Part Number: CC3235SF
The problem arises when the json object has two consecutive strings and the first is null. The library is unable to parse the next object value.
I reproduced the problem using the json_app example provided with the simplelink_cc32xx_sdk_4_40_00_07.
This example uses three jsons they are very similar. But only two of them give the right value to the key "lk".
The first is the original json, it has a key named "kp" wich value is null before the key "lk" with value "AB0123456789".
,\"wm\":0,\"kp\":null,\"lk\":\"AB0123456789\", ---> the query "lk" returns null
in the second json The "kp" key has a value and the library is able to retun the value of "lk".
\"wm\":0,\"kp\":\"AB0123456789\",\"lk\":\"AB0123456789\",\"ot\":1}"; the query "lk" returns AB0123456789
The third json is identical to the first one but the order of keys is changed, "kp\":null,\"wm\":0,\"lk\":\"AB0123456789\". So it seems that when the strings are together and the first value is null the seccond value is also asumed null.
\"kp\":null,\"wm\":0,\"lk\":\"AB0123456789\", --->
void TestNull()
char lk[15] = "";
templateSize = 215;
templateBuff.fileBuffer =
"{\"act\":boolean,\"id\":int32,\"fn\":string,\"ex\":int32,\"us\":int32,\"nm\":boolean,\"st\":int32,\"phid\":string,\"dw\":[int32],\"fc\":[int32],\"fm\":int32,\"pn\":string,\"to\":int32,\"dm\":int32,\"wm\":int32,\"kp\":string,\"lk\":string,\"ot\":int32}";
jsonBuffer.fileBuffer =
"{\"act\":true,\"id\":2,\"fn\":\"schrule\",\"ex\":1766172800,\"us\":7,\"nm\":true,\"st\":1566172800,\"phid\":null,\"dw\":[0,1,2,3,4,5,6],\"fc\":[0,1,0],\"fm\":80,\"pn\":null,\"to\":1400,\"dm\":0,\"wm\":0,\"kp\":null,\"lk\":\"AB0123456789\",\"ot\":1}";
createTemplate();
createObject();
parse();
getStringValue(jsonObjHandle, "\"lk\"", lk);
destroyJsonObject();
"{\"act\":true,\"id\":2,\"fn\":\"schrule\",\"ex\":1766172800,\"us\":7,\"nm\":true,\"st\":1566172800,\"phid\":null,\"dw\":[0,1,2,3,4,5,6],\"fc\":[0,1,0],\"fm\":80,\"pn\":null,\"to\":1400,\"dm\":0,\"wm\":0,\"kp\":\"AB0123456789\",\"lk\":\"AB0123456789\",\"ot\":1}";
createObject();
parse();
"{\"act\":true,\"id\":2,\"fn\":\"schrule\",\"ex\":1766172800,\"us\":7,\"nm\":true,\"st\":1566172800,\"phid\":null,\"dw\":[0,1,2,3,4,5,6],\"fc\":[0,1,0],\"fm\":80,\"pn\":null,\"to\":1400,\"dm\":0,\"kp\":null,\"wm\":0,\"lk\":\"AB0123456789\",\"ot\":1}";
createObject();
parse();
destroyTemplate();
