TIDM-02008: The software phase-locked loop cannot be locked during the simulation process, and it keeps oscillating
Part Number: TIDM-02008
Dear team:
My client refers to the theoretical introduction of Solarlib.pdf in the TIDM-02008 project:
Simulink simulation parameters:
TTPLPFC_AC_FREQ: 50Hz, TTPLPFC_CONTROL_ISR_FREQUENCY, lpf_b0 and lpf_b1 parameters are consistent with the parameters used by TIDM-02008.
Simulink simulation results: input an AC signal with a frequency of 51Hz (a frequency that may appear in a 50Hz AC grid), and see if the waveform can be locked, and it is found that the fo output frequency and q axis cannot be stabilized.
function [sin_a,cos_a,fo_out,Q_out] = fcn(acValue,acFreq,isrFrequency,isrFrequencyMAX,lpf_b0,lpf_b1)
persistent sine;
if isempty(sine)
    sine = 0.0;
end
sin_a = sine;
persistent cosine;
if isempty(cosine)
    cosine = 0.0;
end
cos_a = cosine;
persistent cnt;
if isempty(cnt)
    cnt = 0.0;
end
persistent fn;
if isempty(fn)
    fn = acFreq;
end
persistent delta_t;
if isempty(delta_t)
    delta_t = 1.0/isrFrequency;
end
persistent osg_coeff_osg_k;
if isempty(osg_coeff_osg_k)
    osg_coeff_osg_k = 0.5;
end
persistent osg_coeff_osg_x;
if isempty(osg_coeff_osg_x)
    wn = 2.0 * 3.14159265 * fn;
    osg_coeff_osg_x = 2.0 * osg_coeff_osg_k * wn * delta_t;
end
persistent osg_coeff_osg_y;
if isempty(osg_coeff_osg_y)
    osg_coeff_osg_y = wn * delta_t * wn * delta_t;
end
persistent osg_coeff_osg_b0;
if isempty(osg_coeff_osg_b0)
    osg_coeff_osg_b0 = osg_coeff_osg_x / (osg_coeff_osg_x + osg_coeff_osg_y + 4.0);
end
persistent osg_coeff_osg_b2;
if isempty(osg_coeff_osg_b2)
    osg_coeff_osg_b2 = -osg_coeff_osg_x / (osg_coeff_osg_x + osg_coeff_osg_y + 4.0);
end
persistent osg_coeff_osg_a1;
if isempty(osg_coeff_osg_a1)
    osg_coeff_osg_a1 = 2 * (4.0 - osg_coeff_osg_y) / (osg_coeff_osg_x + osg_coeff_osg_y + 4.0);
end
persistent osg_coeff_osg_a2;
if isempty(osg_coeff_osg_a2)
    osg_coeff_osg_a2 = (osg_coeff_osg_x - osg_coeff_osg_y - 4) / (osg_coeff_osg_x + osg_coeff_osg_y + 4.0);
end
persistent osg_coeff_osg_qb0;
if isempty(osg_coeff_osg_qb0)
    osg_coeff_osg_qb0 = osg_coeff_osg_k * osg_coeff_osg_y / (osg_coeff_osg_x + osg_coeff_osg_y + 4.0);
end
persistent osg_coeff_osg_qb1;
if isempty(osg_coeff_osg_qb1)
    osg_coeff_osg_qb1 = 2 * osg_coeff_osg_k * osg_coeff_osg_y / (osg_coeff_osg_x + osg_coeff_osg_y + 4.0);
end
persistent osg_coeff_osg_qb2;
if isempty(osg_coeff_osg_qb2)
    osg_coeff_osg_qb2 = osg_coeff_osg_k * osg_coeff_osg_y / (osg_coeff_osg_x + osg_coeff_osg_y + 4.0);
end
persistent lpf_coeff_b0;
if isempty(lpf_coeff_b0)
    lpf_coeff_b0 = lpf_b0;
end
persistent lpf_coeff_b1;
if isempty(lpf_coeff_b1)
    lpf_coeff_b1 = lpf_b1;
end
persistent u_0;
if isempty(u_0)
    u_0 = 0.0;
end
persistent u_1;
if isempty(u_1)
    u_1 = 0.0;
end
persistent u_2;
if isempty(u_2)
    u_2 = 0.0;
end
persistent osg_u_0;
if isempty(osg_u_0)
    osg_u_0 = 0.0;
end
persistent osg_u_1;
if isempty(osg_u_1)
    osg_u_1 = 0.0;
end
persistent osg_u_2;
if isempty(osg_u_2)
    osg_u_2 = 0.0;
end
persistent osg_qu_0;
if isempty(osg_qu_0)
    osg_qu_0 = 0.0;
end
persistent osg_qu_1;
if isempty(osg_qu_1)
    osg_qu_1 = 0.0;
end
persistent osg_qu_2;
if isempty(osg_qu_2)
    osg_qu_2 = 0.0;
end
persistent u_Q_0;
if isempty(u_Q_0)
    u_Q_0 = 0.0;
end
Q_out = u_Q_0;
persistent u_Q_1;
if isempty(u_Q_1)
    u_Q_1 = 0.0;
end
persistent u_D_0;
if isempty(u_D_0)
    u_D_0 = 0.0;
end
persistent ylf_0;
if isempty(ylf_0)
    ylf_0 = 0.0;
end
persistent ylf_1;
if isempty(ylf_1)
    ylf_1 = 0.0;
end
persistent fo;
if isempty(fo)
    fo = 0.0;
end
fo_out = fo;
persistent theta;
if isempty(theta)
    theta = 0.0;
end
if cnt >= isrFrequencyMAX
    cnt = cnt - isrFrequencyMAX;
    % Update the spll_obj->u[0] with the grid value
    u_0 = acValue;
    % Orthogonal Signal Generator
    osg_u_0 = osg_coeff_osg_b0 * (u_0 - u_2) + osg_coeff_osg_a1 * osg_u_1 + osg_coeff_osg_a2 * osg_u_2;
    osg_u_2 = osg_u_1;
    osg_u_1 = osg_u_0;
    osg_qu_0 = osg_coeff_osg_qb0 * u_0 + osg_coeff_osg_qb1 * u_1 + osg_coeff_osg_qb2 * u_2 + osg_coeff_osg_a1 * osg_qu_1 + osg_coeff_osg_a2 * osg_qu_2;
    osg_qu_2 = osg_qu_1;
    osg_qu_1 = osg_qu_0;
    u_2 = u_1;
    u_1 = u_0;
    % Park Transform from alpha beta to d-q axis
    u_Q_0 = cosine * osg_u_0 + sine * osg_qu_0;
    u_D_0 = cosine * osg_qu_0 - sine * osg_u_0;
    % Loop Filter
    ylf_0 = ylf_1 + lpf_coeff_b0 * u_Q_0 + lpf_coeff_b1 * u_Q_1;
    ylf_1 = ylf_0;
    u_Q_1 = u_Q_0;
    fo = fn + ylf_0;
    theta = theta + (fo * delta_t) * (2.0 * 3.1415926);
    if theta < 0
        theta = 0;
    end
    if(theta > (2.0 * 3.1415926))
        theta = theta - (2.0 * 3.1415926);
        %theta = 0;
    end
    sin_a = sin(theta);
    cos_a = cos(theta);
    sine = sin_a;
    cosine = cos_a;
end
cnt = cnt + 1;
simulink simulation result q-axis output:
Output frequency:
May I ask why this is caused?
In the table for calculating lpf_b0 and lpf_b1, what does the specific meaning of "Error Band" mean?
Best regards
  • Hi Green,
    SOGI PLL assumes 50 Hz or 60 Hz grid frequency and therefore, the feed forward term in vco (wo) is fixed at 50 Hz for 50 Hz grid.
    If you need to run it other than these two frequency, try to run use FLL instead of SPLL
    There is an option for SPLL in ttplpfc.h file
    Original : TTPLPFC_SPLL_METHOD_SELECT == TTPLPFC_SPLL_1PH_SOGI_SEL (for 50 Hz or 60 Hz)
    Required modification :  TTPLPFC_SPLL_METHOD_SELECT == TTPLPFC_SPLL_1PH_SOGI_FLL_SEL  (other than 50 or 60 Hz)
    John
