CCS Display double floating point wrong for Stellaris micro-controller
Other Parts Discussed in Thread: LM3S3748, LM3S8962
I am using double precision values and although the end calculation looks correct (eventually converted to int) the watch window displays the double values incorrectly. It looks like the byte order is being interpreted incorrectly. IE: I have the value 4792.5 and in ascending order in memory it is: 0x00 0x00 0x00 0x00 0x80 0xB8 0xB2 0x40 However the watch window shows it as: 5.362857607874241e-315 Some trouble shooting shows this value as reverse byte order of above. As I said final calculation is correct so I believe compiler is fine and it is only a debug display problem. Is there a way to set up debug window for proper byte order? The processor I am using is the LM3S3748 and CCS.
