Sincerely,
Robert RATLIFF
Eng V – Technical Deputy | Engineering
Safran Cabin
P +13108847047 • M +17147974631
1500 Glenn Curtiss St.
Carson, CA 90746-4012 USA
www.safran-cabin.com
Sincerely,
Robert RATLIFF
Safran Cabin
Hi Robert,
Please close PSpice for TI, then check if you have any PSpice processes running using the task manager. Use the "command line" column on the "details" tab to look for executables in "C:\Cadence\PSpiceTI":
If not, launch PSpice for TI again to see if you still get the error.
If yes, close PSpice for TI, rename the folders "C:\cds_spb_home\cdssetup\ORCAD_CAPTURETIPSpice_Install" and "C:\cds_spb_home\cdssetup\OrCAD_PSpiceTIPSpice_Install", then try again.
Also, what solution did you reject?
JC
Hi Nicola,
Would you please zip up this folder (except the exe files in it) and share with us?
C:\Users\{USER}\AppData\Roaming\Cadence\PSpiceTIInstall
JC
