Other Parts Discussed in Thread: BQ76952
Hi ,
-i have a question concerning this bloc (disharge protection) :
-whats the role of each component in circle below?
thanks in advance,
Ahmed.
Hi ,
thanks in advance,
Ahmed.
Hi Ryan Tan,
thanks for your reply,
another question:
-how to determine current to calculate the power dissipation in Res R130, R132, R133,?
-why chose 2 res (R132 & R133 ) in series 511OHM and not one Res 1K?
thanks,
Ahmed.
Hi Ahmed
How to choose the resistance value of R130 R132 and R133 depends on the requirements of your system for turn on MOSFET time. you can definitely use 1K resistor to replace it. at the same time, you can also refer to datasheet 7.25 High-side NFET Drivers, you can find different resistor correspond to different turn on time. there is a microampere level of current when driving, so the dissipation of R130 R132 and R133 is very small.
Best Regards
Yebohr zhao
