Debug session does not start
I am using CCS 4.2.1 + SEED-XDS560PLUS jtag or SD XDS510 USB. I am trying to debug my project. For both jtags I am experiencing the same issue.
When I choose Debug Active Project jtag initializes fine, gel script executes fine, my out image loads successfully and then nothing happens.
I cannot run application because all the entries in Target menu are grey out. I looks like Debug session is not started. I tried to debug debugger using DbgView
as it is described on Troubleshooting Wiki page but I have not found any suspicious entries:
[4908] 0x000010A0 3 ICEPICK_C STATE I: Target execution state changed to STATUS_NON_DEBUG_NORMAL
[4908] 0x000010A0 3 ICEPICK_C STATE I: Debugger execution state changed to EVENT_DSP_HALT
I also gathered Trace logs:
M     14:30:53:488 | cTools: Setting up env -CTOOLS_BIN=C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/.
Setting up env -CTOOLS_XMLDB=C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/aet_config
Setting up env -TRACE_XMLDB_SETUP=C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/trace_config/setup
Setting up env -TRACE_XMLDB_DEVICES=C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/trace_config/devices
Setting up env -COMMON_BIN=C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../../../common/bin
Setting up env -COMMON_USCIF=C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../../../common/uscif
Setting up env -TPI=C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../../tpi
Setting up PATH-PATH=C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:/Program Files/Texas Instruments/xdctools_3_20_03_63;C:\Program Files\ActivePerl58\site\bin;C:\Program Files\ActivePerl58\bin;C:\Perl\site\bin;C:\Perl\bin;C:\Python25\;C:\Program Files\GNU\GnuPG\;C:\Program Files\Java\jdk1.6.0_10\bin\;C:\Program Files\Java\jre1.6.0_05\bin\;C:\Software\Oracle\10.1.0\bin;C:\Software\Oracle\10.1.0\jre\1.4.2\bin\client;C:\Software\Oracle\10.1.0\jre\1.4.2\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\scripts;c:\ntutils;C:\Program Files\RSA Security\RSA SecurID Software Token\;C:\Program Files\jEdit;C:\Program Files\Rational\common;C:\Program Files\Qemu\;C:\Program Files\Quest Software\PuTTY\;C:\Program Files\Git\cmd;C:\Program Files\Rational\ClearCase\bin;C:/Program Files/Texas Instruments/xdctools_3_20_03_63;C:\Program Files\GNU\GnuPG\;C:\Program Files\Git\bin\;C:\Program Files\Nmap;D:\Profiles\ams108\Desktop\Android\Development\android-sdk-windows-1.0_r1\tools\;C:\Program Files\Java\jre1.6.0_05\bin\;C:\Python26\;c:\MinGW\bin;c:\cygwin\bin;C:\Program Files\Oracle\Berkeley DB XML 2.4.16\bin\;C:\Program Files\Oracle\Berkeley DB XML 2.5.13\bin;C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/.
M     14:30:53:488 | cTools: main Thread ID 6080 .
M     14:30:53:488 | cTools: cToolsJobMgrIF is created
M     14:30:58:004 | Trace JNI: connecting channel server
M     14:30:58:004 | Trace Factory: Calling CreateTraceFactory
M     14:30:58:004 | Trace Factory: CreateTraceFactory pStaticFactory=0x1afe48e0    refcount=2
M     14:30:58:004 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
M     14:30:58:004 | Trace Factory: CreateChannelServer  - connect existing
    E 14:30:58:004 | Trace Factory: Channel server creation failed.
    E 14:30:58:004 | Trace JNI: Channel server creation failed..
M     14:30:58:004 | Trace JNI: connecting channel server - DONE
M     14:31:00:644 | cTools: In GetcToolsDBMgrIFEx
M     14:31:00:644 | cTools: Create database for XML file C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/aet_config/2000.xml
M     14:31:00:644 | cTools: Calling CreateSystem for ctoolsndbg with TA 0x2253d870 using CPU 0.
M     14:31:00:676 | cToolsIF: CreateSystem() is passed
M     14:31:00:676 | cTools: CreateSystem done.
M     14:31:00:676 | cTools: IsTargetSupported EntityName=ctoolsndbg.
M     14:31:00:676 | cTools: IsTargetSupported action count=0.
M     14:31:00:676 | cTools: IsTargetSupported supportTrace =0.
M     14:31:00:676 | cTools: Loading factory DLL - TraceFactory.dll
M     14:31:00:676 | cTools: Creating Trace factory
M     14:31:00:676 | Trace Factory: Calling CreateTraceFactory
M     14:31:00:676 | Trace Factory: CreateTraceFactory pStaticFactory=0x1afe48e0    refcount=3
M     14:31:00:676 | cTools: Connecting Channel Server
M     14:31:00:676 | Trace Factory: calling CreateChannelServer  m_channelServer=0x0
M     14:31:00:676 | Trace Factory: CreateChannelServer  - create new
M     14:31:00:676 | ICE CD: Initializing channel server in mode 1.
M     14:31:00:676 | ICE CD: Initializing channel server for CCS v4 in mode 1.
M     14:31:00:676 | ICE CD: Strting to load ICE client properties.
M     14:31:00:676 | ICE CD: Loaded ICE client properties.
M     14:31:00:691 | ICE CD: icebox invoked pid 5680
M     14:31:00:738 | ICE CD: Trace Server invoked PID 2552 .
M     14:31:00:738 | ICE CD: Trying to initialize ICE with properties.
M     14:31:00:863 | ICE CD: Trying to get channel server instance.
M     02/24/11 14:31:00:879 | ********** Trace Server Starting **********
M      MODULE INFO - TraceServer.exe  PID=2552 : TraceServer.exe
M     14:31:00:925 | Trace Server: Init server successful
M     14:31:00:925 | Trace Server: register exit handlers
M     14:31:00:925 | Trace Server: getting topic manager. Attempt = 1
M     14:31:01:316 | Trace Server: topic manager instance retreived successfully.
M     14:31:01:332 | Trace Server: parsing C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/./trace_server_config.xml
M     14:31:01:332 | Trace Server: XML control name TraceCntrl
M     14:31:01:332 | Trace Server: XML target adapter name ICETargetAdapter
M     14:31:01:332 | Trace Server: XML display name None
M     14:31:01:332 | Trace Server: XML receiver name None
M     14:31:01:332 | Trace Server: XML receiver multicore is true
M     14:31:01:332 | Trace Server: XML display name 560 Trace Pod
M     14:31:01:332 | Trace Server: XML receiver name TsunamiRcvr
M     14:31:01:332 | Trace Server: XML display name 560 V2 Trace
M     14:31:01:332 | Trace Server: XML receiver name DtcRcvr
M     14:31:01:332 | Trace Server: XML display name ETB
M     14:31:01:332 | Trace Server: XML receiver name ETBRcvr
M     14:31:01:332 | Trace Server: XML Transmitter name DSP Transmitter
M     14:31:01:332 | Trace Server: XML Transmitter DLL name ctools_xmtr
M     14:31:01:332 | Trace Server: XML Transmitter name ARM Transmitter
M     14:31:01:332 | Trace Server: XML Transmitter DLL name etm_xmtr
M     14:31:01:332 | Trace Server: parsed C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/./trace_server_config.xml error 0
M     14:31:01:363 | Trace Server: Started Trace Control [TraceCntrl.exe] PID 336
M     14:31:01:379 | Trace Server: Status thread starting
M     14:31:01:441 | Trace Server: ICE channel server created
M     14:31:01:441 | Trace Server: ICE event broker created
M     14:31:01:441 | Trace Server: initialization done; running server
M     14:31:01:535 | Trace Control: initializing frame....
M     14:31:01:535 | Trace Control: starting debugger detetction thread....
M     14:31:01:535 | Trace Control: Debugger client PID=4908.
M     14:31:01:550 | Trace Control: creating main pannel....
M     14:31:01:550 | Trace Control: connecting to server.
M     14:31:01:550 | Trace Control: setting current dir C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/..
M     14:31:01:629 | Trace Control: calling to connect channel server - retry=5.
M     14:31:01:675 | Trace Control: register for events.
M     14:31:01:675 | Trace Control: getting receivers infos.
M     14:31:01:675 | Trace Server: In GetRcvrInfo for Id=0.
M     14:31:01:675 | Trace Control: available receiver 0  None.
M     14:31:01:675 | Trace Server: In GetRcvrInfo for Id=1.
 W    14:31:01:675 | Trace Server: Receiver not initialized - Id=1.
M     14:31:01:675 | Trace Control: available receiver 1  560 Trace Pod.
M     14:31:01:691 | Trace Server: In GetRcvrInfo for Id=2.
 W    14:31:01:691 | Trace Server: Receiver not initialized - Id=2.
M     14:31:01:691 | Trace Control: available receiver 2  560 V2 Trace.
M     14:31:01:691 | Trace Server: In GetRcvrInfo for Id=3.
 W    14:31:01:691 | Trace Server: Receiver not initialized - Id=3.
M     14:31:01:691 | Trace Control: available receiver 3  ETB.
M     14:31:01:691 | Trace Control: Connected to server.
M     14:31:01:754 | ICE CD: Successfully got channel server instance.
M     14:31:01:754 | ICE CD: Trying to get IceStorm TopicManager Proxy.
M     14:31:01:754 | ICE CD: Trying to convert object base from IceStorm TopicManager Proxy.
M     14:31:01:754 | ICE CD: Trying to convert topic manager from object base .
M     14:31:01:754 | ICE CD: Converted topic manager from object base .
M     14:31:01:754 | ICE CD: Trying to activate channel listener adapter.
M     14:31:01:754 | ICE CD: Activated channel listener adapter.
M     14:31:01:754 | ICE CD: Created new Channel Server 0x230c8a88
M     14:31:01:754 | Trace Factory: CreateChannelServer  - m_CSRefCount=1
M     14:31:01:754 | cTools: Done - creating Channel Server
M     14:31:01:769 | cTools: SUCCESS! Job Manager created successfully.
M     14:31:01:769 | ICE CD: Register client for events - 0x1afef758
M     14:31:01:769 | ICE CD: Total registered clients - 1
M     14:31:01:769 | cTools: Adding ICE target adapter.
M     14:31:01:785 | ICE Target Adapter Server: initializing service
M     14:31:01:785 | ICE Target Adapter Server: creating adapater factory object
M     14:31:01:785 | ICE Target Adapter Server: activating adapater factory object
M     14:31:01:785 | ICE Target Adapter Server: service initialized
M     14:31:01:785 | ICE Target Adapter Server: target adapter 0x230c53d0 cpu id 0 & type 2000 added
M     14:31:01:785 | cTools: ICE target adapter added.
M     14:31:01:785 | cTools: Setting up remote trace event handler map.
M     14:31:01:785 | cTools: Set up timer ID 31637.
M     14:31:01:785 | cTools: RegisterForEvents client=0x1d91a760 for cpunum=0
M     14:31:01:785 | AETPropertyHelper: Get server name from file C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/aet_config/aetdvrs.xml
M     14:31:01:785 | AETProperties: No server name for CPU 2000
M     14:31:01:785 | cTools: OnTargetStateChange 1.
M     14:31:01:785 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/ICEPICK_C
M     14:31:01:785 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/ICEPICK_C state change event 1
M     14:31:01:785 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/ICEPICK_C state change event 1
M     14:31:01:785 | Trace Server: Event broker received pre connect event for SEED XDS560PLUS Emulator_0/ICEPICK_C cpu
M     14:31:01:785 | cTools: OnTargetStateChange Done waitloop=1999
M     14:31:01:957 | cTools: OnTargetStateChange 2.
M     14:31:01:957 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/ICEPICK_C
M     14:31:01:957 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/ICEPICK_C state change event 2
M     14:31:01:957 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/ICEPICK_C state change event 2
M     14:31:01:957 | Trace Server: Event broker received connect event for SEED XDS560PLUS Emulator_0/ICEPICK_C cpu
M     14:31:01:957 | cTools: OnTargetStateChange Done waitloop=1999
M     14:31:02:066 | cTools: In GetcToolsDBMgrIFEx
M     14:31:02:066 | cTools: Create database for XML file C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/aet_config/67104.xml
M     14:31:02:082 | cTools: Calling CreateSystem for cTools2000 with TA 0x221dea60 using CPU 1.
M     14:31:02:113 | cTools2000: CreateSystem() is called. CPU Type: 67104
M     14:31:02:113 | cTools: Protected Target Adapter memory read pushed to Q - address 0x1bc002c length 4.
M     14:31:02:113 | cTools: Protected Target Adapter - WaitUntilProcessed.
M     14:31:02:113 | cTools: Protected Target Adapter [SEED XDS560PLUS Emulator_0/C674X_0] processing request pReq = 0x230e68a8, CurrentThread = 4256.
M     14:31:02:113 | cTools: Protected Target Adapter processing read memory request- address 0x1bc002c.
M     14:31:02:113 | cTools: Protected Target Adapter processing read memory request- address 0x1bc002c value[0] 0x40c done status 0.
M     14:31:02:129 | cToolsIF: CreateSystem() is passed
M     14:31:02:129 | cTools: CreateSystem done.
M     14:31:02:129 | cTools: IsTargetSupported EntityName=cTools2000.
M     14:31:02:129 | cTools: IsTargetSupported action count=21.
M     14:31:02:129 | cTools: IsTargetSupported supportTrace =1.
M     14:31:02:129 | cTools: Adding ICE target adapter.
M     14:31:02:129 | ICE Target Adapter Server: target adapter 0x230e4720 cpu id 1 & type 67104 added
M     14:31:02:129 | cTools: ICE target adapter added.
M     14:31:02:129 | cTools: Adding CPU 1 to trace system.
M     14:31:02:129 | cTools: Setting up remote trace event handler map.
M     14:31:02:129 | cTools: RegisterForEvents client=0x1d91a760 for cpunum=1
M     14:31:02:129 | ICE Target Adapter: connected to target adapter server.
M     14:31:02:129 | ICE Target Adapter Server: got processor label SEED XDS560PLUS Emulator_0/ICEPICK_C
M     14:31:02:129 | ICE Target Adapter Server: got processor label SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:02:129 | ICE Target Adapter Server: got processor id  1342283584
M     14:31:02:129 | ICE Target Adapter Server: got si rev 5
M     14:31:02:144 | ICE Target Adapter Server: got processor label SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:02:144 | Trace Server: Channel event [20] Trace CPU Added fired.
M     14:31:02:144 | ICE Target Adapter Server: got type 67104
M     14:31:02:144 | ICE Target Adapter: got type  67104
M     14:31:02:144 | AETPropertyHelper: Get server name from file C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/aet_config/aetdvrs.xml
M     14:31:02:144 | AETProperties: Operation Server Name AETOperationServer for CPU 67104
M     14:31:02:160 | AETProperties: Call GetOperationServer() for CPU 67104
M     14:31:02:175 | AETOperationServer: Device Identifier loaded
M     14:31:02:175 | DevId: Can Create Server.
M     14:31:02:175 | DevId: CreateDeviceIdentifier - devIdPtr=0x2311d2f0 devIdRefCount=1
M     14:31:02:175 | DevId: Loading factory DLL - TraceFactory.dll
M     14:31:02:175 | DevId: Connecting to Trace factory
M     14:31:02:175 | Trace Factory: Calling CreateTraceFactory
M     14:31:02:175 | Trace Factory: CreateTraceFactory pStaticFactory=0x1afe48e0    refcount=4
M     14:31:02:175 | DevId: Connecting Live Channel Server
M     14:31:02:175 | Trace Factory: calling CreateChannelServer  m_channelServer=0x230c8a88
M     14:31:02:175 | Trace Factory: CreateChannelServer  - m_CSRefCount=2
M     14:31:02:175 | DevId: Done - Connecting Channel Server
M     14:31:02:175 | DevId: Loading device info...
M     14:31:02:175 | DevId: CCS V4 environment.
M     14:31:02:207 | Setup Adapter4: CreateSetupAdapter.
M     14:31:02:207 | Setup Adapter4: CCS_CONNECTION_FILE = D:/Profiles/ams108/My Documents/workspace/datalight_dsp/NewTargetConfiguration.ccxml
M     14:31:03:019 | Setup Adapter4: board.dat file = c:/temp0.dat
M     14:31:03:019 | Setup Adapter4: Processor[0] Name = SEED XDS560PLUS Emulator_0/ICEPICK_C TraceId = 0x0
M     14:31:03:019 | Setup Adapter4: Processor[1] Name = SEED XDS560PLUS Emulator_0/C674X_0 TraceId = 0x0
M     14:31:03:019 | Setup Adapter4: Processor[1] : Name = SEED XDS560PLUS Emulator_0/C674X_0; Type = 0x3c000805; Parent = SEED XDS560PLUS Emulator_0/ICEPICK_C
M     14:31:03:019 | Setup Adapter4: Board file c:/temp0.dat
M     14:31:03:019 | DevId: EMU name xds560
M     14:31:03:019 | DevId: EMU port 0x0
M     14:31:03:019 | DevId: Target adapter instance for SEED XDS560PLUS Emulator_0/ICEPICK_C is 0x230c53d0
M     14:31:03:019 | cTools: Protected Target Adapter get register id pushed to Q- reg IP_TAPID.
M     14:31:03:019 | cTools: Protected Target Adapter - WaitUntilProcessed.
M     14:31:03:019 | cTools: Protected Target Adapter [SEED XDS560PLUS Emulator_0/ICEPICK_C] processing request pReq = 0x23121cf8, CurrentThread = 4256.
M     14:31:03:019 | cTools: Protected Target Adapter processing register id request- register IP_TAPID.
M     14:31:03:019 | cTools: Protected Target Adapter processing register id request- register IP_TAPID done.
M     14:31:03:019 | cTools: Protected Target Adapter register read pushed to Q - reg id 1.
M     14:31:03:019 | cTools: Protected Target Adapter processing read register request- reg id 1.
M     14:31:03:019 | cTools: Protected Target Adapter processing read register request- reg id 1 value 0xb7d102f done status 0.
M     14:31:03:019 | DevId: Read device ID 0xb7d102f
M     14:31:03:019 | Setup Adapter4: proc =SEED XDS560PLUS Emulator_0/ICEPICK_C id=0x3c000805
M     14:31:03:019 | Setup Adapter4: traceId=0x0
M     14:31:03:019 | Setup Adapter4: proc =SEED XDS560PLUS Emulator_0/C674X_0 id=0x50019f40
M     14:31:03:019 | DevId: XML file lookup path C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/trace_config/devices/device*.xml.
M     14:31:03:019 | DevId: device_6488.xml XML file found
M     14:31:03:035 | DevId: Mask value is 0xfffffff xmlId: 0x9202f  devId: 0xb7d102f
M     14:31:03:035 | DevId: Next device_arm9etb11.xml XML file found
M     14:31:03:035 | DevId: Mask value is 0x1ffffff xmlId: 0xb70002f  devId: 0xb7d102f
M     14:31:03:035 | DevId: Next device_armetb11_generic.xml XML file found
M     14:31:03:035 | DevId: Mask value is 0xfffffff xmlId: 0x0  devId: 0xb7d102f
M     14:31:03:035 | DevId: Next device_c64xpcetb6.xml XML file found
M     14:31:03:035 | DevId: Mask value is 0xfffffff xmlId: 0x9102f  devId: 0xb7d102f
M     14:31:03:035 | DevId: Next device_c64xptetb.xml XML file found
M     14:31:03:035 | DevId: Mask value is 0xfffffff xmlId: 0x9602f  devId: 0xb7d102f
M     14:31:03:035 | DevId: Next device_centaraus.xml XML file found
M     14:31:03:050 | DevId: Mask value is 0xfffffff xmlId: 0xb8f202f  devId: 0xb7d102f
M     14:31:03:050 | DevId: Next device_DA830XX.xml XML file found
M     14:31:03:050 | DevId: Mask value is 0xfffffff xmlId: 0xb7df02f  devId: 0xb7d102f
M     14:31:03:050 | DevId: Next device_dm648.xml XML file found
M     14:31:03:050 | DevId: Mask value is 0xfffffff xmlId: 0xb77a02f  devId: 0xb7d102f
M     14:31:03:050 | DevId: Next device_fdy.xml XML file found
M     14:31:03:066 | DevId: Mask value is 0xfffffff xmlId: 0x9202f  devId: 0xb7d102f
M     14:31:03:066 | DevId: Next device_h3g.xml XML file found
M     14:31:03:066 | DevId: Mask value is 0xfffffff xmlId: 0xb7ae02f  devId: 0xb7d102f
M     14:31:03:066 | DevId: Next device_netra.xml XML file found
M     14:31:03:066 | DevId: Mask value is 0xfffffff xmlId: 0xb81e02f  devId: 0xb7d102f
M     14:31:03:082 | DevId: Next device_omap2420.xml XML file found
M     14:31:03:082 | DevId: Mask value is 0x1ffffff xmlId: 0x1ce4801  devId: 0xb7d102f
M     14:31:03:082 | DevId: Next device_omap3430.xml XML file found
M     14:31:03:082 | DevId: Mask value is 0x1ffffff xmlId: 0xb6d602f  devId: 0xb7d102f
M     14:31:03:082 | DevId: Next device_omap4430_sdc.xml XML file found
M     14:31:03:097 | DevId: Mask value is 0xfffffff xmlId: 0xb85202f  devId: 0xb7d102f
M     14:31:03:097 | DevId: Next device_OMAPL13x.xml XML file found
M     14:31:03:097 | DevId: Mask value is 0xfffffff xmlId: 0xb7d102f  devId: 0xb7d102f
M     14:31:03:097 | DevId: Module added name: MOD_ETB0, kind:etb11, access proc:ETB11_0, version=1.0
M     14:31:03:097 | DevId: Module register added ID, ETB11_ID, , 1, 32
M     14:31:03:097 | DevId: Module register added RDP, ETB11_RDP, , 1, 32
M     14:31:03:097 | DevId: Module register added RWP, ETB11_RWP, , 1, 32
M     14:31:03:097 | DevId: Module register added STS, ETB11_STS, , 1, 32
M     14:31:03:097 | DevId: Module register added RRD, ETB11_RRD, , 1, 32
M     14:31:03:097 | DevId: Module register added RRP, ETB11_RRP, , 1, 32
M     14:31:03:097 | DevId: Module register added RWD, ETB11_RWD, , 1, 32
M     14:31:03:097 | DevId: Module register added TRG, ETB11_TRG, , 1, 32
M     14:31:03:097 | DevId: Module register added CTL, ETB11_CTL, , 1, 32
M     14:31:03:097 | DevId: Module added name: DTF, kind:DTF, access proc:, version=1.0
M     14:31:03:097 | DevId: Found a new device xml: C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin/../xmldb/trace_config/devices/device_OMAPL13x.xml that not in cache
M     14:31:03:097 | DevId: eSessionSettingDebuggerName - Code Composer Studio
M     14:31:03:097 | AETOperationServer: nGEMType value =0
M     14:31:03:097 | AETPropertyHelper: UBM property file name AET_Property64PlusPrimus.xml for CPU 67104
M     14:31:03:113 | AETPropertyHelper: Property database 0 is created.
M     14:31:03:113 | cTools: RegisterForEvents client=0x23141144 for cpunum=1
M     14:31:03:113 | AETOperationServer: Creating operation server for CPU 67104
M     14:31:03:113 | AETProperties: Operation Server # 0 is created
M     14:31:03:129 | cTools: OnTargetStateChange 1.
M     14:31:03:129 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:03:129 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/C674X_0 state change event 1
M     14:31:03:129 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/C674X_0 state change event 1
M     14:31:03:129 | Trace Server: Event broker received pre connect event for SEED XDS560PLUS Emulator_0/C674X_0 cpu
M     14:31:03:129 | cTools: OnTargetStateChange Done waitloop=1999
M     14:31:03:144 | cTools: OnTargetStateChange 7.
M     14:31:03:144 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:03:144 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/C674X_0 state change event 7
M     14:31:03:144 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/C674X_0 state change event 7
M     14:31:03:144 | Trace Server: Event broker received cpu halt event for SEED XDS560PLUS Emulator_0/C674X_0 cpu
M     14:31:03:144 | cTools: OnTargetStateChange Done waitloop=1999
M     14:31:03:597 | cTools: OnTargetStateChange 2.
M     14:31:03:597 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:03:597 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/C674X_0 state change event 2
M     14:31:03:597 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/C674X_0 state change event 2
M     14:31:03:597 | Trace Server: Event broker received connect event for SEED XDS560PLUS Emulator_0/C674X_0 cpu
M     14:31:03:597 | cTools: OnTargetStateChange Done waitloop=1999
M     14:31:03:628 | JTRACE: GetChannelServer(): Creating ChannelServer.
M     14:31:03:628 | Trace Factory: calling CreateChannelServer  m_channelServer=0x230c8a88
M     14:31:03:628 | Trace Factory: CreateChannelServer  - m_CSRefCount=3
M     14:31:03:628 | ICE CD: Register client for events - 0x1b2b33b8
M     14:31:03:644 | ICE CD: Total registered clients - 2
M     14:31:03:675 | Trace Control: OnChannelEvent for CPU=SEED XDS560PLUS Emulator_0/C674X_0 event[20] Trace CPU Added
M     14:31:03:675 | Trace Control: Getting connected CPU names
M     14:31:03:675 | JTRACE: Entering OnChannelEvent() for CPU 'SEED XDS560PLUS Emulator_0/C674X_0': Trace CPU Added
M     14:31:03:675 | Trace Control: Adding trace CPU 0: SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:03:675 | JTRACE: CTraceEventHandler::Lock(): Thread 3612 attempting to lock...
M     14:31:03:675 | JTRACE: CTraceEventHandler::Lock(): Lock obtained by thread 3612.
M     14:31:03:675 | JTRACE: OnChannelEvent(): Calling Java event handler.
M     14:31:03:675 | JTRACE: OnChannelEvent(): Returned from Java event handler.
M     14:31:03:675 | JTRACE: OnChannelEvent(): Calling DetachCurrentThread().
M     14:31:03:675 | JTRACE: OnChannelEvent(): Returned from DetachCurrentThread().
M     14:31:03:675 | JTRACE: CTraceEventHandler::Unlock(): Thread 3612 is trying to remove lock owned by thread 3612 ...
M     14:31:03:675 | Trace Control: Adding page for SEED XDS560PLUS Emulator_0/C674X_0 type=2
M     14:31:03:675 | JTRACE: CTraceEventHandler::Unlock(): Thread 3612 successfully removed lock.
M     14:31:03:675 | Trace Control: select receiver - 0 for SEED XDS560PLUS Emulator_0/C674X_0.
M     14:31:03:675 | Trace Server: Selected receiver None for cpu SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:03:675 | ICE Target Adapter Server: got si rev 5
M     14:31:03:675 | ICE Target Adapter: got si rev 5
M     14:31:03:675 | ICE Target Adapter Server: got type 67104
M     14:31:03:675 | ICE Target Adapter: got type  67104
M     14:31:03:675 | Trace Server: Tracing cpu SEED XDS560PLUS Emulator_0/C674X_0 type 67104  si rev 5
M     14:31:03:691 | Trace Control: Add page done for SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:03:691 | Trace Control: Channel Event: CPU added
M     14:31:06:894 | cTools: OnTargetStateChange 7.
M     14:31:06:894 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/C674X_0
M     14:31:06:894 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/C674X_0 state change event 7
M     14:31:06:894 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/C674X_0 state change event 7
M     14:31:06:894 | Trace Server: Event broker received cpu halt event for SEED XDS560PLUS Emulator_0/C674X_0 cpu
M     14:31:06:894 | cTools: OnTargetStateChange Done waitloop=1999
M     14:32:20:703 | cTools: OnTargetStateChange 9.
M     14:32:20:703 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/C674X_0
M     14:32:20:703 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/C674X_0 state change event 9
M     14:32:20:719 | Trace Server: Event broker received changed PC event for SEED XDS560PLUS Emulator_0/C674X_0 cpu
M     14:32:20:719 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/C674X_0 state change event 9
M     14:32:20:969 | cTools: OnTargetStateChange Done waitloop=1999
M     14:32:31:703 | cTools: OnFileDownloadComplete D:/Profiles/ams108/My Documents/workspace/datalight_dsp/Debug/test.out.
M     14:32:31:703 | ICE Target Adapter Server: On file SEED XDS560PLUS Emulator_0/C674X_0 download.
M     14:32:31:703 | ICE Target Adapter Server: Dispatched on file SEED XDS560PLUS Emulator_0/C674X_0 download.
M     14:32:32:421 | cTools: OnTargetStateChange 6.
M     14:32:32:421 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/C674X_0
M     14:32:32:421 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/C674X_0 state change event 6
M     14:32:32:421 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/C674X_0 state change event 6
M     14:32:32:421 | Trace Server: Event broker received cpu run event for SEED XDS560PLUS Emulator_0/C674X_0 cpu
M     14:32:32:421 | cTools: OnTargetStateChange Done waitloop=1999
M     14:32:32:515 | cTools: OnTargetStateChange 7.
M     14:32:32:515 | cTools: TargetEventReceived for SEED XDS560PLUS Emulator_0/C674X_0
M     14:32:32:515 | ICE Target Adapter Server: On target SEED XDS560PLUS Emulator_0/C674X_0 state change event 7
M     14:32:32:515 | ICE Target Adapter Server: Dispatched target SEED XDS560PLUS Emulator_0/C674X_0 state change event 7
M     14:32:32:515 | Trace Server: Event broker received cpu halt event for SEED XDS560PLUS Emulator_0/C674X_0 cpu
M     14:32:32:515 | cTools: OnTargetStateChange Done waitloop=1999
M     14:32:33:671 | JTRACE: Entering OnFileLoaded() for CPU 'SEED XDS560PLUS Emulator_0/C674X_0': test.out, D:/Profiles/ams108/My Documents/workspace/datalight_dsp/Debug
M     14:32:33:671 | JTRACE: CTraceEventHandler::Lock(): Thread 3612 attempting to lock...
M     14:32:33:671 | JTRACE: CTraceEventHandler::Lock(): Lock obtained by thread 3612.
M     14:32:33:671 | JTRACE: CTraceEventHandler::Unlock(): Thread 3612 is trying to remove lock owned by thread 3612 ...
M     14:32:33:671 | JTRACE: CTraceEventHandler::Unlock(): Thread 3612 successfully removed lock.
M     14:32:33:671 | ICE CD: Sending OnTargetStateHandled for SEED XDS560PLUS Emulator_0/C674X_0
M     14:32:33:671 | cTools: OnTraceOperationEnd target event handled for SEED XDS560PLUS Emulator_0/C674X_0
Do you have any idea what is happening?
Thanks in advance
Best Regards
Marcin
