Part Number: TMS570LS0914
I upgraded to CCS V9 and the following problem started: I am debugging C code with a structure. If I hit a breakpoint and look in the "Variables" tab, I can find my structures and when I open them the fields within them are there. However, if I hover over the structure variable in the code the popup that used to contain the fields and values is mostly just white (with (x)= being the only thing that shows for each field) until I click on the field. However, then I can only see one field value at a time. I have a feeling this may be a font color issue, but I can't find the right place to fix it. Any thoughts?
