CCS crashes when using "ctrl +Left"
My customers are debugging with CCS and their CCS crashes when using "ctrl + left" for "Previous word".
My customers use CCSv7 and CCSv9, both of which have this problem as well.
Is there a way to avoid this crash?
Sasaki
  • Sasaki-san,
    I am unable to reproduce this crash using CCSv9.3.
    Can you have the customer try cleaning the workspace?
    https://software-dl.ti.com/ccs/esd/documents/users_guide/ccs_troubleshooting.html#clean-the-workspace-or-try-using-a-new-one
    If that does not help, could you obtain the Eclipse error log from the customer and attach it to this thread? The log can be found in: <WORKSPACE FOLDER>/.metadata/.log
    Thank you
    ki
  • Hi Ki-san,
    Thank you for your reply.
    Ki said:
    My customer have tried this, but the problem has not improved.
    I've attached the log files of my customer.
    Please give me some advice on how to improve it.
    !SESSION 2021-02-24 11:34:54.086 -----------------------------------------------
    eclipse.buildId=4.6.0.I20160606-1100
    java.version=1.8.0_112
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ja_JP
    Framework arguments:  -product com.ti.ccstudio.branding.product
    Command-line arguments:  -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
    !ENTRY com.ti.common.core 4 0 2021-02-24 11:34:57.588
    !MESSAGE path=ccs_base/DebugServer
    !ENTRY com.ti.common.core 4 0 2021-02-24 11:34:57.592
    !MESSAGE debugServerDir=C:/ti/ccsv7/ccs_base/DebugServer
    !ENTRY org.eclipse.equinox.event 4 0 2021-02-24 11:34:59.540
    !MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c422d3 (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@1d55a46, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c422d3 (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@1d55a46, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized}, AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@4e63b3
    !STACK 0
    org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException:
    	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:64)
    	at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
    	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
    	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
    	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4813)
    	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
    	at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
    	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
    	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
    	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
    	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
    	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
    	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
    	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
    	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
    	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
    	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
    	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
    	at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
    	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:304)
    	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
    	at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:196)
    	at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:134)
    	at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:190)
    	at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:567)
    	at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:776)
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    	at java.lang.reflect.Method.invoke(Method.java:498)
    	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:54)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:118)
    	at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
    	at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1525)
    	at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1499)
    	at com.ti.ccstudio.debug.ui.targetStatus.TargetStatusManager.addStatusBar(TargetStatusManager.java:379)
    	at com.ti.ccstudio.debug.ui.targetStatus.statusBar.TargetStatusBar.fill(TargetStatusBar.java:44)
    	at com.ti.ccstudio.debug.ui.targetStatus.statusBar.CCSStatusBar.createControl(CCSStatusBar.java:39)
    	at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:105)
    	at org.eclipse.ui.internal.menus.CompatibilityWorkbenchWindowControlContribution.construct(CompatibilityWorkbenchWindowControlContribution.java:90)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
    	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:308)
    	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
    	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:108)
    	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
    	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:51)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlContribution.createControl(ToolControlContribution.java:58)
    	at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:101)
    	at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:343)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.subscribeTopicUpdateToBeRendered(ToolBarManagerRenderer.java:213)
    	at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
    	at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:345)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarContributionRecord.updateVisibility(ToolBarContributionRecord.java:74)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$5.changed(ToolBarManagerRenderer.java:479)
    	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
    	at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:324)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processAddition(ToolBarManagerRenderer.java:471)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.generateContributions(ToolBarManagerRenderer.java:447)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContribution(ToolBarManagerRenderer.java:413)
    	at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createWidget(ToolBarManagerRenderer.java:373)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
    	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(PartRenderingEngine.java:296)
    	at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
    	at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:80)
    	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
    	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:341)
    	at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.processAddition(ContributionsAnalyzer.java:370)
    	at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.addTrimContributions(TrimBarRenderer.java:171)
    	at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:143)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
    	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:747)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
    	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
    	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
    	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
    	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
    	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
    	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
    	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
    	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
    	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
    	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
    	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
    Caused by: java.lang.IllegalArgumentException:
    	at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
    	at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:145)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:394)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:380)
    	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getActivePerspective(ModelServiceImpl.java:959)
    	at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.getElementsToMinimize(MinMaxAddon.java:680)
    	at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.maximize(MinMaxAddon.java:655)
    	at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:363)
    	at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
    	... 150 more
    !ENTRY com.ti.ccstudio.debug.server 4 214294189 2021-02-24 11:35:01.721
    !MESSAGE Unexpected CCS exit detected [21/02/24 11:30]!!!
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:02.292
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/artifacts.xml
    !STACK 1
    org.eclipse.ecf.filetransfer.BrowseFileTransferException: Proxy Authentication Required
    	at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:291)
    	at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
    	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:02.293
    !MESSAGE Proxy Authentication Required
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:02.490
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/artifacts.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:02.490
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:02.668
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:02.668
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:02.717
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:02.717
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:03.020
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:03.021
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:03.206
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:03.206
    !ENTRY org.eclipse.equinox.p2.core 4 0 2021-02-24 11:35:03.211
    !MESSAGE Unable to load repositories.
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:03.257
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/ccs/non-esd/dvt/ccs6.0/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:03.257
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:03.895
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/ccs/esd/CCSv7/Updates/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:03.895
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.000
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.000
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.031
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.0/all_extras_repo/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.032
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.180
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.181
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.241
    !MESSAGE HTTP Proxy Authentication Required: http://www.blackhawk-dsp.com/updates/ccsv53/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.241
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.333
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/artifacts.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.333
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.612
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.613
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.794
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.795
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:04.999
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:04.999
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:05.152
    !MESSAGE HTTP Proxy Authentication Required: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/content.xml
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:05.152
    !ENTRY org.eclipse.equinox.p2.core 4 0 2021-02-24 11:35:05.157
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:05.791
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:05.791
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:05.945
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:05.945
    !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2021-02-24 11:35:06.124
    !STACK 1
    !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2021-02-24 11:35:06.125
    !ENTRY org.eclipse.equinox.p2.core 4 0 2021-02-24 11:35:06.131
    !ENTRY org.eclipse.cdt.core 1 0 2021-02-24 11:35:27.250
    !MESSAGE Indexed 'SMPExample1_CortexA' (1 sources, 0 headers) in 0.203 sec: 41 declarations; 83 references; 13 unresolved inclusions; 0 syntax errors; 62 unresolved names (33%)
    !ENTRY org.eclipse.cdt.core 1 0 2021-02-24 11:35:36.947
    !MESSAGE Indexed 'rtos_template_app_am572x_a15' (5 sources, 359 headers) in 9.33 sec: 29,805 declarations; 46,147 references; 34 unresolved inclusions; 7 syntax errors; 175 unresolved names (0.23%)
    !ENTRY org.eclipse.cdt.core 1 0 2021-02-24 11:35:45.457
    !MESSAGE Indexed 'rtos_template_app_am572x_a15_smp' (5 sources, 378 headers) in 8.49 sec: 31,288 declarations; 49,816 references; 33 unresolved inclusions; 7 syntax errors; 177 unresolved names (0.22%)
    !ENTRY org.eclipse.cdt.core 1 0 2021-02-24 11:35:52.925
    !MESSAGE Indexed 'rtos_template_app_am572x_c66' (5 sources, 333 headers) in 7.44 sec: 26,925 declarations; 41,511 references; 0 unresolved inclusions; 2,699 syntax errors; 596 unresolved names (0.86%)
    !ENTRY org.eclipse.cdt.core 1 0 2021-02-24 11:36:03.512
    !MESSAGE Indexed 'sample3_ARM3' (9 sources, 533 headers) in 10.6 sec: 49,365 declarations; 96,897 references; 33 unresolved inclusions; 9 syntax errors; 272 unresolved names (0.19%)
    !ENTRY org.eclipse.cdt.core 1 0 2021-02-24 11:36:12.698
    !MESSAGE Indexed 'sample3_DSP' (7 sources, 436 headers) in 9.16 sec: 39,116 declarations; 78,767 references; 42 unresolved inclusions; 4,395 syntax errors; 1,385 unresolved names (1.2%)
    Sasaki
  • Thank you for the log. Unfortunately there was not any information in there that was helpful for this analysis.
    Is it only "previous word" that causes the crash? Do all the other keyboard shortcut actions work fine? Does "next word" (CTRL+Right) work without issue?
  • Ki-san,
    Thank you for your support.
    There was an error in my previous question. I'm sorry.
    My customer's CCS crashes when running "Ctrl + left click". However, when they use F3 instead of "Ctrl + left click", the problem did not occur.
    Do you know why CCS crashes with "Ctrl + left click"?
    CCS does not crash with any other command.
    Sasaki
  • Sasaki-san
    Thank you for the clarification.
    I am still unable to reproduce the error. CCS will successfully open the hyperlink in a new editor tab in CCS. I tried this with CCS 7.4 and 9.3.
    On what exactly is the customer trying to use the common on? (ex. #include statement? variable? macro?, etc). Does the crash happen everytime for everything?
    It may also be helpful if the customer can provide the source file (and what the customer is trying to . It can be a modified source file to protect sensitive information. I just need a file that the customer can reproduce the issue on, and what they are trying to open declaration on
    ki
  • Ctrl click is a mac thing. Is this on a Mac?
  • Hi Ki-san,
    My customers want to see functions and variables with this Ctrl+click.
    I also couldn't reproduce this problem. Probably a problem with the customer's PC, so ask the customer to try reinstalling CCS.
    If the problem persists after reinstalling, I'll ask you again, so please close this thread.
    Sasaki
  • Keith-san,
    No, this is on windows.
    You can use Ctrl click  on functions and variables in Windows to jump to those references.
    Sasaki
  • Sasaki-san
    Yes, it appears specific to his PC. It could be a corrupted CCS installation. A re-installation may help here. Just make sure the customer installs CCS in a clean (empty) directory. They may also what to consider installing the latest CCS 10.2.0 if possible.
    Thank you
    ki
