Hi sir,
I am working on USB device, in the TI evaluation board it is working fine with the driver code that you had provided.
But, here the issue is when we are working on USB-2 device by using external pin connector (instead of USB-2 port as you provided in the evaluation board) without using the V-Bus concept, it is not detecting the USB device. It is showing the pop-up message as USB device is not detected.
Whether we need to change any configuration in the driver code?
Please, help us to solve this issue as early as possible.
Praveena M
