PSPICE-FOR-TI: PSPICE-FOR-TI
Part Number: PSPICE-FOR-TI
Hello Support
Installation error.
Error log attached.
Thanks.
Best wishes
3:54:33 PM Wednesday, 6 October, 2021 : parameter count = 1
3:54:33 PM Wednesday, 6 October, 2021 : -wrapper
3:54:33 PM Wednesday, 6 October, 2021 : Initializing
3:54:33 PM Wednesday, 6 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
3:54:34 PM Wednesday, 6 October, 2021 : Response Content length = 1724
3:54:34 PM Wednesday, 6 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
3:54:34 PM Wednesday, 6 October, 2021 : Reading Json URL File
3:54:34 PM Wednesday, 6 October, 2021 : setting media download server URL from Json File
3:54:34 PM Wednesday, 6 October, 2021 : setting Dll path from Json File
3:54:34 PM Wednesday, 6 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
3:54:34 PM Wednesday, 6 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
3:54:35 PM Wednesday, 6 October, 2021 : parameter count = 1
3:54:35 PM Wednesday, 6 October, 2021 : -wrapper
3:54:36 PM Wednesday, 6 October, 2021 : ReleaseVersion in XML: 17.40.007 InstalledVersion on system:
3:55:38 PM Wednesday, 6 October, 2021 : An exception occured which is causing the program to close.
3:55:38 PM Wednesday, 6 October, 2021 : Details of exception are : Unable to load DLL 'cdsVbl.dll': The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
3:55:38 PM Wednesday, 6 October, 2021 : Stack Trace for the exception is    at TIPSpice.Utilities.cdsVblRegisterInstallation(String productKey, String bundleName, String chwsUrl)
   at TIPSpice.Utilities.RegisterInstallation(String ProdKey)
   at TIPSpice.AuthWindow.AuthenticateUser()
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.Controls.Primitives.ButtonBase.OnClick()
   at System.Windows.Controls.Button.OnClick()
   at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at TIPSpice.App.Main()
3:55:38 PM Wednesday, 6 October, 2021 : Message: An error occurred and PSpice for TI needs to close.
Refer to cdsPspiceTIlog.txt at C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall for error details.
3:56:17 PM Wednesday, 6 October, 2021 : parameter count = 1
3:56:17 PM Wednesday, 6 October, 2021 : -wrapper
3:56:17 PM Wednesday, 6 October, 2021 : Initializing
3:56:17 PM Wednesday, 6 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
3:56:17 PM Wednesday, 6 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
3:56:18 PM Wednesday, 6 October, 2021 : Response Content length = 1724
3:56:18 PM Wednesday, 6 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
3:56:18 PM Wednesday, 6 October, 2021 : Reading Json URL File
3:56:18 PM Wednesday, 6 October, 2021 : setting media download server URL from Json File
3:56:18 PM Wednesday, 6 October, 2021 : setting Dll path from Json File
3:56:18 PM Wednesday, 6 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
3:56:18 PM Wednesday, 6 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
3:56:18 PM Wednesday, 6 October, 2021 : parameter count = 1
3:56:18 PM Wednesday, 6 October, 2021 : -wrapper
3:56:19 PM Wednesday, 6 October, 2021 : ReleaseVersion in XML: 17.40.007 InstalledVersion on system:
3:57:02 PM Wednesday, 6 October, 2021 : An exception occured which is causing the program to close.
3:57:02 PM Wednesday, 6 October, 2021 : Details of exception are : Unable to load DLL 'cdsVbl.dll': The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
3:57:02 PM Wednesday, 6 October, 2021 : Stack Trace for the exception is    at TIPSpice.Utilities.cdsVblRegisterInstallation(String productKey, String bundleName, String chwsUrl)
3:57:02 PM Wednesday, 6 October, 2021 : Message: An error occurred and PSpice for TI needs to close.
3:59:35 PM Wednesday, 6 October, 2021 : parameter count = 1
3:59:35 PM Wednesday, 6 October, 2021 : -wrapper
3:59:35 PM Wednesday, 6 October, 2021 : Initializing
3:59:35 PM Wednesday, 6 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
3:59:35 PM Wednesday, 6 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
3:59:35 PM Wednesday, 6 October, 2021 : Response Content length = 1724
3:59:35 PM Wednesday, 6 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
3:59:35 PM Wednesday, 6 October, 2021 : Reading Json URL File
3:59:35 PM Wednesday, 6 October, 2021 : setting media download server URL from Json File
3:59:35 PM Wednesday, 6 October, 2021 : setting Dll path from Json File
3:59:35 PM Wednesday, 6 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
3:59:35 PM Wednesday, 6 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
3:59:36 PM Wednesday, 6 October, 2021 : parameter count = 1
3:59:36 PM Wednesday, 6 October, 2021 : -wrapper
3:59:36 PM Wednesday, 6 October, 2021 : ReleaseVersion in XML: 17.40.007 InstalledVersion on system:
4:00:36 PM Wednesday, 6 October, 2021 : An exception occured which is causing the program to close.
4:00:36 PM Wednesday, 6 October, 2021 : Details of exception are : Unable to load DLL 'cdsVbl.dll': The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
4:00:36 PM Wednesday, 6 October, 2021 : Stack Trace for the exception is    at TIPSpice.Utilities.cdsVblRegisterInstallation(String productKey, String bundleName, String chwsUrl)
4:00:36 PM Wednesday, 6 October, 2021 : Message: An error occurred and PSpice for TI needs to close.
4:02:26 PM Wednesday, 6 October, 2021 : Message: Another instance of this installation is in progress. Close or complete that instance, and then launch the installer.
4:02:35 PM Wednesday, 6 October, 2021 : parameter count = 0
4:02:35 PM Wednesday, 6 October, 2021 : Initializing
4:02:35 PM Wednesday, 6 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
4:02:35 PM Wednesday, 6 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
4:02:36 PM Wednesday, 6 October, 2021 : Response Content length = 1724
4:02:36 PM Wednesday, 6 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
4:02:36 PM Wednesday, 6 October, 2021 : Reading Json URL File
4:02:36 PM Wednesday, 6 October, 2021 : setting media download server URL from Json File
4:02:36 PM Wednesday, 6 October, 2021 : setting Dll path from Json File
4:02:36 PM Wednesday, 6 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
4:02:36 PM Wednesday, 6 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
4:02:36 PM Wednesday, 6 October, 2021 : Wrapper Not Found..Exiting Installation
4:02:41 PM Wednesday, 6 October, 2021 : parameter count = 0
4:02:41 PM Wednesday, 6 October, 2021 : Initializing
4:02:41 PM Wednesday, 6 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
4:02:41 PM Wednesday, 6 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
4:02:41 PM Wednesday, 6 October, 2021 : Response Content length = 1724
4:02:41 PM Wednesday, 6 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
4:02:41 PM Wednesday, 6 October, 2021 : Reading Json URL File
4:02:41 PM Wednesday, 6 October, 2021 : setting media download server URL from Json File
4:02:41 PM Wednesday, 6 October, 2021 : setting Dll path from Json File
4:02:41 PM Wednesday, 6 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
4:02:41 PM Wednesday, 6 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
4:02:41 PM Wednesday, 6 October, 2021 : Wrapper Not Found..Exiting Installation
4:02:43 PM Wednesday, 6 October, 2021 : parameter count = 0
4:02:43 PM Wednesday, 6 October, 2021 : Initializing
4:02:43 PM Wednesday, 6 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
4:02:43 PM Wednesday, 6 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
4:02:44 PM Wednesday, 6 October, 2021 : Response Content length = 1724
4:02:44 PM Wednesday, 6 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
4:02:44 PM Wednesday, 6 October, 2021 : Reading Json URL File
4:02:44 PM Wednesday, 6 October, 2021 : setting media download server URL from Json File
4:02:44 PM Wednesday, 6 October, 2021 : setting Dll path from Json File
4:02:44 PM Wednesday, 6 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
4:02:44 PM Wednesday, 6 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
4:02:44 PM Wednesday, 6 October, 2021 : Wrapper Not Found..Exiting Installation
9:44:59 AM Thursday, 7 October, 2021 : parameter count = 1
9:44:59 AM Thursday, 7 October, 2021 : -wrapper
9:44:59 AM Thursday, 7 October, 2021 : Initializing
9:44:59 AM Thursday, 7 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
9:44:59 AM Thursday, 7 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
9:45:00 AM Thursday, 7 October, 2021 : Response Content length = 1724
9:45:00 AM Thursday, 7 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
9:45:00 AM Thursday, 7 October, 2021 : Reading Json URL File
9:45:00 AM Thursday, 7 October, 2021 : setting media download server URL from Json File
9:45:00 AM Thursday, 7 October, 2021 : setting Dll path from Json File
9:45:00 AM Thursday, 7 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
9:45:00 AM Thursday, 7 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
9:45:00 AM Thursday, 7 October, 2021 : parameter count = 1
9:45:00 AM Thursday, 7 October, 2021 : -wrapper
9:45:03 AM Thursday, 7 October, 2021 : ReleaseVersion in XML: 17.40.007 InstalledVersion on system:
9:46:24 AM Thursday, 7 October, 2021 : An exception occured which is causing the program to close.
9:46:24 AM Thursday, 7 October, 2021 : Details of exception are : Unable to load DLL 'cdsVbl.dll': The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
9:46:24 AM Thursday, 7 October, 2021 : Stack Trace for the exception is    at TIPSpice.Utilities.cdsVblRegisterInstallation(String productKey, String bundleName, String chwsUrl)
9:46:24 AM Thursday, 7 October, 2021 : Message: An error occurred and PSpice for TI needs to close.
12:01:40 PM Thursday, 7 October, 2021 : parameter count = 0
12:01:40 PM Thursday, 7 October, 2021 : Initializing
12:01:40 PM Thursday, 7 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
12:01:40 PM Thursday, 7 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
12:01:42 PM Thursday, 7 October, 2021 : Response Content length = 1724
12:01:42 PM Thursday, 7 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
12:01:42 PM Thursday, 7 October, 2021 : Reading Json URL File
12:01:42 PM Thursday, 7 October, 2021 : setting media download server URL from Json File
12:01:42 PM Thursday, 7 October, 2021 : setting Dll path from Json File
12:01:42 PM Thursday, 7 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
12:01:42 PM Thursday, 7 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
12:01:42 PM Thursday, 7 October, 2021 : Wrapper Not Found..Exiting Installation
12:02:07 PM Thursday, 7 October, 2021 : parameter count = 0
12:02:07 PM Thursday, 7 October, 2021 : Initializing
12:02:07 PM Thursday, 7 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
12:02:07 PM Thursday, 7 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
12:02:07 PM Thursday, 7 October, 2021 : Response Content length = 1724
12:02:07 PM Thursday, 7 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
12:02:07 PM Thursday, 7 October, 2021 : Reading Json URL File
12:02:07 PM Thursday, 7 October, 2021 : setting media download server URL from Json File
12:02:07 PM Thursday, 7 October, 2021 : setting Dll path from Json File
12:02:07 PM Thursday, 7 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
12:02:07 PM Thursday, 7 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
12:02:07 PM Thursday, 7 October, 2021 : Wrapper Not Found..Exiting Installation
12:02:57 PM Thursday, 7 October, 2021 : parameter count = 1
12:02:57 PM Thursday, 7 October, 2021 : -wrapper
12:02:57 PM Thursday, 7 October, 2021 : Initializing
12:02:57 PM Thursday, 7 October, 2021 : Deleting file : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
12:02:57 PM Thursday, 7 October, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
12:02:58 PM Thursday, 7 October, 2021 : Response Content length = 1724
12:02:58 PM Thursday, 7 October, 2021 : C:\Users\USER\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
12:02:58 PM Thursday, 7 October, 2021 : Reading Json URL File
12:02:58 PM Thursday, 7 October, 2021 : setting media download server URL from Json File
12:02:58 PM Thursday, 7 October, 2021 : setting Dll path from Json File
12:02:58 PM Thursday, 7 October, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
12:02:58 PM Thursday, 7 October, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
12:02:58 PM Thursday, 7 October, 2021 : parameter count = 1
12:02:58 PM Thursday, 7 October, 2021 : -wrapper
12:03:01 PM Thursday, 7 October, 2021 : ReleaseVersion in XML: 17.40.007 InstalledVersion on system:
12:04:00 PM Thursday, 7 October, 2021 : An exception occured which is causing the program to close.
12:04:00 PM Thursday, 7 October, 2021 : Details of exception are : Unable to load DLL 'cdsVbl.dll': The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
12:04:01 PM Thursday, 7 October, 2021 : Stack Trace for the exception is    at TIPSpice.Utilities.cdsVblRegisterInstallation(String productKey, String bundleName, String chwsUrl)
12:04:01 PM Thursday, 7 October, 2021 : Message: An error occurred and PSpice for TI needs to close.
Rahulan
Adma & Lee Power Products Pte Ltd
Unit # 10-15 Crescent @ Kallang 47 Kallang Pudding Road
S(349318)
SINGAPORE
Tel: +65-6636 3938    www.admalee.com
https://www.facebook.com/AdmaLeePowerProductsPteLtd/
