IBIS Models
Other Parts Discussed in Thread: SN54LVCH245A
Hi All,
I hope all is well. I am running SI analysis on one of our existing board that utilizes the follow interface: SNJ54LVCH245AJ, SNJ55LVDS31J. Could you please support with the provision of its IBIS model?
Your support on this will be highly appreciated.
Thank you
  • Hi Jean,
    We don't have an IBIS model for the SN54LVCH245A.
    The SN74LVCH245A has an IBIS model you can use (Same exact device just the commercial version, input/output behavior will be the same).
    However it won't have data for the same temperature range of the military part SN54LVCH245A, only -40 to 125C.
    I don't support LVDS devices so I'll loop in that team to comment.
    Sebastian
  • Hi Sebastian,
    Thank you for your time and for sharing your inputs on this SN54LVCH245A IBIS model search, I would be more than happy to have what you have available and see if I can edit the model parameters' scripts to reflect the respective temperature.  Also, I look forward to hearing from what your team thinks.
    Thank you again.
    Jean
