Code Composer Studio Not working
Other Parts Discussed in Thread: CCSTUDIO
The CCS V 9.3.0.00012 was working fine until yesterday. It started with not opening up the CCS existing workspace. I had to delete my CCS workspace, create a new one and import my project into the new workspace in order for CCS to work. After some time It wasn't allowing me to build or load software to the target. I have uninstall and re-install CCS  V 9.3.0.00012. The installation was successful. However now it gives me different error and it doesn't let me to build or to load. The error is:
'CrashTrackerJob' has encountered a problem.
An internal error occurred during: "CrashTrackerJob".
Could not initialize class com.ti.utility.filesystem.DirectoryService$SingletonHolder
Could you please let me know how I can solve this?
This is the content of the workspace log file:
!SESSION 2021-02-05 09:27:34.694 -----------------------------------------------
eclipse.buildId=4.8.0.I20180611-0500
java.version=1.8.0_144
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments:  -product com.ti.ccstudio.branding.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product com.ti.ccstudio.branding.product
!ENTRY org.eclipse.egit.core 2 0 2021-02-05 09:27:39.766
!MESSAGE Builtin LFS support not present/detected
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.jgit.lfs.BuiltinLFS cannot be found by org.eclipse.egit.core_5.0.0.201806131550-r
 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:508)
 at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:419)
 at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:411)
 at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
 at java.lang.ClassLoader.loadClass(Unknown Source)
 at java.lang.Class.forName0(Native Method)
 at java.lang.Class.forName(Unknown Source)
 at org.eclipse.egit.core.Activator.registerBuiltinLFS(Activator.java:279)
 at org.eclipse.egit.core.Activator.start(Activator.java:212)
 at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
 at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
 at java.security.AccessController.doPrivileged(Native Method)
 at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
 at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
 at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1002)
 at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:354)
 at org.eclipse.osgi.container.Module.doStart(Module.java:581)
 at org.eclipse.osgi.container.Module.start(Module.java:449)
 at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
 at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:114)
 at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:505)
 at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
 at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:392)
 at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
 at org.eclipse.egit.ui.Activator$RepositoryChangeScanner.<init>(Activator.java:921)
 at org.eclipse.egit.ui.Activator.setupRepoChangeScanner(Activator.java:1034)
 at org.eclipse.egit.ui.Activator.start(Activator.java:336)
 at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:470)
 at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:609)
 at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:177)
 at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:931)
 at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
 at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:60)
 at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:174)
 at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:104)
 at org.eclipse.ui.internal.Workbench$34.runWithException(Workbench.java:2378)
 at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
 at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
 at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
 at org.eclipse.swt.widgets.Display.syncExec(Display.java:4567)
 at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:95)
 at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2373)
 at org.eclipse.ui.internal.Workbench.init(Workbench.java:1654)
 at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2859)
 at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:654)
 at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
 at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
 at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
 at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
 at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
 at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
 at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
 at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
 at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
 at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
 at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
 at java.lang.reflect.Method.invoke(Unknown Source)
 at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
 at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
 at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
!ENTRY com.ti.common.core 1 0 2021-02-05 09:27:40.611
!MESSAGE path=ccs_base/DebugServer
!MESSAGE debugServerDir=C:/ti/ccs930/ccs/ccs_base/DebugServer
!ENTRY org.eclipse.equinox.event 4 0 2021-02-05 09:27:46.524
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] {ChangedElement=org.eclipse.e4.primaryDataStack=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@48188d23 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@5d9d8ecf, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.primaryDataStack=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@48188d23 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@5d9d8ecf, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized}, AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@64710a6
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException:
 at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
 at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:64)
 at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:212)
 at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:61)
 at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
 at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:196)
 at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
 at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
 at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
 at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
 at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
 at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
 at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
 at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
 at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
 at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:304)
 at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:304)
 at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:200)
 at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:138)
 at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:190)
 at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:572)
 at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:782)
 at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
 at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1005)
 at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:137)
 at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:93)
 at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:74)
 at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1507)
 at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1478)
 at com.ti.ccstudio.debug.ui.targetStatus.TargetStatusManager.addStatusBar(TargetStatusManager.java:379)
 at com.ti.ccstudio.debug.ui.targetStatus.statusBar.TargetStatusBar.fill(TargetStatusBar.java:44)
 at com.ti.ccstudio.debug.ui.targetStatus.statusBar.CCSStatusBar.createControl(CCSStatusBar.java:39)
 at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:105)
 at org.eclipse.ui.internal.menus.CompatibilityWorkbenchWindowControlContribution.construct(CompatibilityWorkbenchWindowControlContribution.java:90)
 at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:412)
 at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:345)
 at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:214)
 at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:108)
 at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
 at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:51)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlContribution.createControl(ToolControlContribution.java:53)
 at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:101)
 at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:343)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.subscribeTopicUpdateToBeRendered(ToolBarManagerRenderer.java:213)
 at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
 at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:346)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarContributionRecord.updateVisibility(ToolBarContributionRecord.java:71)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$2.changed(ToolBarManagerRenderer.java:479)
 at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
 at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:344)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processAddition(ToolBarManagerRenderer.java:471)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.generateContributions(ToolBarManagerRenderer.java:447)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContribution(ToolBarManagerRenderer.java:416)
 at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createWidget(ToolBarManagerRenderer.java:376)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:1012)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:672)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:778)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:749)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:743)
 at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:727)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(PartRenderingEngine.java:308)
 at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
 at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:88)
 at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
 at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:340)
 at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.processAddition(ContributionsAnalyzer.java:441)
 at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.addTrimContributions(TrimBarRenderer.java:164)
 at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:136)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:686)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:557)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:541)
 at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:722)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1096)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
 at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
 at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
Caused by: java.lang.IllegalArgumentException:
 at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
 at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
 at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:160)
 at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:411)
 at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:397)
 at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getActivePerspective(ModelServiceImpl.java:976)
 at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.getElementsToMinimize(MinMaxAddon.java:719)
 at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.maximize(MinMaxAddon.java:690)
 at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:381)
 at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
 ... 150 more
!ENTRY org.eclipse.launchbar.core 2 0 2021-02-05 09:27:46.777
!MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.core.net 4 0 2021-02-05 09:27:46.824
!MESSAGE WinHttp.GetProxyForUrl for pac failed with error 'The handle is invalid.
' #6.
!ENTRY org.eclipse.launchbar.core 2 0 2021-02-05 09:27:46.824
!MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.osgi 4 0 2021-02-05 09:27:46.863
!MESSAGE An error occurred while automatically activating bundle com.ti.ccstudio.errorreporting (59).
!STACK 0
org.osgi.framework.BundleException: Exception in com.ti.ccstudio.errorreporting.ErrorReportingPlugin.start() of bundle com.ti.ccstudio.errorreporting.
 at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
 at org.eclipse.ui.internal.WorkbenchPlugin.lambda$0(WorkbenchPlugin.java:288)
 at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:54)
 at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:285)
 at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:53)
 at org.eclipse.ui.internal.Workbench$40.run(Workbench.java:2758)
 at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
Caused by: java.lang.UnsatisfiedLinkError: C:\ti\ccs930\ccs\ccs_base\DebugServer\bin\LibraryLoader.dll: Can't find dependent libraries
 at java.lang.ClassLoader$NativeLibrary.load(Native Method)
 at java.lang.ClassLoader.loadLibrary0(Unknown Source)
 at java.lang.ClassLoader.loadLibrary(Unknown Source)
 at java.lang.Runtime.load0(Unknown Source)
 at java.lang.System.load(Unknown Source)
 at com.ti.debug.engine.xpcom.Runtime.preXPCOMInit(Runtime.java:163)
 at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:116)
 at com.ti.debug.engine.xpcom.Runtime.createComponent(Runtime.java:170)
 at com.ti.utility.filesystem.DirectoryService.<init>(DirectoryService.java:26)
 at com.ti.utility.filesystem.DirectoryService.<init>(DirectoryService.java:9)
 at com.ti.utility.filesystem.DirectoryService$SingletonHolder.<clinit>(DirectoryService.java:44)
 at com.ti.utility.filesystem.DirectoryService.instance(DirectoryService.java:49)
 at com.ti.ccstudio.errorreporting.ErrorReportJob.<init>(ErrorReportJob.java:41)
 at com.ti.ccstudio.errorreporting.ErrorReportingPlugin.startCrashTracker(ErrorReportingPlugin.java:56)
 at com.ti.ccstudio.errorreporting.ErrorReportingPlugin.singletonInit(ErrorReportingPlugin.java:39)
 at com.ti.common.ui.BaseTIUIPlugin.start(BaseTIUIPlugin.java:44)
 ... 27 more
Root exception:
!ENTRY org.eclipse.ui.workbench 4 2 2021-02-05 09:27:46.868
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.ti.ccstudio.errorreporting was unable to load class com.ti.ccstudio.errorreporting.ErrorDialogStartup.
 at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:197)
 at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:179)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle com.ti.ccstudio.errorreporting (59).
 at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:123)
 ... 10 more
Caused by: org.osgi.framework.BundleException: Exception in com.ti.ccstudio.errorreporting.ErrorReportingPlugin.start() of bundle com.ti.ccstudio.errorreporting.
 ... 20 more
 ... 27 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2021-02-05 09:27:46.869
!MESSAGE Plug-in com.ti.ccstudio.errorreporting was unable to load class com.ti.ccstudio.errorreporting.ErrorDialogStartup.
!STACK 0
 ... 20 more
 ... 27 more
!STACK 0
 ... 20 more
 ... 27 more
!ENTRY org.eclipse.ui 4 0 2021-02-05 09:27:46.874
!MESSAGE Unable to execute early startup code for the org.eclipse.ui.IStartup extension contributed by the 'com.ti.ccstudio.errorreporting' plug-in.
!STACK 1
 ... 10 more
 ... 20 more
 ... 27 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2021-02-05 09:27:46.875
!STACK 0
 ... 20 more
 ... 27 more
!ENTRY com.ti.ccstudio.webcontent 4 0 2021-02-05 09:27:48.230
!MESSAGE C:\ti\ccs930\ccs\ccs_base\DebugServer\bin\ti_xpcom.dll: Can't find dependent libraries
!STACK 0
java.lang.UnsatisfiedLinkError: C:\ti\ccs930\ccs\ccs_base\DebugServer\bin\ti_xpcom.dll: Can't find dependent libraries
 at com.ti.xpcom.internal.JavaXPCOMMethods.registerJavaXPCOMMethods(JavaXPCOMMethods.java:53)
 at com.ti.xpcom.internal.MozillaImpl.initialize(MozillaImpl.java:52)
 at com.ti.xpcom.Mozilla.initialize(Mozilla.java:124)
 at com.ti.debug.engine.xpcom.Runtime.startBare(Runtime.java:122)
 at com.ti.logger.impl.DSLogger.<init>(DSLogger.java:27)
 at com.ti.logger.impl.DSLogger.instance(DSLogger.java:41)
 at com.ti.logger.impl.DSLogger.getLogger(DSLogger.java:54)
 at com.ti.cloudagent.Agent.instance(Agent.java:41)
 at com.ti.ccstudio.webcontent.cloudagent.CloudAgent.getAgent(CloudAgent.java:33)
 at com.ti.ccstudio.webcontent.cloudagent.CloudAgent.<init>(CloudAgent.java:22)
 at com.ti.ccstudio.webcontent.cloudagent.CloudAgent.<clinit>(CloudAgent.java:18)
 at com.ti.ccstudio.webcontent.internal.ABrowserExtension.init(ABrowserExtension.java:29)
 at com.ti.ccstudio.webcontent.cloudagent.CloudAgentBrowserExtension.init(CloudAgentBrowserExtension.java:24)
 at com.ti.ccstudio.webcontent.internal.CommonBrowserExtensionContributor.init(CommonBrowserExtensionContributor.java:29)
 at com.ti.browser.internal.TIBrowser$1.run(TIBrowser.java:100)
 at com.ti.chromium.browser.JxBrowser$3.onScriptContextCreated(JxBrowser.java:343)
 at com.teamdev.jxbrowser.chromium.Browser$d.b(SourceFile:3647)
 at com.teamdev.jxbrowser.chromium.Browser$d.onMessageReceived(SourceFile:5616)
 at com.teamdev.jxbrowser.chromium.internal.ipc.q.a(SourceFile:1084)
 at com.teamdev.jxbrowser.chromium.internal.ipc.r.run(SourceFile:68)
 at com.teamdev.jxbrowser.chromium.internal.r.run(SourceFile:79)
 at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
 at java.util.concurrent.FutureTask.run(Unknown Source)
 at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
 at java.lang.Thread.run(Unknown Source)
!ENTRY com.ti.ccstudio.webcontent 4 0 2021-02-05 09:27:48.240
!MESSAGE com.ti.xpcom.internal.XPCOMImpl.getComponentManager()Lcom/ti/xpcom/interfaces/nsIComponentManager;
!STACK 0
java.lang.UnsatisfiedLinkError: com.ti.xpcom.internal.XPCOMImpl.getComponentManager()Lcom/ti/xpcom/interfaces/nsIComponentManager;
 at com.ti.xpcom.internal.XPCOMImpl.getComponentManager(Native Method)
 at com.ti.xpcom.Mozilla.getComponentManager(Mozilla.java:141)
 at com.ti.debug.engine.xpcom.Runtime.createComponent(Runtime.java:179)
!STACK 0
 at com.ti.ccstudio.webcontent.cloudagent.CloudAgent.getAgentPort(CloudAgent.java:26)
 at com.ti.ccstudio.webcontent.cloudagent.CloudAgentBrowserExtension.init(CloudAgentBrowserExtension.java:27)
!STACK 0
 at com.ti.ccstudio.webcontent.internal.DebugUIBrowserExtension.init(DebugUIBrowserExtension.java:110)
 at com.ti.ccstudio.webcontent.internal.CommonBrowserExtensionContributor.init(CommonBrowserExtensionContributor.java:30)
