Other Parts Discussed in Thread: TIDA-01494, , INA181, PMP20873, PMP22220
Good Day. I suggest to them some of reference design for their query.
Good Day. Is there any update on our customer's query. Thank you very much.
Ray Vincent
Good Day. My post is from 2 days ago yet there is no response. Thank you very much.
Ray Vincent
Good Day. My post is about 11 days ago yet I haven't receive any response from your team. Please help to check. Thank you very much.
Ray Vincent
Ray Vincent,
Sorry for my very late reply. To modify PMP11282 or TIDA-01494 for battery charger application (Assuming required Vout,max/Vout,min >2) would need to redesign the power stage especially the ratio of transformer magnetizing inductance to series resonant inductor ratio and likely the transformer turns ratio.
Sheng-Yang Yu
Hi Sheng-yang,
Good Day. Please see below the response of our customer to your reply. Thank you very much.
Ray Vincent
Hi Sheng-yang,
Good Day. Is there any update on the latest query of the customer? Thank you very much.
Ray Vincent
Hi Sheng-yang,
Good Day. Any response on the latest query of the customer? Thank you very much.
Ray Vincent
See my answer below:
(a) PMP11282 isn't designed for variable output voltage application (ex: battery charging). TIDA-01494 has constant current control loop and allows 22V-28V output voltage range.
(b) My understanding is INA181 only amplify current sensing signal, itself doesn't provide overcurrent protection.
(c) Because input current is higher at 100Vac, PFC stage efficiency drops a lot. So you want to improve PFC stage efficiency. The efficiency difference you are talking about is greater than 3%. I do believe you will need to use either AC-switch bridgeless PFC like PMP22220 or TTPL bridgeless PFC like PMP20873.
Sheng-Yang Yu
