PSPICE-FOR-TI: PSpice for TI installation stopped at Configuring Library
Part Number: PSPICE-FOR-TI
Most of the PSpice installation works on my computer, but near the end (according to the progress bar) it hangs at Configuring Library. I left it running for a couple hours, and it never finished.
This problem is identical to one that was reported on this forum in September, and that one was resolved after the user tried the installation again. I ran it a second time, and it failed at the same place. Then I rebooted my computer, and the install again failed at the same place, so I tried a third time with the same results. Below is a screenshot of where the install fails, and I have attached the log. My computer meets or exceeds all the requirements listed at https://e2e.ti.com/support/tools/simulation-hardware-system-design-tools-group/sim-hw-system-design/f/simulation-hardware-system-design-tools-forum/940856/pspice-for-ti-pspice.
After a while, if I use the task manager to kill the installation, I get these few lines at the end of the log file:
11:47:44 AM Thursday, January 19, 2023 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
11:55:18 AM Thursday, January 19, 2023 : Exiting Installation Installing Dialog
11:55:18 AM Thursday, January 19, 2023 : An exception occured which is causing the program to close.
11:55:18 AM Thursday, January 19, 2023 : Details of exception are : Not enough quota is available to process this command
11:55:18 AM Thursday, January 19, 2023 : Stack Trace for the exception is at MS.Win32.ManagedWndProcTracker.HookUpDefWindowProc(IntPtr hwnd)
at MS.Win32.ManagedWndProcTracker.OnAppDomainProcessExit()
at MS.Internal.ShutDownListener.HandleShutDown(Object sender, EventArgs e)
11:55:18 AM Thursday, January 19, 2023 : Message: An error occurred and PSpice for TI needs to close.
Refer to cdsPspiceTIlog.txt at C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall for error details.
7384.cdsPspiceTIlog.txt
9:17:33 AM Thursday, January 19, 2023 : parameter count = 1
9:17:33 AM Thursday, January 19, 2023 : -wrapper
9:17:33 AM Thursday, January 19, 2023 : Module Name: TIPSpice.exe
9:17:33 AM Thursday, January 19, 2023 : Server OS = False
9:17:33 AM Thursday, January 19, 2023 : Operating system version : 10.0.0.0
9:17:33 AM Thursday, January 19, 2023 : Checking for proxy
9:17:33 AM Thursday, January 19, 2023 : {
	"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
	"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
	"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
	"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
	"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
	"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
	"LibFirstInstall_LatestVersion": "17.40.006",
	"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
	"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
	"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
	"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
	"SoftwareUpdate_Expiry": {
		"Timestamp": "01:15:2099 15:07:19 GMT",
		"RegularMessage": {
			"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
			"HyperLink": "license agreement",
			"PostHyperLink": "."
		"ForceMessage": {
			"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
			"PostHyperLink": ".  Click Cancel to exit."
	"UTM_Keyword": {
		"TIPSpice_Install": "HQS=pspiceforti",
		"Full_Install": "HQS=pspiceforti"
	"TI_URLs_Version": [
		"17_4_2020_S006"
9:17:33 AM Thursday, January 19, 2023 : Checking if Licensing URL is accessible
9:17:33 AM Thursday, January 19, 2023 : Initializing
9:17:33 AM Thursday, January 19, 2023 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
9:17:33 AM Thursday, January 19, 2023 : Response Content length = 1724
9:17:33 AM Thursday, January 19, 2023 : C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
9:17:33 AM Thursday, January 19, 2023 : Reading Json URL File
9:17:33 AM Thursday, January 19, 2023 : setting media download server URL from Json File
9:17:33 AM Thursday, January 19, 2023 : setting Dll path from Json File
9:17:33 AM Thursday, January 19, 2023 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
9:17:33 AM Thursday, January 19, 2023 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
9:17:33 AM Thursday, January 19, 2023 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system:
9:17:33 AM Thursday, January 19, 2023 : LaunchTIPSpiceDlgs()
9:17:33 AM Thursday, January 19, 2023 : Checking for compnts.dat
9:18:03 AM Thursday, January 19, 2023 : error_code cdsVblRegisterInstallation: VblSuccess
9:18:03 AM Thursday, January 19, 2023 : error_code cdsVblRequestLicense: VblSuccess
9:18:09 AM Thursday, January 19, 2023 : Set Installation and Home Directory()
9:18:09 AM Thursday, January 19, 2023 : Setting default Installation directory : C:\Cadence\PSpiceTI
9:18:09 AM Thursday, January 19, 2023 : Reading CDS_HOME environment variable
9:18:09 AM Thursday, January 19, 2023 : CDS_HOME is not present or is empty. Need to set CDS_HOME.
9:18:09 AM Thursday, January 19, 2023 : First time installation. CDS_HOME will be set to default HOME directory.
9:18:09 AM Thursday, January 19, 2023 : Checking if CDS_HOME directory exists and whether user has permission to create it.
9:18:09 AM Thursday, January 19, 2023 : Creating directory : C:\cds_spb_home
9:18:16 AM Thursday, January 19, 2023 : Checking for memory space
9:18:16 AM Thursday, January 19, 2023 : Memory space available
9:18:16 AM Thursday, January 19, 2023 : Target Dir: C:\Cadence\PSpiceTI
9:18:16 AM Thursday, January 19, 2023 : Working Dir: C:\cds_spb_home
9:18:16 AM Thursday, January 19, 2023 : Silent ini file created
9:18:18 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
9:18:18 AM Thursday, January 19, 2023 : Starting download of data1.cab   Attempt no 1 DataSize is 31794544
9:18:18 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
9:18:18 AM Thursday, January 19, 2023 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
9:18:18 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
9:18:18 AM Thursday, January 19, 2023 : Completing download of 0x0409.ini
9:18:20 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
9:18:20 AM Thursday, January 19, 2023 : Starting download of data1.hdr   Attempt no 1 DataSize is 4999392
9:18:31 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
9:18:31 AM Thursday, January 19, 2023 : Completing download of data1.hdr
9:18:33 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
9:18:33 AM Thursday, January 19, 2023 : Starting download of data2.cab   Attempt no 1 DataSize is 170168320
9:19:20 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
9:19:20 AM Thursday, January 19, 2023 : Completing download of data1.cab
9:19:22 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
9:19:22 AM Thursday, January 19, 2023 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1637872
9:19:26 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
9:19:26 AM Thursday, January 19, 2023 : Completing download of ISSetup.dll
9:19:28 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
9:19:28 AM Thursday, January 19, 2023 : Starting download of layout.bin   Attempt no 1 DataSize is 994
9:19:28 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
9:19:28 AM Thursday, January 19, 2023 : Completing download of layout.bin
9:19:30 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
9:19:30 AM Thursday, January 19, 2023 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
9:19:30 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
9:19:30 AM Thursday, January 19, 2023 : Completing download of pspInstall.pdf
9:19:32 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
9:19:32 AM Thursday, January 19, 2023 : Starting download of setup.bmp   Attempt no 1 DataSize is 414054
9:19:33 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
9:19:33 AM Thursday, January 19, 2023 : Completing download of setup.bmp
9:19:35 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
9:19:35 AM Thursday, January 19, 2023 : Starting download of setup.ini   Attempt no 1 DataSize is 2430
9:19:35 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
9:19:35 AM Thursday, January 19, 2023 : Completing download of setup.ini
9:19:37 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
9:19:37 AM Thursday, January 19, 2023 : Starting download of setup.inx   Attempt no 1 DataSize is 574598
9:19:38 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
9:19:38 AM Thursday, January 19, 2023 : Completing download of setup.inx
9:19:40 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
9:19:40 AM Thursday, January 19, 2023 : Starting download of data9.cab   Attempt no 1 DataSize is 79773492
9:22:26 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
9:22:27 AM Thursday, January 19, 2023 : Completing download of data9.cab
9:22:29 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
9:22:29 AM Thursday, January 19, 2023 : Starting download of data8.cab   Attempt no 1 DataSize is 209715200
9:24:14 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
9:24:14 AM Thursday, January 19, 2023 : Completing download of data2.cab
9:24:17 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
9:24:17 AM Thursday, January 19, 2023 : Starting download of data7.cab   Attempt no 1 DataSize is 209715200
9:31:58 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
9:31:58 AM Thursday, January 19, 2023 : Completing download of data8.cab
9:32:00 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
9:32:00 AM Thursday, January 19, 2023 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
9:33:42 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
9:33:43 AM Thursday, January 19, 2023 : Completing download of data7.cab
9:33:45 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
9:33:45 AM Thursday, January 19, 2023 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
9:39:56 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
9:39:56 AM Thursday, January 19, 2023 : Completing download of data6.cab
9:39:58 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
9:39:58 AM Thursday, January 19, 2023 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
9:41:39 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
9:41:39 AM Thursday, January 19, 2023 : Completing download of data5.cab
9:41:41 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
9:41:41 AM Thursday, January 19, 2023 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
9:47:44 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
9:47:45 AM Thursday, January 19, 2023 : Completing download of data4.cab
9:47:46 AM Thursday, January 19, 2023 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
9:47:46 AM Thursday, January 19, 2023 : Starting download of installsetup.exe   Attempt no 1 DataSize is 954864
9:47:48 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
9:47:48 AM Thursday, January 19, 2023 : Completing download of installsetup.exe
9:48:38 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
9:48:38 AM Thursday, January 19, 2023 : Completing download of data3.cab
9:48:38 AM Thursday, January 19, 2023 : 2824698 2824698
9:48:38 AM Thursday, January 19, 2023 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
9:48:38 AM Thursday, January 19, 2023 : Allegro Installation Start pid: 28416
9:48:44 AM Thursday, January 19, 2023 : NumberOfComponentsToBeInstalled = 39824
9:48:44 AM Thursday, January 19, 2023 : Updated NumberOfComponentsToBeInstalled = 40625.23
9:48:44 AM Thursday, January 19, 2023 : Updated NumberOfComponentsInstalled = 399
9:53:38 AM Thursday, January 19, 2023 : Feature transfer complete..disabling close button
9:53:38 AM Thursday, January 19, 2023 : Installing: Runtime packages and redistributables
9:53:57 AM Thursday, January 19, 2023 : Installing: Configuring documentation
9:53:57 AM Thursday, January 19, 2023 : Installing: Configuring file associations
9:54:00 AM Thursday, January 19, 2023 : Installing: Setting permissions for files and folders
9:54:05 AM Thursday, January 19, 2023 : Installing: Creating Registries
9:54:05 AM Thursday, January 19, 2023 : Installing: SQL Lite ODBC Driver
9:54:06 AM Thursday, January 19, 2023 : Installing: Finishing Installation
9:54:22 AM Thursday, January 19, 2023 : Running Library Configuration Executable
9:54:22 AM Thursday, January 19, 2023 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
11:28:48 AM Thursday, January 19, 2023 : Exiting Installation Installing Dialog
11:28:48 AM Thursday, January 19, 2023 : An exception occured which is causing the program to close.
11:28:48 AM Thursday, January 19, 2023 : Details of exception are : Not enough quota is available to process this command
11:28:48 AM Thursday, January 19, 2023 : Stack Trace for the exception is    at MS.Win32.ManagedWndProcTracker.HookUpDefWindowProc(IntPtr hwnd)
11:28:48 AM Thursday, January 19, 2023 : Message: An error occurred and PSpice for TI needs to close.
11:29:12 AM Thursday, January 19, 2023 : parameter count = 1
11:29:12 AM Thursday, January 19, 2023 : -wrapper
11:29:12 AM Thursday, January 19, 2023 : Module Name: TIPSpice.exe
11:29:12 AM Thursday, January 19, 2023 : Server OS = False
11:29:12 AM Thursday, January 19, 2023 : Operating system version : 10.0.0.0
11:29:12 AM Thursday, January 19, 2023 : Checking for proxy
11:29:13 AM Thursday, January 19, 2023 : {
		"RegularMessage": {
		"ForceMessage": {
	"UTM_Keyword": {
		"17_4_2020_S006"
11:29:13 AM Thursday, January 19, 2023 : Checking if Licensing URL is accessible
11:29:13 AM Thursday, January 19, 2023 : Initializing
11:29:13 AM Thursday, January 19, 2023 : Deleting file : C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
11:29:13 AM Thursday, January 19, 2023 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
11:29:13 AM Thursday, January 19, 2023 : Response Content length = 1724
11:29:13 AM Thursday, January 19, 2023 : C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
11:29:13 AM Thursday, January 19, 2023 : Reading Json URL File
11:29:13 AM Thursday, January 19, 2023 : setting media download server URL from Json File
11:29:13 AM Thursday, January 19, 2023 : setting Dll path from Json File
11:29:13 AM Thursday, January 19, 2023 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
11:29:13 AM Thursday, January 19, 2023 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
11:29:14 AM Thursday, January 19, 2023 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 17.40.008
11:29:14 AM Thursday, January 19, 2023 : Repair mode
11:29:14 AM Thursday, January 19, 2023 : Check if CDS_HOME is set
11:29:14 AM Thursday, January 19, 2023 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
11:29:14 AM Thursday, January 19, 2023 : LaunchTIPSpiceDlgs()
11:29:14 AM Thursday, January 19, 2023 : Checking for compnts.dat
11:29:36 AM Thursday, January 19, 2023 : error_code cdsVblRegisterInstallation: VblSuccess
11:29:36 AM Thursday, January 19, 2023 : error_code cdsVblRequestLicense: VblSuccess
11:29:40 AM Thursday, January 19, 2023 : Set Installation and Home Directory()
11:29:43 AM Thursday, January 19, 2023 : Checking for memory space
11:29:43 AM Thursday, January 19, 2023 : Memory space available
11:29:43 AM Thursday, January 19, 2023 : Target Dir: C:\Cadence\PSpiceTI
11:29:43 AM Thursday, January 19, 2023 : Working Dir: C:\cds_spb_home
11:29:43 AM Thursday, January 19, 2023 : Silent ini file created
11:29:43 AM Thursday, January 19, 2023 : Skipping download of 0x0409.ini DataSize is 22480
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
11:29:43 AM Thursday, January 19, 2023 : Skipping download of data1.hdr DataSize is 4999392
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
11:29:43 AM Thursday, January 19, 2023 : Skipping download of data1.cab DataSize is 31794544
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
11:29:43 AM Thursday, January 19, 2023 : Skipping download of ISSetup.dll DataSize is 1637872
11:29:43 AM Thursday, January 19, 2023 : Skipping download of layout.bin DataSize is 994
11:29:43 AM Thursday, January 19, 2023 : Skipping download of pspInstall.pdf DataSize is 85357
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
11:29:43 AM Thursday, January 19, 2023 : Skipping download of setup.ini DataSize is 2430
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
11:29:43 AM Thursday, January 19, 2023 : Skipping download of setup.bmp DataSize is 414054
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
11:29:43 AM Thursday, January 19, 2023 : Skipping download of setup.inx DataSize is 574598
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
11:29:43 AM Thursday, January 19, 2023 : Skipping download of data9.cab DataSize is 79773492
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
11:29:43 AM Thursday, January 19, 2023 : Skipping download of data2.cab DataSize is 170168320
11:29:43 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
11:29:44 AM Thursday, January 19, 2023 : Skipping download of data8.cab DataSize is 209715200
11:29:44 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
11:29:44 AM Thursday, January 19, 2023 : Skipping download of data7.cab DataSize is 209715200
11:29:44 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
11:29:44 AM Thursday, January 19, 2023 : Skipping download of data6.cab DataSize is 209715200
11:29:44 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
11:29:44 AM Thursday, January 19, 2023 : Skipping download of data5.cab DataSize is 209715200
11:29:44 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
11:29:45 AM Thursday, January 19, 2023 : Skipping download of data4.cab DataSize is 209715200
11:29:45 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
11:29:45 AM Thursday, January 19, 2023 : Skipping download of installsetup.exe DataSize is 954864
11:29:45 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
11:29:45 AM Thursday, January 19, 2023 : 1514072 1514072
11:29:45 AM Thursday, January 19, 2023 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
11:29:45 AM Thursday, January 19, 2023 : Skipping download of data3.cab DataSize is 209715200
11:29:45 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
11:29:45 AM Thursday, January 19, 2023 : Allegro Installation Start pid: 32952
11:29:51 AM Thursday, January 19, 2023 : NumberOfComponentsToBeInstalled = 39824
11:29:51 AM Thursday, January 19, 2023 : Updated NumberOfComponentsToBeInstalled = 40625.23
11:29:51 AM Thursday, January 19, 2023 : Updated NumberOfComponentsInstalled = 399
11:31:27 AM Thursday, January 19, 2023 : Feature transfer complete..disabling close button
11:31:27 AM Thursday, January 19, 2023 : Installing: Runtime packages and redistributables
11:31:44 AM Thursday, January 19, 2023 : Installing: Configuring documentation
11:31:44 AM Thursday, January 19, 2023 : Installing: Configuring file associations
11:31:45 AM Thursday, January 19, 2023 : Installing: Setting permissions for files and folders
11:31:50 AM Thursday, January 19, 2023 : Installing: Creating Registries
11:31:50 AM Thursday, January 19, 2023 : Installing: SQL Lite ODBC Driver
11:31:51 AM Thursday, January 19, 2023 : Installing: Finishing Installation
11:32:07 AM Thursday, January 19, 2023 : Running Library Configuration Executable
11:32:07 AM Thursday, January 19, 2023 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
11:36:18 AM Thursday, January 19, 2023 : Exiting Installation Installing Dialog
11:44:51 AM Thursday, January 19, 2023 : parameter count = 1
11:44:51 AM Thursday, January 19, 2023 : -wrapper
11:44:51 AM Thursday, January 19, 2023 : Module Name: TIPSpice.exe
11:44:51 AM Thursday, January 19, 2023 : Server OS = False
11:44:51 AM Thursday, January 19, 2023 : Operating system version : 10.0.0.0
11:44:51 AM Thursday, January 19, 2023 : Checking for proxy
11:44:51 AM Thursday, January 19, 2023 : {
		"RegularMessage": {
		"ForceMessage": {
	"UTM_Keyword": {
		"17_4_2020_S006"
11:44:51 AM Thursday, January 19, 2023 : Checking if Licensing URL is accessible
11:44:51 AM Thursday, January 19, 2023 : Initializing
11:44:51 AM Thursday, January 19, 2023 : Deleting file : C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
11:44:51 AM Thursday, January 19, 2023 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
11:44:51 AM Thursday, January 19, 2023 : Response Content length = 1724
11:44:51 AM Thursday, January 19, 2023 : C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
11:44:51 AM Thursday, January 19, 2023 : Reading Json URL File
11:44:51 AM Thursday, January 19, 2023 : setting media download server URL from Json File
11:44:51 AM Thursday, January 19, 2023 : setting Dll path from Json File
11:44:51 AM Thursday, January 19, 2023 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
11:44:51 AM Thursday, January 19, 2023 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
11:44:51 AM Thursday, January 19, 2023 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 17.40.008
11:44:51 AM Thursday, January 19, 2023 : Repair mode
11:44:51 AM Thursday, January 19, 2023 : Check if CDS_HOME is set
11:44:51 AM Thursday, January 19, 2023 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
11:44:51 AM Thursday, January 19, 2023 : LaunchTIPSpiceDlgs()
11:44:51 AM Thursday, January 19, 2023 : Checking for compnts.dat
11:44:58 AM Thursday, January 19, 2023 : error_code cdsVblRegisterInstallation: VblSuccess
11:44:58 AM Thursday, January 19, 2023 : error_code cdsVblRequestLicense: VblSuccess
11:45:01 AM Thursday, January 19, 2023 : Set Installation and Home Directory()
11:45:04 AM Thursday, January 19, 2023 : Checking for memory space
11:45:04 AM Thursday, January 19, 2023 : Memory space available
11:45:04 AM Thursday, January 19, 2023 : Target Dir: C:\Cadence\PSpiceTI
11:45:04 AM Thursday, January 19, 2023 : Working Dir: C:\cds_spb_home
11:45:04 AM Thursday, January 19, 2023 : Silent ini file created
11:45:04 AM Thursday, January 19, 2023 : Skipping download of 0x0409.ini DataSize is 22480
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
11:45:04 AM Thursday, January 19, 2023 : Skipping download of data1.hdr DataSize is 4999392
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
11:45:04 AM Thursday, January 19, 2023 : Skipping download of data1.cab DataSize is 31794544
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
11:45:04 AM Thursday, January 19, 2023 : Skipping download of ISSetup.dll DataSize is 1637872
11:45:04 AM Thursday, January 19, 2023 : Skipping download of layout.bin DataSize is 994
11:45:04 AM Thursday, January 19, 2023 : Skipping download of pspInstall.pdf DataSize is 85357
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
11:45:04 AM Thursday, January 19, 2023 : Skipping download of setup.bmp DataSize is 414054
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
11:45:04 AM Thursday, January 19, 2023 : Skipping download of setup.inx DataSize is 574598
11:45:04 AM Thursday, January 19, 2023 : Skipping download of setup.ini DataSize is 2430
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
11:45:04 AM Thursday, January 19, 2023 : Skipping download of data9.cab DataSize is 79773492
11:45:04 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
11:45:05 AM Thursday, January 19, 2023 : Skipping download of data2.cab DataSize is 170168320
11:45:05 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
11:45:05 AM Thursday, January 19, 2023 : Skipping download of data8.cab DataSize is 209715200
11:45:05 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
11:45:05 AM Thursday, January 19, 2023 : Skipping download of data7.cab DataSize is 209715200
11:45:05 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
11:45:05 AM Thursday, January 19, 2023 : Skipping download of data6.cab DataSize is 209715200
11:45:05 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
11:45:05 AM Thursday, January 19, 2023 : Skipping download of data5.cab DataSize is 209715200
11:45:05 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
11:45:06 AM Thursday, January 19, 2023 : Skipping download of data4.cab DataSize is 209715200
11:45:06 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
11:45:06 AM Thursday, January 19, 2023 : Skipping download of installsetup.exe DataSize is 954864
11:45:06 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
11:45:06 AM Thursday, January 19, 2023 : 197522 197522
11:45:06 AM Thursday, January 19, 2023 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
11:45:06 AM Thursday, January 19, 2023 : Skipping download of data3.cab DataSize is 209715200
11:45:06 AM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
11:45:06 AM Thursday, January 19, 2023 : Allegro Installation Start pid: 21396
11:45:12 AM Thursday, January 19, 2023 : NumberOfComponentsToBeInstalled = 39824
11:45:12 AM Thursday, January 19, 2023 : Updated NumberOfComponentsToBeInstalled = 40625.23
11:45:12 AM Thursday, January 19, 2023 : Updated NumberOfComponentsInstalled = 399
11:47:05 AM Thursday, January 19, 2023 : Feature transfer complete..disabling close button
11:47:05 AM Thursday, January 19, 2023 : Installing: Runtime packages and redistributables
11:47:21 AM Thursday, January 19, 2023 : Installing: Configuring documentation
11:47:22 AM Thursday, January 19, 2023 : Installing: Configuring file associations
11:47:22 AM Thursday, January 19, 2023 : Installing: Setting permissions for files and folders
11:47:27 AM Thursday, January 19, 2023 : Installing: Creating Registries
11:47:27 AM Thursday, January 19, 2023 : Installing: SQL Lite ODBC Driver
11:47:28 AM Thursday, January 19, 2023 : Installing: Finishing Installation
11:47:44 AM Thursday, January 19, 2023 : Running Library Configuration Executable
12:29:17 PM Thursday, January 19, 2023 : parameter count = 1
12:29:17 PM Thursday, January 19, 2023 : -wrapper
12:29:17 PM Thursday, January 19, 2023 : Module Name: TIPSpice.exe
12:29:17 PM Thursday, January 19, 2023 : Server OS = False
12:29:17 PM Thursday, January 19, 2023 : Operating system version : 10.0.0.0
12:29:17 PM Thursday, January 19, 2023 : Checking for proxy
12:29:18 PM Thursday, January 19, 2023 : {
		"RegularMessage": {
		"ForceMessage": {
	"UTM_Keyword": {
		"17_4_2020_S006"
12:29:18 PM Thursday, January 19, 2023 : Checking if Licensing URL is accessible
12:29:18 PM Thursday, January 19, 2023 : Initializing
12:29:18 PM Thursday, January 19, 2023 : Deleting file : C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
12:29:18 PM Thursday, January 19, 2023 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
12:29:18 PM Thursday, January 19, 2023 : Response Content length = 1724
12:29:18 PM Thursday, January 19, 2023 : C:\Users\Marc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
12:29:18 PM Thursday, January 19, 2023 : Reading Json URL File
12:29:18 PM Thursday, January 19, 2023 : setting media download server URL from Json File
12:29:18 PM Thursday, January 19, 2023 : setting Dll path from Json File
12:29:18 PM Thursday, January 19, 2023 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
12:29:18 PM Thursday, January 19, 2023 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
12:29:18 PM Thursday, January 19, 2023 : ReleaseVersion in XML: 17.40.008 InstalledVersion on system: 17.40.008
12:29:18 PM Thursday, January 19, 2023 : Repair mode
12:29:18 PM Thursday, January 19, 2023 : Check if CDS_HOME is set
12:29:18 PM Thursday, January 19, 2023 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
12:29:18 PM Thursday, January 19, 2023 : LaunchTIPSpiceDlgs()
12:29:18 PM Thursday, January 19, 2023 : Checking for compnts.dat
12:29:41 PM Thursday, January 19, 2023 : error_code cdsVblRegisterInstallation: VblSuccess
12:29:41 PM Thursday, January 19, 2023 : error_code cdsVblRequestLicense: VblSuccess
12:29:44 PM Thursday, January 19, 2023 : Set Installation and Home Directory()
12:29:46 PM Thursday, January 19, 2023 : Checking for memory space
12:29:46 PM Thursday, January 19, 2023 : Memory space available
12:29:46 PM Thursday, January 19, 2023 : Target Dir: C:\Cadence\PSpiceTI
12:29:46 PM Thursday, January 19, 2023 : Working Dir: C:\cds_spb_home
12:29:46 PM Thursday, January 19, 2023 : Silent ini file created
12:29:46 PM Thursday, January 19, 2023 : Skipping download of 0x0409.ini DataSize is 22480
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
12:29:46 PM Thursday, January 19, 2023 : Skipping download of data1.hdr DataSize is 4999392
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
12:29:46 PM Thursday, January 19, 2023 : Skipping download of data1.cab DataSize is 31794544
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
12:29:46 PM Thursday, January 19, 2023 : Skipping download of ISSetup.dll DataSize is 1637872
12:29:46 PM Thursday, January 19, 2023 : Skipping download of layout.bin DataSize is 994
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
12:29:46 PM Thursday, January 19, 2023 : Skipping download of pspInstall.pdf DataSize is 85357
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
12:29:46 PM Thursday, January 19, 2023 : Skipping download of setup.ini DataSize is 2430
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
12:29:46 PM Thursday, January 19, 2023 : Skipping download of setup.inx DataSize is 574598
12:29:46 PM Thursday, January 19, 2023 : Skipping download of setup.bmp DataSize is 414054
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
12:29:46 PM Thursday, January 19, 2023 : Skipping download of data9.cab DataSize is 79773492
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
12:29:46 PM Thursday, January 19, 2023 : Skipping download of data2.cab DataSize is 170168320
12:29:46 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
12:29:47 PM Thursday, January 19, 2023 : Skipping download of data8.cab DataSize is 209715200
12:29:47 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
12:29:47 PM Thursday, January 19, 2023 : Skipping download of data7.cab DataSize is 209715200
12:29:47 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
12:29:47 PM Thursday, January 19, 2023 : Skipping download of data6.cab DataSize is 209715200
12:29:47 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
12:29:47 PM Thursday, January 19, 2023 : Skipping download of data5.cab DataSize is 209715200
12:29:47 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
12:29:48 PM Thursday, January 19, 2023 : Skipping download of data4.cab DataSize is 209715200
12:29:48 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
12:29:48 PM Thursday, January 19, 2023 : Skipping download of installsetup.exe DataSize is 954864
12:29:48 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
12:29:48 PM Thursday, January 19, 2023 : 265040 265040
12:29:48 PM Thursday, January 19, 2023 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
12:29:48 PM Thursday, January 19, 2023 : Skipping download of data3.cab DataSize is 209715200
12:29:48 PM Thursday, January 19, 2023 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
12:29:48 PM Thursday, January 19, 2023 : Allegro Installation Start pid: 9684
12:29:54 PM Thursday, January 19, 2023 : NumberOfComponentsToBeInstalled = 39824
12:29:54 PM Thursday, January 19, 2023 : Updated NumberOfComponentsToBeInstalled = 40625.23
12:29:54 PM Thursday, January 19, 2023 : Updated NumberOfComponentsInstalled = 399
12:31:18 PM Thursday, January 19, 2023 : Feature transfer complete..disabling close button
12:31:18 PM Thursday, January 19, 2023 : Installing: Runtime packages and redistributables
12:31:34 PM Thursday, January 19, 2023 : Installing: Configuring documentation
12:31:35 PM Thursday, January 19, 2023 : Installing: Configuring file associations
12:31:35 PM Thursday, January 19, 2023 : Installing: Setting permissions for files and folders
12:31:41 PM Thursday, January 19, 2023 : Installing: Creating Registries
12:31:41 PM Thursday, January 19, 2023 : Installing: SQL Lite ODBC Driver
12:31:41 PM Thursday, January 19, 2023 : Installing: Finishing Installation
12:31:57 PM Thursday, January 19, 2023 : Running Library Configuration Executable
12:31:57 PM Thursday, January 19, 2023 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
  • Hi Marc,
    This appears to be network/proxy related. Would you please take a look at the file cdsPSpiceNetworkStatus.txt? It's in the same folder as cdsPspiceTIlog.txt.
    JC
  • Hello JC, the evening I wrote my post I was able to install at home. I imagine the cdsPSpiceNetworkStatus.txt file that might have shown the problem was overwritten during the successful install, but it sounds likely that you are right and it was network/proxy related. I'm a little confused because one of my colleagues was able to successfully install at work. Anyway, my problem is resolved. Thanks for your help. -Regards, Marc
