May 7 2020'.
The library build time was '19:55:51'.
The library package version is '9.2.0.00002'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '6' (0x00000006).
The controller has an insertion length of '0' (0x00000000).
The cable+pod has a version number of '8' (0x00000008).
The cable+pod has a capability number of '7423' (0x00001cff).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the Nano-TBC VHDL.
The link is a 560-class second-generation-560 cable.
The software is configured for Nano-TBC VHDL features.
The controller will be software reset via its registers.
The controller has a logic ONE on its EMU[0] input pin.
The controller has a logic ONE on its EMU[1] input pin.
The controller will use falling-edge timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '2' (0x0002).
The utility logic has not previously detected a power-loss.
The utility logic is not currently detecting a power-loss.
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-233' (0xffffff17).
The title is 'SC_ERR_PATH_BROKEN'.
The explanation is:
The JTAG IR and DR scan-paths cannot circulate bits, they may be broken.
An attempt to scan the JTAG scan-path has failed.
The target's JTAG scan-path appears to be broken
with a stuck-at-ones or stuck-at-zero fault.
[End: Blackhawk XDS560v2-USB System Trace Emulator_0]
<BH XDS560v2 configuration utility>
< Output log of Configuration Utility >
CMD: dtc_conf --version
Version 9.2.0.00002, built May 7 2020 21:04:33
LAN: Not selected to search.
CMD: dtc_conf get bh560v2u 0
CMD: dtc_conf get bh560v2u 1
USB: 1 device found.
TOTAL: 1 device found.
addrConf=:55756
addrIo=:55755
boardRev=2
dtcName=none
epkRev=5.0.573.0
fpgaRev=1.57
productClass=XDS560V2
productName=Blackhawk USB560v2 System Trace Emulator
safeMode=false
serialNum=00:00:00:04:55:49
swBuildTime=Apr 19 2012 14:09:25
swRev=5.0.573.0
time=none
vendorName=Blackhawk
standbyEnable=false
standbyMinutes=20
CMD: dbgjtag -X emulator,driver=bh560v2u,ioport=0 -S integrity -Y reset -S pathlength -G range,lowest=9.350000,highest=11.250000
The explanation is:
RES: dbgjtag -X emulator,driver=bh560v2u,ioport=0 -S integrity -Y reset -S pathlength -G range,lowest=9.350000,highest=11.250000
RES: Fail
