When I try to install CCS I keep getting the following message :
Error running C:/Users/sbmorrison/AppData/Local/Temp/ccs_89e60924-ac43-4463-4061-15a4065dc6c5/DMED/ti_cgt_dmed_1.1.6_windows_installer.exe --prefix "C:\ti\ccs1011/ccs" --eclipseprefix "C:/ti/ccs1011/ccs/eclipse" --mode unattended --installer-log "C:\ti\ccs1011/ccs/install_logs/20210325091651" --ccs true: Program ended with an error exit code
[09:24:14] CCS_ERROR: Unable to install executable C:/Users/sbmorrison/AppData/Local/Temp/ccs_89e60924-ac43-4463-4061-15a4065dc6c5/DMED/ti_cgt_dmed_1.1.6_windows_installer.exe: Error running C:/Users/sbmorrison/AppData/Local/Temp/ccs_89e60924-ac43-4463-4061-15a4065dc6c5/DMED/ti_cgt_dmed_1.1.6_windows_installer.exe --prefix "C:\ti\ccs1011/ccs" --eclipseprefix "C:/ti/ccs1011/ccs/eclipse" --mode unattended --installer-log "C:\ti\ccs1011/ccs/install_logs/20210325091651" --ccs true: Program ended with an error exit code: 1
[09:24:14] CCS_WARNING: Found C:\ti\ccs1011\ccs\install_logs\dmed_install.log, component installer needs to be updated.
[09:24:14] CCS_INFO: In installationAbortedActionList
[09:24:17] CCS_ERROR: Code Composer Studio 10.1.1.00004 failed to install.
[09:24:17] CCS_INFO: Downloading software-dl.ti.com/.../CCS10.1.1.00004_tia_windows_failed_offline.zip
[09:24:18] CCS_INFO: Return values from downloadMarker software-dl.ti.com/.../CCS10.1.1.00004_tia_windows_failed_offline.zip: 200
[09:24:18] CCS_INFO: Deleting C:\ti\ccs1011/ccs? : !false
[09:24:26] Moving logfile to C:\ti\ccs1011/ccs/install_logs/20210325091651/ccs_install_10.1.1.00004.log
Any insights you have would be appreciated.
Scott
