After installing the latest PSpice for TI update, I am not able to run any circuit simulation with getting an error message "ERROR (ORCAP-15053): Can not initialize PSpice UI"
Hi Dured,
Are you seeing this error for every project or only on a specific project?
Could you please share your installation log, located at %appdata%\Cadence\PSpiceTIInstall\cdsPspiceTIlog.txt?
Could you please produce this error and then share your session log? It is in the bottom frame of your schematic capture window.
Thank you,
Jackie
Hi Jackie,
Yes, I see this error for every project.
Attached are the installation log file and session log screenshot.
3:48:21 PM Thursday, December 9, 2021 : parameter count = 1
3:48:21 PM Thursday, December 9, 2021 : -wrapper
3:48:21 PM Thursday, December 9, 2021 : Initializing
3:48:21 PM Thursday, December 9, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
3:48:21 PM Thursday, December 9, 2021 : Response Content length = 1724
3:48:21 PM Thursday, December 9, 2021 : C:\Users\DU031589\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
3:48:21 PM Thursday, December 9, 2021 : Reading Json URL File
3:48:21 PM Thursday, December 9, 2021 : setting media download server URL from Json File
3:48:21 PM Thursday, December 9, 2021 : setting Dll path from Json File
3:48:21 PM Thursday, December 9, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
3:48:21 PM Thursday, December 9, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
3:48:22 PM Thursday, December 9, 2021 : ReleaseVersion in XML: 17.40.007 InstalledVersion on system:
3:50:19 PM Thursday, December 9, 2021 : error_code cdsVblRegisterInstallation: -8
3:50:19 PM Thursday, December 9, 2021 : strErrorMsgDesc: Access key entered is not in expected format. Please go to http://e2e.ti.com for further assistance.
3:52:13 PM Thursday, December 9, 2021 : error_code cdsVblRegisterInstallation: VblSuccess
3:52:13 PM Thursday, December 9, 2021 : error_code cdsVblRequestLicense: VblSuccess
3:52:17 PM Thursday, December 9, 2021 : Set Installation and Home Directory()
3:52:17 PM Thursday, December 9, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI
3:52:17 PM Thursday, December 9, 2021 : Reading CDS_HOME environment variable
3:52:17 PM Thursday, December 9, 2021 : CDS_HOME is not present or is empty. Need to set CDS_HOME.
3:52:17 PM Thursday, December 9, 2021 : First time installation. CDS_HOME will be set to default HOME directory.
3:52:17 PM Thursday, December 9, 2021 : Checking if CDS_HOME directory exists and whether user has permission to create it.
3:52:17 PM Thursday, December 9, 2021 : Creating directory : C:\cds_spb_home
3:52:21 PM Thursday, December 9, 2021 : Checking for memory space
3:52:21 PM Thursday, December 9, 2021 : Memory space available
3:52:21 PM Thursday, December 9, 2021 : Target Dir: C:\Cadence\PSpiceTI
3:52:21 PM Thursday, December 9, 2021 : Working Dir: C:\cds_spb_home
3:52:21 PM Thursday, December 9, 2021 : Silent ini file created
3:52:23 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
3:52:23 PM Thursday, December 9, 2021 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480
3:52:23 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
3:52:23 PM Thursday, December 9, 2021 : Completing download of 0x0409.ini
3:52:24 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
3:52:24 PM Thursday, December 9, 2021 : Starting download of data1.cab Attempt no 1 DataSize is 31794545
3:52:25 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
3:52:25 PM Thursday, December 9, 2021 : Starting download of data1.hdr Attempt no 1 DataSize is 4972835
3:52:25 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
3:52:25 PM Thursday, December 9, 2021 : Completing download of data1.hdr
3:52:26 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
3:52:26 PM Thursday, December 9, 2021 : Completing download of data1.cab
3:52:28 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
3:52:28 PM Thursday, December 9, 2021 : Starting download of data2.cab Attempt no 1 DataSize is 170194944
3:52:28 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
3:52:28 PM Thursday, December 9, 2021 : Starting download of ISSetup.dll Attempt no 1 DataSize is 1637872
3:52:29 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
3:52:29 PM Thursday, December 9, 2021 : Completing download of ISSetup.dll
3:52:30 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
3:52:30 PM Thursday, December 9, 2021 : Starting download of layout.bin Attempt no 1 DataSize is 994
3:52:30 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
3:52:30 PM Thursday, December 9, 2021 : Completing download of layout.bin
3:52:31 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
3:52:31 PM Thursday, December 9, 2021 : Starting download of pspInstall.pdf Attempt no 1 DataSize is 85357
3:52:31 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
3:52:31 PM Thursday, December 9, 2021 : Completing download of pspInstall.pdf
3:52:32 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
3:52:32 PM Thursday, December 9, 2021 : Starting download of setup.bmp Attempt no 1 DataSize is 414054
3:52:32 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
3:52:32 PM Thursday, December 9, 2021 : Completing download of setup.bmp
3:52:33 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
3:52:33 PM Thursday, December 9, 2021 : Starting download of setup.ini Attempt no 1 DataSize is 2430
3:52:33 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
3:52:33 PM Thursday, December 9, 2021 : Completing download of setup.ini
3:52:34 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
3:52:34 PM Thursday, December 9, 2021 : Starting download of setup.inx Attempt no 1 DataSize is 574166
3:52:34 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
3:52:34 PM Thursday, December 9, 2021 : Completing download of setup.inx
3:52:37 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
3:52:37 PM Thursday, December 9, 2021 : Starting download of data9.cab Attempt no 1 DataSize is 79449767
3:52:41 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
3:52:41 PM Thursday, December 9, 2021 : Completing download of data2.cab
3:52:43 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
3:52:43 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
3:52:43 PM Thursday, December 9, 2021 : Starting download of data8.cab Attempt no 1 DataSize is 209715200
3:52:43 PM Thursday, December 9, 2021 : Completing download of data9.cab
3:52:47 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
3:52:47 PM Thursday, December 9, 2021 : Starting download of data7.cab Attempt no 1 DataSize is 209715200
3:52:59 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
3:53:00 PM Thursday, December 9, 2021 : Completing download of data8.cab
3:53:03 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
3:53:03 PM Thursday, December 9, 2021 : Starting download of data6.cab Attempt no 1 DataSize is 209715200
3:53:10 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
3:53:11 PM Thursday, December 9, 2021 : Completing download of data7.cab
3:53:14 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
3:53:14 PM Thursday, December 9, 2021 : Starting download of data5.cab Attempt no 1 DataSize is 209715200
3:53:21 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
3:53:22 PM Thursday, December 9, 2021 : Completing download of data6.cab
3:53:25 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
3:53:25 PM Thursday, December 9, 2021 : Starting download of data4.cab Attempt no 1 DataSize is 209715200
3:53:36 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
3:53:36 PM Thursday, December 9, 2021 : Completing download of data5.cab
3:53:39 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
3:53:39 PM Thursday, December 9, 2021 : Starting download of data3.cab Attempt no 1 DataSize is 209715200
3:53:46 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
3:53:46 PM Thursday, December 9, 2021 : Completing download of data4.cab
3:53:48 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
3:53:48 PM Thursday, December 9, 2021 : Starting download of installsetup.exe Attempt no 1 DataSize is 954864
3:53:48 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
3:53:48 PM Thursday, December 9, 2021 : Completing download of installsetup.exe
3:53:58 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
3:53:59 PM Thursday, December 9, 2021 : Completing download of data3.cab
3:53:59 PM Thursday, December 9, 2021 : 1578192 1578192
3:53:59 PM Thursday, December 9, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
3:53:59 PM Thursday, December 9, 2021 : Allegro Installation Start pid: 5500
3:54:06 PM Thursday, December 9, 2021 : NumberOfComponentsToBeInstalled = 39597
3:54:06 PM Thursday, December 9, 2021 : Updated NumberOfComponentsToBeInstalled = 40392.93
3:54:06 PM Thursday, December 9, 2021 : Updated NumberOfComponentsInstalled = 396
3:57:02 PM Thursday, December 9, 2021 : Feature transfer complete..disabling close button
3:57:02 PM Thursday, December 9, 2021 : Installing: Runtime packages and redistributables
3:57:02 PM Thursday, December 9, 2021 : Installing: Configuring documentation
3:57:03 PM Thursday, December 9, 2021 : Installing: Configuring file associations
3:57:04 PM Thursday, December 9, 2021 : Installing: Setting permissions for files and folders
3:57:11 PM Thursday, December 9, 2021 : Installing: Creating Registries
3:57:11 PM Thursday, December 9, 2021 : Installing: Finishing Installation
3:57:27 PM Thursday, December 9, 2021 : Running Library Configuration Executable
3:57:27 PM Thursday, December 9, 2021 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
4:00:19 PM Thursday, December 9, 2021 : orLibraryDownLoad.exe returned : 0
4:00:19 PM Thursday, December 9, 2021 : Library Installation completed successfully.
4:00:19 PM Thursday, December 9, 2021 : Downloading License file
4:00:19 PM Thursday, December 9, 2021 : error_code cdsVblDownloadLicense: VblSuccess
4:00:19 PM Thursday, December 9, 2021 : Downloading License file finish
4:00:19 PM Thursday, December 9, 2021 : PrepareUninstallation
4:00:19 PM Thursday, December 9, 2021 : strLocalPath: C:\Users\DU031589\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
4:00:19 PM Thursday, December 9, 2021 : strLocalConfigPath: C:\Users\DU031589\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe.config
4:00:19 PM Thursday, December 9, 2021 : strCachedLocForFV174Installer: "C:\Users\DU031589\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409 Uninstall -removeonly
4:00:19 PM Thursday, December 9, 2021 : ClearRunOnceIfNotNeeded()
4:00:19 PM Thursday, December 9, 2021 : installSetupValue =
4:00:50 PM Thursday, December 9, 2021 : Deleting installation files
4:08:53 PM Thursday, December 9, 2021 : parameter count = 4
4:08:53 PM Thursday, December 9, 2021 : -runfromtemp
4:08:53 PM Thursday, December 9, 2021 : -l0x0409
4:08:53 PM Thursday, December 9, 2021 : Uninstall
4:08:53 PM Thursday, December 9, 2021 : -removeonly
4:08:53 PM Thursday, December 9, 2021 : TI Launched in uninstallation mode as remove found in command line
4:08:53 PM Thursday, December 9, 2021 : Message: Do you want to completely remove the selected application and all of its features?
4:09:04 PM Thursday, December 9, 2021 : Target Dir: C:\Cadence\PSpiceTI
4:09:04 PM Thursday, December 9, 2021 : Working Dir:
4:09:04 PM Thursday, December 9, 2021 : Silent ini file created
4:09:04 PM Thursday, December 9, 2021 : Uninstallation exe path ctor: C:\Users\DU031589\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}
4:09:04 PM Thursday, December 9, 2021 : Uninstallation exe path: C:\Users\DU031589\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\installsetup.exe
4:09:04 PM Thursday, December 9, 2021 : 6227144 6227144
4:09:04 PM Thursday, December 9, 2021 : Setup EXE Argument: /hide_progress /hide_splash DMHandle="6227144" -Wrapper Uninstall !Quiet="C:\Users\DU031589\AppData\Roaming\Cadence\PspiceTIInstall\silentinstall-TI.ini"
4:09:11 PM Thursday, December 9, 2021 : Message 1004: Uninstalling: Removing shortcuts
4:09:11 PM Thursday, December 9, 2021 : NumberOfComponentsToBeInstalled = 39597
4:09:11 PM Thursday, December 9, 2021 : Updated NumberOfFeaturesToBeUninstalled = 41181
4:09:11 PM Thursday, December 9, 2021 : Updated NumberOfFeaturesUninstalled = 1584
4:09:11 PM Thursday, December 9, 2021 : Message 1004: Uninstalling: Uninstalling files
4:10:07 PM Thursday, December 9, 2021 : Message 1002: Uninstalling: Finishing Uninstallation
4:10:20 PM Thursday, December 9, 2021 : uninstallation sucessfull
4:10:20 PM Thursday, December 9, 2021 : Clearing Registry: TIPSpice.Resources.Email.reg
4:10:20 PM Thursday, December 9, 2021 : Cleared Registry settings
4:10:20 PM Thursday, December 9, 2021 : This installation requires a reboot.
4:40:32 PM Thursday, December 9, 2021 : parameter count = 1
4:40:32 PM Thursday, December 9, 2021 : -wrapper
4:40:32 PM Thursday, December 9, 2021 : Initializing
4:40:32 PM Thursday, December 9, 2021 : Deleting file : C:\Users\DU031589\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
4:40:32 PM Thursday, December 9, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
4:40:32 PM Thursday, December 9, 2021 : Response Content length = 1724
4:40:32 PM Thursday, December 9, 2021 : C:\Users\DU031589\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
4:40:32 PM Thursday, December 9, 2021 : Reading Json URL File
4:40:32 PM Thursday, December 9, 2021 : setting media download server URL from Json File
4:40:32 PM Thursday, December 9, 2021 : setting Dll path from Json File
4:40:32 PM Thursday, December 9, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
4:40:32 PM Thursday, December 9, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
4:40:32 PM Thursday, December 9, 2021 : ReleaseVersion in XML: 17.40.007 InstalledVersion on system:
4:42:02 PM Thursday, December 9, 2021 : error_code cdsVblRegisterInstallation: VblSuccess
4:42:02 PM Thursday, December 9, 2021 : error_code cdsVblRequestLicense: VblSuccess
4:42:05 PM Thursday, December 9, 2021 : Set Installation and Home Directory()
4:42:05 PM Thursday, December 9, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI
4:42:05 PM Thursday, December 9, 2021 : Reading CDS_HOME environment variable
4:42:05 PM Thursday, December 9, 2021 : CDS_HOME is present and set to C:\cds_spb_home. No need to set CDS_HOME
4:42:15 PM Thursday, December 9, 2021 : Checking for memory space
4:42:15 PM Thursday, December 9, 2021 : Memory space available
4:42:15 PM Thursday, December 9, 2021 : Target Dir: C:\Cadence\PSpiceTI
4:42:15 PM Thursday, December 9, 2021 : Working Dir: C:\cds_spb_home
4:42:15 PM Thursday, December 9, 2021 : Silent ini file created
4:42:18 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
4:42:18 PM Thursday, December 9, 2021 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480
4:42:18 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
4:42:18 PM Thursday, December 9, 2021 : Completing download of 0x0409.ini
4:42:18 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
4:42:18 PM Thursday, December 9, 2021 : Starting download of data1.cab Attempt no 1 DataSize is 31794545
4:42:19 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
4:42:19 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
4:42:19 PM Thursday, December 9, 2021 : Starting download of data1.hdr Attempt no 1 DataSize is 4972835
4:42:19 PM Thursday, December 9, 2021 : Completing download of data1.cab
4:42:20 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
4:42:20 PM Thursday, December 9, 2021 : Completing download of data1.hdr
4:42:21 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
4:42:21 PM Thursday, December 9, 2021 : Starting download of data2.cab Attempt no 1 DataSize is 170194944
4:42:21 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
4:42:21 PM Thursday, December 9, 2021 : Starting download of ISSetup.dll Attempt no 1 DataSize is 1637872
4:42:21 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
4:42:21 PM Thursday, December 9, 2021 : Completing download of ISSetup.dll
4:42:23 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
4:42:23 PM Thursday, December 9, 2021 : Starting download of layout.bin Attempt no 1 DataSize is 994
4:42:23 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
4:42:23 PM Thursday, December 9, 2021 : Completing download of layout.bin
4:42:25 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
4:42:25 PM Thursday, December 9, 2021 : Starting download of pspInstall.pdf Attempt no 1 DataSize is 85357
4:42:25 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
4:42:25 PM Thursday, December 9, 2021 : Completing download of pspInstall.pdf
4:42:27 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
4:42:27 PM Thursday, December 9, 2021 : Starting download of setup.bmp Attempt no 1 DataSize is 414054
4:42:27 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
4:42:27 PM Thursday, December 9, 2021 : Completing download of setup.bmp
4:42:28 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
4:42:28 PM Thursday, December 9, 2021 : Completing download of data2.cab
4:42:29 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
4:42:29 PM Thursday, December 9, 2021 : Starting download of setup.ini Attempt no 1 DataSize is 2430
4:42:29 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
4:42:29 PM Thursday, December 9, 2021 : Completing download of setup.ini
4:42:29 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
4:42:29 PM Thursday, December 9, 2021 : Starting download of setup.inx Attempt no 1 DataSize is 574166
4:42:30 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
4:42:30 PM Thursday, December 9, 2021 : Completing download of setup.inx
4:42:31 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
4:42:31 PM Thursday, December 9, 2021 : Starting download of data8.cab Attempt no 1 DataSize is 209715200
4:42:31 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
4:42:31 PM Thursday, December 9, 2021 : Starting download of data9.cab Attempt no 1 DataSize is 79449767
4:42:36 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
4:42:36 PM Thursday, December 9, 2021 : Completing download of data9.cab
4:42:38 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
4:42:38 PM Thursday, December 9, 2021 : Starting download of data7.cab Attempt no 1 DataSize is 209715200
4:42:41 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
4:42:41 PM Thursday, December 9, 2021 : Completing download of data8.cab
4:42:44 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
4:42:44 PM Thursday, December 9, 2021 : Starting download of data6.cab Attempt no 1 DataSize is 209715200
4:42:48 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
4:42:49 PM Thursday, December 9, 2021 : Completing download of data7.cab
4:42:50 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
4:42:50 PM Thursday, December 9, 2021 : Starting download of data5.cab Attempt no 1 DataSize is 209715200
4:42:54 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
4:42:55 PM Thursday, December 9, 2021 : Completing download of data6.cab
4:42:57 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
4:42:57 PM Thursday, December 9, 2021 : Starting download of data4.cab Attempt no 1 DataSize is 209715200
4:43:00 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
4:43:01 PM Thursday, December 9, 2021 : Completing download of data5.cab
4:43:03 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
4:43:03 PM Thursday, December 9, 2021 : Starting download of data3.cab Attempt no 1 DataSize is 209715200
4:43:08 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
4:43:09 PM Thursday, December 9, 2021 : Completing download of data4.cab
4:43:10 PM Thursday, December 9, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
4:43:10 PM Thursday, December 9, 2021 : Starting download of installsetup.exe Attempt no 1 DataSize is 954864
4:43:10 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
4:43:10 PM Thursday, December 9, 2021 : Completing download of installsetup.exe
4:43:14 PM Thursday, December 9, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
4:43:14 PM Thursday, December 9, 2021 : Completing download of data3.cab
4:43:14 PM Thursday, December 9, 2021 : 134176 134176
4:43:14 PM Thursday, December 9, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
4:43:14 PM Thursday, December 9, 2021 : Allegro Installation Start pid: 9508
4:43:21 PM Thursday, December 9, 2021 : NumberOfComponentsToBeInstalled = 39597
4:43:21 PM Thursday, December 9, 2021 : Updated NumberOfComponentsToBeInstalled = 40392.93
4:43:21 PM Thursday, December 9, 2021 : Updated NumberOfComponentsInstalled = 396
4:46:10 PM Thursday, December 9, 2021 : Feature transfer complete..disabling close button
4:46:10 PM Thursday, December 9, 2021 : Installing: Runtime packages and redistributables
4:46:10 PM Thursday, December 9, 2021 : Installing: Configuring documentation
4:46:11 PM Thursday, December 9, 2021 : Installing: Configuring file associations
4:46:11 PM Thursday, December 9, 2021 : Installing: Setting permissions for files and folders
4:46:18 PM Thursday, December 9, 2021 : Installing: Creating Registries
4:46:19 PM Thursday, December 9, 2021 : Installing: Finishing Installation
4:46:34 PM Thursday, December 9, 2021 : Running Library Configuration Executable
4:46:34 PM Thursday, December 9, 2021 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
4:49:03 PM Thursday, December 9, 2021 : orLibraryDownLoad.exe returned : 0
4:49:03 PM Thursday, December 9, 2021 : Library Installation completed successfully.
4:49:03 PM Thursday, December 9, 2021 : Downloading License file
4:49:03 PM Thursday, December 9, 2021 : error_code cdsVblDownloadLicense: VblSuccess
4:49:03 PM Thursday, December 9, 2021 : Downloading License file finish
4:49:03 PM Thursday, December 9, 2021 : PrepareUninstallation
4:49:03 PM Thursday, December 9, 2021 : strLocalPath: C:\Users\DU031589\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
4:49:03 PM Thursday, December 9, 2021 : strCachedLocForFV174Installer: "C:\Users\DU031589\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409 Uninstall -removeonly
4:49:03 PM Thursday, December 9, 2021 : ClearRunOnceIfNotNeeded()
4:49:03 PM Thursday, December 9, 2021 : installSetupValue =
4:49:07 PM Thursday, December 9, 2021 : Deleting installation files
9:52:18 PM Sunday, March 27, 2022 : parameter count = 2
9:52:18 PM Sunday, March 27, 2022 : -wrapper
9:52:18 PM Sunday, March 27, 2022 : -update
9:52:18 PM Sunday, March 27, 2022 : Module Name: TIPSpice.exe
9:52:18 PM Sunday, March 27, 2022 : Server OS = False
9:52:18 PM Sunday, March 27, 2022 : Operating system version : 10.0.0.0
9:52:18 PM Sunday, March 27, 2022 : Checking for proxy
9:52:19 PM Sunday, March 27, 2022 : {
"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
"LibFirstInstall_LatestVersion": "17.40.006",
"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
"SoftwareUpdate_Expiry": {
"Timestamp": "01:15:2099 15:07:19 GMT",
"RegularMessage": {
"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
"HyperLink": "license agreement",
"PostHyperLink": "."
"ForceMessage": {
"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
"PostHyperLink": ". Click Cancel to exit."
"UTM_Keyword": {
"TIPSpice_Install": "HQS=pspiceforti",
"Full_Install": "HQS=pspiceforti"
"TI_URLs_Version": [
"17_4_2020_S006"
9:52:19 PM Sunday, March 27, 2022 : Checking if Licensing URL is accessible
9:52:19 PM Sunday, March 27, 2022 : Initializing
9:52:19 PM Sunday, March 27, 2022 : Deleting file : C:\Users\DU031589\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
9:52:19 PM Sunday, March 27, 2022 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
9:52:19 PM Sunday, March 27, 2022 : Response Content length = 1724
9:52:19 PM Sunday, March 27, 2022 : C:\Users\DU031589\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
9:52:19 PM Sunday, March 27, 2022 : Reading Json URL File
9:52:19 PM Sunday, March 27, 2022 : setting media download server URL from Json File
9:52:19 PM Sunday, March 27, 2022 : setting Dll path from Json File
9:52:19 PM Sunday, March 27, 2022 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
9:52:19 PM Sunday, March 27, 2022 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
9:52:19 PM Sunday, March 27, 2022 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 17.40.007
9:52:19 PM Sunday, March 27, 2022 : Check if CDS_HOME is set
9:52:19 PM Sunday, March 27, 2022 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
9:52:19 PM Sunday, March 27, 2022 : LaunchTIPSpiceDlgs()
9:52:20 PM Sunday, March 27, 2022 : error_code cdsVblRequestLicense: VblSuccess
9:52:20 PM Sunday, March 27, 2022 : Target Dir: C:\Cadence\PSpiceTI
9:52:20 PM Sunday, March 27, 2022 : Working Dir: C:\cds_spb_home
9:52:20 PM Sunday, March 27, 2022 : Silent ini file created
9:52:23 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
9:52:23 PM Sunday, March 27, 2022 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480
9:52:23 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
9:52:23 PM Sunday, March 27, 2022 : Completing download of 0x0409.ini
9:52:23 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
9:52:23 PM Sunday, March 27, 2022 : Starting download of data1.cab Attempt no 1 DataSize is 31794544
9:52:25 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
9:52:25 PM Sunday, March 27, 2022 : Starting download of data1.hdr Attempt no 1 DataSize is 4999392
9:52:26 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
9:52:26 PM Sunday, March 27, 2022 : Completing download of data1.hdr
9:52:27 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
9:52:27 PM Sunday, March 27, 2022 : Completing download of data1.cab
9:52:29 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
9:52:29 PM Sunday, March 27, 2022 : Starting download of data2.cab Attempt no 1 DataSize is 170168320
9:52:30 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
9:52:30 PM Sunday, March 27, 2022 : Starting download of ISSetup.dll Attempt no 1 DataSize is 1637872
9:52:30 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
9:52:31 PM Sunday, March 27, 2022 : Completing download of ISSetup.dll
9:52:32 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
9:52:32 PM Sunday, March 27, 2022 : Starting download of layout.bin Attempt no 1 DataSize is 994
9:52:32 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
9:52:32 PM Sunday, March 27, 2022 : Completing download of layout.bin
9:52:34 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
9:52:34 PM Sunday, March 27, 2022 : Starting download of pspInstall.pdf Attempt no 1 DataSize is 85357
9:52:34 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
9:52:34 PM Sunday, March 27, 2022 : Completing download of pspInstall.pdf
9:52:36 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
9:52:36 PM Sunday, March 27, 2022 : Starting download of setup.bmp Attempt no 1 DataSize is 414054
9:52:36 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
9:52:36 PM Sunday, March 27, 2022 : Completing download of setup.bmp
9:52:38 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
9:52:38 PM Sunday, March 27, 2022 : Starting download of setup.ini Attempt no 1 DataSize is 2430
9:52:38 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
9:52:38 PM Sunday, March 27, 2022 : Completing download of setup.ini
9:52:39 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
9:52:39 PM Sunday, March 27, 2022 : Starting download of setup.inx Attempt no 1 DataSize is 574598
9:52:39 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
9:52:39 PM Sunday, March 27, 2022 : Completing download of setup.inx
9:52:42 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
9:52:42 PM Sunday, March 27, 2022 : Starting download of data9.cab Attempt no 1 DataSize is 79773492
9:52:51 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
9:52:51 PM Sunday, March 27, 2022 : Completing download of data2.cab
9:52:54 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
9:52:54 PM Sunday, March 27, 2022 : Starting download of data8.cab Attempt no 1 DataSize is 209715200
9:52:57 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
9:52:57 PM Sunday, March 27, 2022 : Completing download of data9.cab
9:52:59 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
9:52:59 PM Sunday, March 27, 2022 : Starting download of data7.cab Attempt no 1 DataSize is 209715200
9:53:35 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
9:53:36 PM Sunday, March 27, 2022 : Completing download of data8.cab
9:53:39 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
9:53:39 PM Sunday, March 27, 2022 : Starting download of data6.cab Attempt no 1 DataSize is 209715200
9:53:43 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
9:53:43 PM Sunday, March 27, 2022 : Completing download of data7.cab
9:53:46 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
9:53:46 PM Sunday, March 27, 2022 : Starting download of data5.cab Attempt no 1 DataSize is 209715200
9:54:20 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
9:54:21 PM Sunday, March 27, 2022 : Completing download of data6.cab
9:54:23 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
9:54:23 PM Sunday, March 27, 2022 : Starting download of data4.cab Attempt no 1 DataSize is 209715200
9:54:27 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
9:54:28 PM Sunday, March 27, 2022 : Completing download of data5.cab
9:54:29 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
9:54:29 PM Sunday, March 27, 2022 : Starting download of data3.cab Attempt no 1 DataSize is 209715200
9:55:04 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
9:55:05 PM Sunday, March 27, 2022 : Completing download of data4.cab
9:55:07 PM Sunday, March 27, 2022 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
9:55:07 PM Sunday, March 27, 2022 : Starting download of installsetup.exe Attempt no 1 DataSize is 954864
9:55:08 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
9:55:08 PM Sunday, March 27, 2022 : Completing download of installsetup.exe
9:55:10 PM Sunday, March 27, 2022 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
9:55:10 PM Sunday, March 27, 2022 : Completing download of data3.cab
9:55:10 PM Sunday, March 27, 2022 : 1050328 1050328
9:55:10 PM Sunday, March 27, 2022 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
9:55:10 PM Sunday, March 27, 2022 : Allegro Installation Start pid: 17124
9:55:17 PM Sunday, March 27, 2022 : NumberOfComponentsToBeInstalled = 39824
9:55:17 PM Sunday, March 27, 2022 : Updated NumberOfComponentsToBeInstalled = 40625.23
9:55:17 PM Sunday, March 27, 2022 : Updated NumberOfComponentsInstalled = 399
10:00:39 PM Sunday, March 27, 2022 : Feature transfer complete..disabling close button
10:00:39 PM Sunday, March 27, 2022 : Installing: Configuring documentation
10:00:40 PM Sunday, March 27, 2022 : Installing: Configuring installation
10:00:41 PM Sunday, March 27, 2022 : Reboot message received.
10:00:41 PM Sunday, March 27, 2022 : Installing: Finishing installation
10:00:58 PM Sunday, March 27, 2022 : Downloading License file
10:00:59 PM Sunday, March 27, 2022 : error_code cdsVblDownloadLicense: VblSuccess
10:00:59 PM Sunday, March 27, 2022 : Downloading License file finish
10:00:59 PM Sunday, March 27, 2022 : Removing generic credentials.
10:00:59 PM Sunday, March 27, 2022 : PrepareUninstallation
10:00:59 PM Sunday, March 27, 2022 : strLocalPath: C:\Users\DU031589\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
10:00:59 PM Sunday, March 27, 2022 : strCachedLocForFV174Installer: "C:\Users\DU031589\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409 Uninstall Uninstall -removeonly
10:00:59 PM Sunday, March 27, 2022 : ClearRunOnceIfNotNeeded()
10:00:59 PM Sunday, March 27, 2022 : installSetupValue = C:\Users\DU031589\AppData\Roaming\INSTAL~1\{A74FA~1\INSTAL~1.EXE -rebootC:\Users\DU031589\AppData\Roaming\INSTAL~1\{A74FA~1\reboot.ini
10:00:59 PM Sunday, March 27, 2022 : strFullPathInNonDosFormat = C:\Users\DU031589\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\reboot.ini
10:00:59 PM Sunday, March 27, 2022 : Deleted RunOnce Entry
10:00:59 PM Sunday, March 27, 2022 : This installation requires a reboot.
10:01:06 PM Sunday, March 27, 2022 : Deleting installation files
Hi Dured,
Did you restart your machine after installation?
Do you have the commercial software of Cadence Orcad installed? If yes, what version?
Thank you,
Jackie
Hi Jackie,
-Yes I restarted my machine.
-Yes I have the commercial software of Cadence OrCAD installed version 17.4.
Dured
Hi Dured,
There is a known issue where PSpice for TI and Cadence OrCAD cannot be launched and used at the same time. Having both installed on the same machine is no issue, and there are no other conflicts with OrCAD. Do you see this issue with PSpice for TI even if Cadence OrCAD is not open? Are you able to launch all OrCAD simulations as normal?
Thank you,
Jackie
Hi Jackie,
-I am not launching or using PSpice for TI and Cadence OrCAD at the same time.
- Yes I have this issue even if Cadence OrCAD is not open.
- Yes I am able to launch all OrCAD simulations as normal.
Hi Dured,
I'd like to discuss this issue with you more. I am going to add you as a friend on the E2E forum so we can communicate by private messaging. Please accept the request and I will let you know our next steps.
Thank you,
Jackie
Hello Dured,
You were able to resolve this issue by reinstalling PSpice for TI. I will be closing this thread and any associated tickets.
Thank you,
Jackie
Hello Jackie,
Yes I were able to resolve this issue by reinstalling PSpice for TI.
Thank you,
Dured
