Other Parts Discussed in Thread: ISO1211
trying to understand the reason for using U2 (SN74LVC2G132YZPR) dual NAND gates instead of a single AND gate? what is the advantage of inverting the signal and using this dual NAND part?
also, i assume the dual R6 and R13 resistors is for HFT=1? if this is the case, why wouldnt you have dual R16's resistors in parallel in case of open circuit failure in the R16?
